Old May 16, 2006, 02:22 PM
shaul_ei is offline
Find More Posts by shaul_ei
Tel Aviv
Joined Feb 2006
New Product
SmartPropoPlus and PPJoy
For those who want to connect their Tx to the computer via the soundcard. For those who think that SmartPropoPlus is too FMS-oriented. For those who like PPJoy.
I think I managed to create a piece of software that you are going to like. It is only Alpha, so it is still unpolished and basic. But, it works!
It goes like that:
You connect your Tx to the soundcard (e.g. Mike).
You install PPJoy (Virtual Joystick of course)
You launch this SmartPropoPlus Extension
And you get a universal joystick out of your Tx.
Please try it - I need your comments!
Downloads are here
Documentation is here.
My email address is in the application about box.
shaul_ei is offline Find More Posts by shaul_ei
Old May 16, 2006, 10:46 PM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
Great news. This is the way to go. I tried to use it in ClearView and it is almost there. With my Futaba 8 radio, I could get only 3 channels working - throttle, aileron and elevator. The best about this solution is that the cable is only few dollars and trip to Radio Shack.
Stefan
http://rcflightsim.com
skirtz is offline Find More Posts by skirtz
Old May 16, 2006, 11:46 PM
shaul_ei is offline
Tel Aviv
Joined Feb 2006
Stefan has kindly sent me a license for ClearView. I will see what I can do ASAP. Thank you Stefan!
Old May 16, 2006, 11:53 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
So it fully emulates a joystick? If that is the case I better try it with my code to run the RFG3 demo. Could be the easy tx-interconnect solution I was looking for. Thanks!
rutat is offline Find More Posts by rutat
Old May 17, 2006, 12:56 AM
shaul_ei is offline
Tel Aviv
Joined Feb 2006
Rutat, this is only a zero-zero version. It works fine on my box, but you will have to test it on yours as well. Please send/post your feedbacks.
Old May 17, 2006, 08:47 AM
Daniel11 is offline
Find More Posts by Daniel11
Daniel11's Avatar
Vicksburg, MI
Joined Jul 2004
I installed PPJoy, and when I start configure joysticks and click add, the options explained in your instructions are blocked out. What might be the problem, or did I do something wrong?
-Daniel
Daniel11 is offline Find More Posts by Daniel11
Old May 17, 2006, 01:11 PM
shaul_ei is offline
Tel Aviv
Joined Feb 2006
On the contrary. You have no other option but the correct one. You are on the right track.
Old May 17, 2006, 05:16 PM
Daniel11 is offline
Daniel11's Avatar
Vicksburg, MI
Joined Jul 2004
Ok, I got all four channels working corectly, now if I can just set up the dual rates.......
-Daniel
BTW, PPM-Audio played a key role in getting this to work. Apparently, having the ATV and EPA set up on my radio was causing problems, and I was able to see that by using PPM-Audio.
Old May 18, 2006, 01:32 AM
shaul_ei is offline
Tel Aviv
Joined Feb 2006
Phil's Thermometer is very useful indeed. And since we do not share code, it helps me a lot when debugging mine. Thank you Phil!
Old May 19, 2006, 03:18 PM
bazuka is offline
Find More Posts by bazuka
Pro Bro #2277
bazuka's Avatar
Longmont, CO.
Joined Feb 2006
I installed PPJoy and it works very well with FMS. I now have complete throttle control. Before PPJoy, I had no way to stop throttle, it was always at one quarter, never lower.
I tried it on the ClearView demo, so far zero success.
bazuka is offline Find More Posts by bazuka
Old May 19, 2006, 03:50 PM
skirtz is offline
Joined Sep 2002
PPJoy works with ClearView. What was your problem?
Stefan
Old May 19, 2006, 04:06 PM
bazuka is offline
Pro Bro #2277
bazuka's Avatar
Longmont, CO.
Joined Feb 2006
I tried everything out on FMS, then switched to ClearView. After opening Clearview, switched joystick but could not calibrate. It mentioned something about calibrating with Windows. Tried the game controller function in Control Panel, would not calibrate there either.
I am using a JR 6 ch, connected with trainer cord through my sound card.
Old May 19, 2006, 06:16 PM
skirtz is offline
Joined Sep 2002
First, connect in your radio. Then start the SmartPropo console and make sure that PPJoy Virtual Joystick works and is properly callibrated in Windows Game Controllers screen. Just after that, start ClearView and select the Virtual Joystick in the Controllers setup window. Then assign the channels and save. It will work.
Stefan
Old May 20, 2006, 06:28 PM
sameershah is offline
Find More Posts by sameershah
Joined May 2006
help with futaba
I am thinking of connecting my 6EXA to the Mono jack using the following diagram
[IMG]C:\Futaba_Square.jpg[/IMG]
Is it the right diagram. The thing that is confusing me is that the TX is labled as slave, but I thought it is the master as it is in control and sending the singnals to the computer. Can somebody explain it to me please?
Thanks.
sameershah is offline Find More Posts by sameershah
Old May 20, 2006, 06:44 PM
Joined May 2006
Lets see if the image is displayed now...
Discussion SmartPropoPlus and PPJoy - new version 3.0.1 shaul_ei Simulators 1 May 22, 2006 12:42 PM
