Old May 15, 2006, 01:29 PM
JustGoFly is offline
Find More Posts by JustGoFly
Rochester, NY
JustGoFly's Avatar
United States, NY, Monroe
Joined May 2004
Need Help - Ideas for holding Formosa Canopy on
My Formosa Canopy is being subjected to ludicrous speeds and extra magnets are not holding it tight. It's floated from ahigh three times over the past three days, and I'd hate to lose it. I've resorted to wrecking the paint job with tape to hold it on, but even that has peeled up in flight.
I've seens some ingenious ideas on these forums and am hoping someone has come up with something cool for the Formosa canopy.
Here is a video of some of the stress this puppy is taking:
Formosa Video
Please post a picture.
Vinnie
JustGoFly is offline Find More Posts by JustGoFly
Old May 21, 2006, 09:34 PM
Glu it again Sam is offline
Find More Posts by Glu it again Sam
Pickering, Ontario
Joined Aug 2004
I found that knife edge flying was sliding the front of my Formosa canopy sideways till the magnet no longer was overtop the metal piece, then it would fly off.
I put a short bamboo pin between the canopy and the fuselage. Confirm that it's at 90 degrees to the two pins at the rear, then glue it to the canopy. To install the canopy, engage the rear pins, then roll the canopy down till the magnet catchs. The pin prevents the sliding, and the canopy stays put.
Sorry, no picture.
GIAS
Glu it again Sam is offline Find More Posts by Glu it again Sam
Old Jun 01, 2006, 10:04 AM
diviatix is offline
Find More Posts by diviatix
All thumbs is good for RC
diviatix's Avatar
Woodstock, Ontario
Joined Jul 2005
good canpoy mod...
I put a little dubro mini-hinge at the front of the canopy and the regular supplied magnet at the back...
Just embed 1 leaf of the hinge in the canopy and epoxy...same on the other leaf into the fuse ..canopy then just pops forward like a front hinged car hood----works really well....
Also epoxy a short vertical strip of plastic inside the hatch on each side sticking up past the lip of the fuse where canopy closes so when the canopy is closed u cant see anything and helps against lateral forces...
Cheers
diviatix is offline Find More Posts by diviatix
Old Jun 09, 2006, 11:28 AM
ramintrepid is offline
Find More Posts by ramintrepid
Joined Aug 2004
I looked at other ideas on this site, and chose to add two more rare earth magnets. I purchased them from Radio Shack. Just drill two more holes in the magnet holder and also add a longer piece of metal on the fuselage where the magnets will contact. It hasn't come off yet in flight.
ramintrepid is offline Find More Posts by ramintrepid
Old Jun 15, 2006, 02:59 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
I just put in strips of office tape at front and rear for some security.
perttime is online now Find More Posts by perttime
Old Aug 01, 2006, 09:14 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Cheers
I think this is a great idea. I will probably convert mine to this.
Right now, I glued a small balsa stick to the inside of the cowl, and inside the cockpit right behind the battery, and have a rubber band holding the cowl on, as well as the original hardware. Even if the cowl pops off (once in like 100 flights) it is still attached by the rubber band. The force of the rubber band also helps hold the cowl down.
antslake is offline Find More Posts by antslake
Latest blog entry: FAA registration
Old Aug 01, 2006, 09:44 PM
lmopar69 is offline
Find More Posts by lmopar69
Team Cobra!!! Ssssssss!
lmopar69's Avatar
United States, NE, Doniphan
Joined Feb 2005
http://www.engconcepts.net/List_Of_C...ce_Magnets.asp
Try some of those... cant hurt to have a bunch layin around at those prices!
lmopar69 is offline Find More Posts by lmopar69
Discussion Need Help!!Looking for Details on this Stearman Sturmbock(TimoK) Scale Kit/Scratch Built 18 Dec 05, 2006 11:32 PM
Need help - frustrated with V-tail linkage on Gambler (and the Bug for this matter) dimple Hand Launch 8 Apr 14, 2004 10:34 AM
need help, looking for a B58 hustler ttnissan Electric Ducted Fan Jet Talk 3 Jun 11, 2003 10:22 PM
Need Covering Ideas for DS FAST! nr5a Parkflyers 4 Apr 05, 2003 05:15 PM
Need help/ideas on what to build! awood12345 Scratchbuilt Indoor and Micro Models 0 Dec 06, 2002 02:52 PM
