Old May 14, 2006, 10:27 PM
LittleJon is offline
Find More Posts by LittleJon
LittleJon's Avatar
Laguna Beach, California
Joined Nov 2004
Portable Plane with Ripstop Nylon Wings (70" wingspan)
Here's my new scratch-built plane. I designed it for aerial photography, but wanted it to be small enough to fit on the rear parcel shelf of my MX-5 Miata.
It's got a 70" wingspan, but as you can see from the pics it collapses down pretty small. The fabric collapses like an accordian while on the lower carbon wing spars. When the upper spars are attached the wing pulls out and attaches to nocks on the ends of the spars using shock chord (elasticated thick string).
The airfoil is created by shaped alumium ribs that I slid in to pockets sewn in to the wing. The ends of the rods plug in to kite standoff connectors that slide along the carbon spars.
Two Slow Stick aluminum booms are stuck end to end to create the fuselage. I used magnets to provide linkage between the servo control rods on the two booms. However, it turned out that the magnets weren't strong enough so I'm going to replace them with much stronger ones.
I've got it to fly, but it seems that the rudder isn't big enough for the job. On the two occassions I've flown it so far I had trouble steering at times. That was in 6+ mph wings. I'm going to make the rudder larger. This isn't exactly a fast plane, so at times the airspeed across the rudder must be very low.
LittleJon is offline Find More Posts by LittleJon
Old May 14, 2006, 10:40 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Increase the dihedral angle to get better turning on rudder....
Very interesting project!
BEC is online now Find More Posts by BEC
Old May 14, 2006, 10:55 PM
LittleJon's Avatar
Joined Nov 2004
Thanks for the suggestion. I've got a fair amount of dihedral. If I remember correctly the holes that the lower carbon wing spars fit in to are drilled at a 4 degree angle. The tension of the bracing lines increases the dihedral further. I could increase the tension on the lines next time to get more. At the moment they're adjustable, but at some point I'll make them fixed.
Old May 15, 2006, 01:53 PM
BEC is online now
BEC
BEC
BEC's Avatar
Joined Jan 2001
Somewhere around 6-7 degrees seems to be a good number for most "high wing" types. I was just looking at the in-flight picture and thinking it might need a bit more. This is a review I did of a plane about that same size, but rather heavier.... in it I discuss exactly this question: http://www.rcgroups.com/links/index.php?id=4014
Old May 16, 2006, 01:45 AM
LittleJon's Avatar
Joined Nov 2004
Thanks for the link. The carbon tubing I used turned out to be stiffer than I expected, so it's not as easy to put a lot of dihedral in as I thought. However, I'm sure I can give it quite a bit more. I certainly didn't have that much tension in the bracing lines for the previous flights.
I'm sure I can easily add another few degrees.
Old May 16, 2006, 02:17 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
The dihederal is most important at the wing tips (where it's got most leverage), so is OK if just the wing tips bend up. (which is what can happen if you tension the rigging wires)
BTW, that translucent wing looks beautiful in the air!
RobinBennett is offline Find More Posts by RobinBennett
Old May 16, 2006, 03:47 PM
LittleJon's Avatar
Joined Nov 2004
Thanks, but it attracts insects like you wouldn't believe!
Discussion Ripstop material Portable plane freddb3 Parkflyers 5 Mar 29, 2006 01:40 AM
GWS - I would love a GWS plane with a 16" wingspan!! WingsofEagles GWS (Grand Wing Servo) 5 May 11, 2005 02:44 AM
Can anyone recommend A plane with less then 30" wingspan.. rumme Parkflyers 13 Feb 16, 2005 04:37 PM
Question Got plane with huge wingspan (43"), good or bad? meowmix Beginner Training Area (Aircraft-Electric) 8 Apr 15, 2004 07:08 PM
