Old May 14, 2006, 12:11 PM
Renzi6669@aol.com
Renzi6669@aol.com
Guest
n/a Posts
Need help with ailerons
This message from Renzi6669@aol.com brought to you by EFLIGHT!
Working on a fun fly plane, scratch built, built up wing, profile fuze. The
wing has a clarky airfoil, 10" cord, 35" span, full lenght ailerons. My
question....Is it OK to have the ailerons ( flat 1/4" balsa) past the TE vs
"built" into the wing like on Cubs, trainers, or any plane that has a flat bottom
airfoil??? My Great Planes Slinger flying wing ( flat bottom ) is an example
of the ailerons past the TE of the wing. I would imagine that it is ok. If
so, then what with ( 1" 1 1/2" 2" ) would be ideal....would like good
manuvability at slow flying speeds.....???
Mike R
--- StripMime Report -- processed MIME parts ---
multipart/alternative
text/plain (text body -- kept)
text/html
*** Any complaints or problems? Send an email to monitor@ezonemag.com
*** For help with list commands go to http://www.ezonemag.com/pages/mailhelp.htm
*** For the list rules go to http://www.ezonemag.com/pages/mailrule.htm
Old May 14, 2006, 02:11 PM
Pete Foss
Pete Foss
Guest
n/a Posts
Re: Need help with ailerons
This message from Pete Foss <petefoss@skymasters.org> brought to you by EFLIGHT!
I'd go with 2" myself.
John Likakis
John Likakis
Guest
n/a Posts
This message from John Likakis <blurunnr@sover.net> brought to you by EFLIGHT!
Mike,
I've built dozens of models with wings like that. Works just fine. As
for the correct chord for the ailerons, I'd shoot for 1.5 inch as a
minimum, and would probably use 2 inches at the root, tapering to 1.5
inches at the tips. Give you good maneuverability with a slightly
tapered planform.
JL
> Thanks
> Mike R
Discussion Need help with Eclipse 7 programming - Acro/Glid and Thottle/Ailerons jbachman Electric Sailplanes 2 Jan 29, 2007 12:33 PM
Need Help with Sluggish Ailerons...! Boss248 3D Flying 13 Dec 02, 2004 11:00 PM
Need help with ailerons! KMKAZE Electric Plane Talk 11 Jul 19, 2001 12:34 AM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
