Old May 13, 2006, 02:06 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Build Log
GWS DHC-2 Beaver Build
Ok I know this has been done before but I thought I would post my build log for a GWS DHC-2 Beaver Kit, I just built I took pictures along the way and tried some of the tricks I have picked up over the years.
This is a all stock kit using all GWS gear except where noted!
GWS parts used in this build are:
1. GWS DHC-2 Beaver kit with GW350c Stock motor and ep1047 prop
2. Pico+/F/BB/J servos
1. ICS300li speed control ( For Lipo battery packs)
1. GW/R4PII receiver
2. deans ez conectors ( for the servos )
2. gws lite foam 1 1/2" wheels
1. gws lite foam 1" wheels
Building material
new pack #11 xacto blades
rool of strapping tap ( the kind with fiber strands in it)
mini hot glue gun with (low temp glue sticks)
gws contact cement
pair of metal cutters
wax paper
clear scotch tape 3/4" type
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old May 13, 2006, 02:35 PM
tallflyer's Avatar
Joined Jul 2002
Let the build begin :)
Ok hear are all the pictures of the build.
Old May 13, 2006, 02:45 PM
tallflyer's Avatar
Joined Jul 2002
Things not pictured!
Sorry I did not take pictures of the wing assemebly but I will give you a detailed verison of my build method!
take the two wing half and trim the middle section of both halfs so that when they are next to each other its a good fit.
lay a piece of wax paper on a flat surface and putting a box or a book under one of the wing half to get the angle right see the instruction for the angle
( I hot glue the 2 halfs together put a good amount of glue on one side and then press the wing half together and hold them in place intill the glue sets. perfect and strong every time.
also use the low heat gue sticks to mount the plastic wing mount to the top of the wings!
I also used the hot glue to mount he crowl mounts and all the other itmes that require GWS glue wow makes builging quick and clean and strong!
Old May 13, 2006, 06:16 PM
RC4ZEKE is offline
Find More Posts by RC4ZEKE
Whistling Death
RC4ZEKE's Avatar
WA,USA
Joined Jun 2004
Nicely detailed build log, Tallflyer.
Never have got around yet to getting me this plane. I do like how it looks and I think it would be even better with floats on it. Hmmm, i've always wanted a float plane.
RC4ZEKE is offline Find More Posts by RC4ZEKE
Old May 20, 2006, 01:47 PM
tallflyer's Avatar
Joined Jul 2002
Brushless Upgrade!
Ok I decided after flying yesterday that I would try a BP21 brushless motor on my GWS DHC-2 Beaver for all of you who have not seen this little motor it has to be the Best bang for your Dollar
I flew it again this morning and WOW what a difference the plane is lighter and since I'm using a 2 cell lipo not the Recomended nimh/nicd GWS has in there manual the motor and battery weight a lot less then the old stock setup
the plane will fly around at half throttle like it used to fly at 3/4.
If your looking to go straight up virtical with a beaver better make sure you have a strong reinforced wing before you punch the throttle.
Now this plane is real fun to fly and landing is a great since the plane is even lighter then before.
Old Jul 10, 2006, 02:29 PM
bob_suruncle is offline
Find More Posts by bob_suruncle
I think I can glue that..
bob_suruncle's Avatar
Paris, Ontario, Canada EH
Joined Jul 2005
Originally Posted by tallflyer
Ok I decided after flying yesterday that I would try a BP21 brushless motor on my GWS DHC-2 Beaver for all of you who have not seen this little motor it has to be the Best bang for your Dollar I have them on both my sites:
http://www.sdparkflyers.com/brushless.html
http://www.flatfoamflyers.com/Brushless.html
I flew it again this morning and WOW what a difference the plane is lighter and since I'm using a 2 cell lipo not the Recomended nimh/nicd GWS has in there manula the motor and battery weight alot less then the old stock setup
Interesting: I put a brushless in my Beaver and couldnt even get it off the ground with a 2s..... had to go to a 3S to launch it.
bob_suruncle is offline Find More Posts by bob_suruncle
Old Jul 10, 2006, 02:45 PM
tallflyer's Avatar
Joined Jul 2002
bob
really my flys great on the setup above!
Im going to shot some video one of these days as soon as the wind decided to let me fly on my day off!
Old Jul 10, 2006, 03:07 PM
kcwannafly is offline
Find More Posts by kcwannafly
SoCal, USA
Joined Jul 2006
Depends on the B/L motor you use.
kcwannafly is offline Find More Posts by kcwannafly
Old Jul 10, 2006, 04:15 PM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
My J3 Cub which is a similar size to the Beaver goes vertical on a BP12 with a 2 cell and a 1047SF. But you need a battery that can put the amps out.
Tallflyer now you've got some hours on the Beaver - how do those u/c fairings look. You must be real pretty at landing (and a whole lot better than me!) if they're not busted up yet.
Roger Lombard is offline Find More Posts by Roger Lombard
Old Jul 12, 2006, 02:10 PM
TopSpin is offline
Find More Posts by TopSpin
Leesburg, VA
Joined Jul 2005
Great minds really do think alike Roger, that's exactly what I put in my Cub and it bores a hole in the sky when you push the stick forward.
I'm running Thunder Power 2S 1320s in it and it draws about 10 amps wide open and around 2.2 cruising.
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old Jul 12, 2006, 02:56 PM
David Winter is offline
Find More Posts by David Winter
'Riders fan.
David Winter's Avatar
Vancouver, British Columbia
Joined Mar 2004
Anyone put ailerons on the Beaver? Doesn't stike me as difficult, just wondered why nobody has done it.
David Winter is offline Find More Posts by David Winter
Old Jul 14, 2006, 10:22 AM
Joined Jul 2005
I was using a park 370 inrunner with my 9070 x 3.... If I was using an outrunner maybe...
Old Jul 14, 2006, 10:42 AM
tallflyer's Avatar
Joined Jul 2002
I want to try it but have not had a chance to work on the project!
Im just going to add some pieces of white depron to the trailing edge of each wing and put and put a small little micro servo under each wing to control the aileron. that way if I dont like it I can remove the whole setup and the plane is back to the original version!
Cool GWS DHC-2 Beaver with onboard video tallflyer GWS (Grand Wing Servo) 11 Aug 03, 2006 11:04 PM
Found Cowl for GWS DHC-2 Beaver RyanF Aircraft - General - Miscellaneous (FS/W) 0 Jun 02, 2006 11:21 PM
Question GWS DHC-2 Beaver for indoor? FlattyFlier GWS (Grand Wing Servo) 16 Dec 29, 2005 08:59 PM
GWS DHC-2 Beaver Horizon Vendor Talk 1 Jul 02, 2002 05:18 PM
GWS DHC-2 Beaver Horizon Vendor Talk 0 Apr 08, 2002 02:44 PM
