Old Sep 09, 2001, 02:40 AM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Electric Jet Factory F-86
Flew the F-86 today and got some great video. Should be up on EJF web site by Sunday night. The plane is flying great. Take offs are fast and nice climb out. USing the HW 730 fan and Aveox 1412/2Y motor on 18 cells. Going to try using a 1415/2Y next. The Midi fan version should be ready to fly in about 3 weeks. Keep you all Robert has kits avaiable. ;-)
Bob Ruff
bruff is online now Find More Posts by bruff
Old Sep 09, 2001, 09:09 AM
p471701
p471701
Guest
n/a Posts
bob:what is the auw. of this set up?...gregg
Old Sep 09, 2001, 11:28 AM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
The HW 730 version is 6.5 lb. We are hoping on the Midi version to get the weight down to 6.0 lb.
Bob
Old Sep 09, 2001, 02:18 PM
Brucejay34 is offline
Find More Posts by Brucejay34
stonington , conn....usa
Joined Sep 2001
i'm getting ready to build the same plane with a midi fan and 1409...what can I expect for performance ? or should I opt for the larger fan on this plane?...thanx bruce
Brucejay34 is offline Find More Posts by Brucejay34
Old Sep 09, 2001, 02:36 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I'm going a Midi fan version also. I think the 1409/2Y is not big enough. I'm using the 1412/2Y or Hacker D50-18S motor.
Old Sep 10, 2001, 09:40 AM
dorysch1 is offline
Find More Posts by dorysch1
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
my Tutor Jet flies good with the Hacker and midi It weighs in at 6.5
dorysch1 is offline Find More Posts by dorysch1
Old Sep 10, 2001, 08:49 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Congrats Bob!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Sep 11, 2001, 12:11 AM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
I have this plane, kit was bought in 1983. I have flown it twice on a Midi Fan, Ultra 930-6 and 20 cells. Weight is 7 lbs. It takes off fine. I have yet to land without damage. It does not like to be flown too slow so remember to keep the speed up on landing.
I'm in the process of fixing the nose again.
Bob, I will be really interested to know how you plan to get the weight down to 6 lbs
Ken
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Sep 11, 2001, 12:34 AM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
To help keep the weight down. I do not cut the hatch out. This adds a great deal of strength to the nose. The fan is mounted the same way as the JHH F-86. Two plywood "T" pieces that mount to the fuselage sides. I do not use the plywood bulkheads. I make the canopy a removalable hatch to allow access to the inside for wire hook up. With the brushless setup I'm usung 18 2400 ma cells (zapped). The aux inlet in the wing and the blow-in doors on the fus are used. I put a floor (1/64 plywood)in the fus running from the inlet to the LE of the wing (velcro). This smooths the air coming in from the nose and blow-in doors. All the mods with be in the Midi fan version of the kit. Note the HW 730 version does use both ply bulkheads.
Wanted Electric Jet Factory F-86 Sabre 49" ws PREACHHAMES Aircraft - Electric - Airplanes (FS/W) 2 Nov 28, 2005 09:41 AM
Robert - Electric Jet Factory F-86 FAA Electric Ducted Fan Jet Talk 41 Apr 10, 2003 07:50 PM
Electric Jet Factory F-86 with Hacker motor bruff Electric Ducted Fan Jet Talk 3 Nov 12, 2001 01:32 PM
Electric Jet Factory F-18 NIB byoung Aircraft - Electric - Airplanes (FS/W) 1 Sep 15, 2001 01:43 AM
Electric Jet Factory F-16 EDF CAWayne Electric Ducted Fan Jet Talk 0 Apr 26, 2001 01:47 PM
