Old May 12, 2006, 09:00 AM
skylight is offline
Find More Posts by skylight
Walnut Creek, CA
Joined Apr 2004
Voltage cutoff for 3 cell Lipo
I want to use a Castle Creations Pixie 20P with a 3 cell, 1250 mAh Lipo, 11.1V from Common Sense RC. The battery manufacturer recommends the voltage cutoff at 3.2 V per cell (9.6V total). However, the Pixie 20P program option for 3 cell Lipo is 8.4V. Has anyone else run into this problem? Can I use the 8.4V cutoff safely with the 3 cell Lipo?
What ESC can I use ?
Suggestions Please
skylight is offline Find More Posts by skylight
Old May 12, 2006, 09:09 AM
hb888 is offline
Find More Posts by hb888
Monmouth UK
8.4V is too low. At least 9.0V is minimum. I have my LiPo alarm set to 9.6V. Go get one.
hb888 is offline Find More Posts by hb888
Old May 12, 2006, 10:10 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
I also set my LVC to 9.6 volts. The experts say it is important to not let any cell get below 3 volts. Since some cells discharge faster the others, I am just trying to make those expensive Lipos last as long as possible. I'm not cheap just frugal!
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old May 12, 2006, 07:04 PM
skylight is offline
Walnut Creek, CA
Joined Apr 2004
What is a Lipo alarm? and where can I get one.
Old May 12, 2006, 08:07 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
skylight:
You must have one in an older package since this was addressed some time ago and the industry has since settled on a minimum of 3v/cell.
You can get a great lipo low voltage device from Diversity Model Aircraft called the Li-Saver.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old May 12, 2006, 08:22 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Another very good LiPoly LVC device is the LiPo Shield.
http://www.dimensionengineering.com/LipoShield.htm
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old May 12, 2006, 09:20 PM
skylight is offline
Walnut Creek, CA
Joined Apr 2004
Thanks for all the information. I am new to RC and I am trying to figure all this out.
Skylight
Discussion ESC Cutoff for 3 Cell Lipo skylight Power Systems 1 May 11, 2006 12:23 AM
Brushed 350 size made for 3 cell Lipo?? praymond Power Systems 6 Oct 22, 2005 09:31 AM
BEC for 3-cell Lipo on micro heli OmegaDot DIY Electronics 6 Jul 08, 2004 04:20 PM
What voltage cutoff for 10 cell packs? cloudhopper Batteries and Chargers 0 Dec 19, 2003 07:45 PM
CC ESC says 7.2v cut off for 3 Cell LiPo. MHawker Batteries and Chargers 4 Aug 27, 2003 07:46 AM
