Old Jul 13, 2002, 09:17 PM
Gonflyin01 is offline
Find More Posts by Gonflyin01
Toledo Ohio, USA!
Joined Dec 2001
MPI 45 amp ESC. Any help you can give me?
I bought a 45 amp MPI esc for my twin U-2. It says for over 7 cells to cut the red pin out, and use a seperate RX pack. Why is that? What happens if i dont?
Gonflyin01 is offline Find More Posts by Gonflyin01
Old Jul 19, 2002, 07:04 PM
Toledo Ohio, USA!
Joined Dec 2001
Anyone? once I take out the red pin...I have to add another 3 oz's in battery weight.
Old Jul 19, 2002, 07:09 PM
matthev is offline
Find More Posts by matthev
Joined Jan 2001
Above 7 cells and the regulator to the receiver will not be able to handle the rated current... ie you won't be able to use as many servos as it is rated (or it might burn out altogether). Either stick to 7 or less cells or cut the pin.
matthev is offline Find More Posts by matthev
Old Jul 20, 2002, 07:57 AM
Toledo Ohio, USA!
Joined Dec 2001
okay, thanks.
Cool hummingbird will the himax brushless work can you guys give me your in put breyman Micro Helis 1 Sep 06, 2005 09:13 PM
Question hummingbird will the himax brushless work can you guys give me your in put breyman Electric Heli Talk 1 Jan 26, 2005 01:08 AM
Trying to pinpoint the cause of a burnt ESC, maybe one of you can help... revhigh Power Systems 4 May 01, 2004 03:19 PM
WTT: MPI 45 amp ESC,for another ESC Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 0 Nov 08, 2002 03:10 PM
MPI 45 Amp ESC, almost new steveo64 Aircraft - Electric - Airplanes (FS/W) 3 Oct 26, 2002 08:32 AM
