Old Jul 13, 2002, 04:48 PM
rdogg32 is offline
Find More Posts by rdogg32
Flying high since '85
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
Need help with motor overheating!
As you may have read in another post, I am having trouble with my Eco-8. I have the Phasor 30/3, 40-3P controller, 23 tooth pinion, stock blades, 10 cell 2400 MaH pack. The motor is getting HOT. It causes pain to touch, and in the last flight, I could kinda smell somthing funny (and it wasn't my own odor for once) Why is this. Many people have used this same setup with nothing but god to say about it. I am only hovering the thing for now, nuthin fancy. Is there any heatsinks that I can buy for it? Anything else I can do to lower the temp?
Maybe I am too sensitive about the motor heat, how hot can they get??
rdogg32 is offline Find More Posts by rdogg32
Old Jul 13, 2002, 05:17 PM
Eco8gator is online now
Find More Posts by Eco8gator
United States, FL, West Palm Beach
Joined Jun 2001
Hello
What is your pitch and throttle curve?
Try setting it up so that is hovers at a higher throttle setting and a lower pitch.
Carlo
Eco8gator is online now Find More Posts by Eco8gator
Old Jul 13, 2002, 05:20 PM
rdogg32 is offline
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
Hmmm... That sounds like it may work. The motor would be doing less work, more rpms. I take a look at the curves (again!) and try that out.
Old Jul 13, 2002, 09:12 PM
rdogg32 is offline
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
Well, Just got done flying again, and the motor was very hot again. The air temp has dropped below 80, and the sun is no longer out, so I am needing to look for other reasons. I will try to edit the curves again. Could dropping to a 22 tooth pinion help at all? I thought that elevation may matter, I am at 3500 feet. Could my headspeed be to high? It was nearing 1550? hmmm....
Old Jul 13, 2002, 10:05 PM
Joined Jun 2001
Hello
How hot exactily is your motor getting? It is normal for a motor to get warm after a flight, but if your motor is getting so hot that if you spit on it and the spit sizzles, then something is wrong.
Just let it cool to ambient temp(takes maybe 10 mins) and fly, dont worry about the temp unless it is really, really hot.
I think I know the smell you are refering too. My Aveox put out the worst motor smells(it know is is not just limited to mine every one I have encountered has the "Aveox motor smell" after a flight). My Mega had its own smell too. My Hacker(B50-11L) doent smell at all after flights but it never gets hot.
Oh, 1500 is not that high, I'd say that it is a good HS. I run mine over 1600, and sometimes at 1900 but only for a little. The cyclic and climb rate is plain awsome.
Carlo
Old Jul 13, 2002, 10:38 PM
rdogg32 is offline
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
Spit Sizzles...
Well, I haven't chucked a lugi on my motor latley, but I don't think that it gets so hot that it would sizzle the spit. The smell isn't that bad, but I guess that I am a worry wort. Smell are just ussually a bad thing, but if it won't damage my motor, then I guess I shouldn't worry. I am done flying today, but am going to take it out tomorrow, and I will a drop or two of water on the motor after the flight.
The headspeed just before take off was about 1700!, but then the pack died a little, and that sank to about 1600. I realize that isn't too much, but for the motor combo in the heli I expected a little less. I think I should throw a little more pitch in there, cause I don't have the climbing power that I expect.
OK, now to make an ass out of myself: Is it pronounces Eeeko, or more like Echo?
Old Jul 13, 2002, 10:54 PM
Chachin is offline
Find More Posts by Chachin
Powered by ThunderPower
Chachin's Avatar
United States, FL, Cocoa
Joined Sep 2001
I think it's Echo.
I'm using your same combo, it's not supposed to burn you or make water sizzle.
Like Carlo mentioned, it's also important to let the motor rest in between flights.
I'll take a closer look at my motor temp tomorrow after I fly.
Chachin..
Chachin is offline Find More Posts by Chachin
Old Jul 13, 2002, 11:06 PM
rdogg32 is offline
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
Well, I think mine is far from making water sizzle (thank goodness)! The best way that I can descibe the heat is this: It doesn't feel good to touch it, you can touch it lightly for a second or two, but then it starts to hurt. Firmly squeezing it for more than two seconds would not be fun, but brobably wouln't leave a burn!
Man, I should borrow one of those temp guns or somthing! It's almost comical! "Well, I can't cook top ramen on it, but I could sear a veal roast..."
Old Jul 13, 2002, 11:27 PM
Chachin is offline
Chachin's Avatar
Joined Sep 2001
Heatsinks
As far as heatsinks, you have two options... that I know of :
Option 1: This is my favorite just because it's anodized blue and it plain looks cool. I have heard of people using it on their Eco-8's motors at the Ikarus BBS as well. But it's $12 bucks! Snaps right on. Check it out:
http://www2.towerhobbies.com/cgi-bin...1&I=LXTG84&P=7
Option 2: This one is made by Traxxas. It's black and wide. It's usually recommended by Fred. This one I haven't used, but it's said to work well. Very attractive price... under $5 bucks! Also snaps right on. Check it out:
http://www2.towerhobbies.com/cgi-bin...1&I=LXJD62&P=7
Comments:
I'm not using either heatsink right now for my current Jeti/Phasor combo setup because I don't think it's necessary under my circumstances. You can tell when your motor is overheating or simply hot. I wish I had a temp gun as well so that we can compare .
Again, I'll post more comments tomorrow after I fly.
Good luck!
Chachin..
Old Jul 14, 2002, 02:50 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
You may need to check the setup too. Something could be tight.
Also, be sure not to over-rev the motor. Jetis don't like to turn fast, but all motors like to unload.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jul 14, 2002, 05:14 AM
k_ogre is offline
Find More Posts by k_ogre
United States, WA, Sequim
Joined Apr 2002
karma
sounds like karma to me
k_ogre is offline Find More Posts by k_ogre
Old Jul 14, 2002, 10:34 AM
rdogg32 is offline
rdogg32's Avatar
Corvallis, Oregon
Joined Apr 2001
I think I just need a heat sink. Maybe I am babying it a little too much.
I added back in a little more pitch, because it was flying better that way.
need help with motor rcairmike Parkflyers 3 Nov 05, 2002 03:30 PM
Desperately need help with motor interference problem Ken Lapointe Electric Plane Talk 8 Jun 22, 2001 06:40 AM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
E.E. Lightning-pusher scale electric need help with motor/battery etc bipeflyer Scale Kit/Scratch Built 5 May 01, 2001 05:33 PM
E.E. Lightning-pusher scale electric need help with motor/battery etc bipeflyer Scale Kit/Scratch Built 0 Apr 29, 2001 05:02 AM
