Old May 08, 2006, 01:26 PM
kmp647 is offline
Find More Posts by kmp647
marshall , va
Joined Jul 2003
Groovy50 pattern plane video
http://media.putfile.com/Groovy50
Finally able to post some video of my WM Groovy50 conversion. My brother shot this video, conditions for filiming were not the the best.
53" span
It uses an axi 4120/18 on 5s3700 polyquest battery, phx60, and a 15x10e prop ~1,000 watts, at 59 amps , auw is 5lbs10oz
Kevin
kmp647 is offline Find More Posts by kmp647
Old May 11, 2006, 05:09 PM
kris1 is offline
Find More Posts by kris1
kris1's Avatar
South Devon UK
Joined Aug 2002
Looks good Kevin,
I guess you are running 170W per pound. I have the same aircraft and was planning to use a 4120/14 on a 4 or 5S 3700. I only have 4s at the moment, which I really don't think is enough. What duration are you getting on th 5S packs
Cheers
Kris
kris1 is offline Find More Posts by kris1
Old May 11, 2006, 05:53 PM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
My ES10 is about the same size as the Groovy 50 and being purpose build electric is quite a bit lighter. Nevertheless it was just a atouch underpowered on 4S. 5S is good with an outrunner on these .40.50 pattern planes particularly when drawing strong uplines or for fast low passes.
davidleitch is offline Find More Posts by davidleitch
Old May 11, 2006, 06:36 PM
kmp647 is offline
marshall , va
Joined Jul 2003
Thanks Kris, I am getting 6/8 minute flights depending on wind and throttle use.
It has very strong vertical and throttle response.
Kevin
Discussion New pattern plane- Möbius ( Video) furyflyer2 3D Flying 351 Sep 23, 2006 05:29 PM
Watt-Age Super 400 F3-EP Micro Pattern Plane Thomas Manson Foamies (Kits) 0 Jul 30, 2001 04:47 PM
Wedgie (plane) video? dave_lilley Life, The Universe, and Politics 17 Jun 06, 2001 08:11 AM
Wedgie (plane) video? dave_lilley Foamies (Kits) 5 Jun 05, 2001 11:38 AM
E-Factor electric F3A pattern plane ShredAir Sport Planes 0 Apr 20, 2001 11:06 PM
