Old Jul 13, 2002, 01:17 PM
drliu is offline
Find More Posts by drliu
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Smallest, lightest radio transmitting color still/video camera?
The title says it all... I'm looking for the lightest, smallest video camera (or digital still camera) that can be mounted onto a submicro RC plane (like the Skeeter or Microtaxi). It will need to transmit by RF and ideally to have a receiver that can interface either with a laptop or with an NTSC video processor. Any suggestions?
David
drliu is offline Find More Posts by drliu
Old Jul 15, 2002, 09:27 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Sorry I could not find the link but emailthis guy. Ben [bendelta@netvigator.com]
He sells a nifty little system for $100
poobs is offline Find More Posts by poobs
Old Jul 16, 2002, 06:04 PM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
Also check out BlackWidow AV
(The 50mW unit)
joemi is offline Find More Posts by joemi
Old Jul 18, 2002, 11:43 PM
yb2normal is offline
Find More Posts by yb2normal
Frequent User
yb2normal's Avatar
Broomfield, CO, USA
Joined Jan 2001
And when you are ready to fly the plane by RPV, joemi can hook you up with some video glasses.
I bought a pair from him and fly my Wingo via RPV. A total rush
Bill
yb2normal is offline Find More Posts by yb2normal
Old Jul 19, 2002, 04:37 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I can vouch for the 50mW blackwidow AV tx and the receiver they work great. I have built a dc-dc that weights 0.3g and provides easily enough current to run the camera and tx. Using this with one of my 140mA lithium poly batteries means the pack weight is just 3.9g less wires.
Cheers,
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jul 19, 2002, 08:44 AM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
wow
Graham,
Would it be possible for me to purchase the DC-DC converter from you? Which components exactly did you use from Black Widow? (I assume the 50 mw TX, camera, and RX; if so how much is the total weight of the LiPoly, your DC-DC converter, and the camera?)
David
Old Jul 19, 2002, 10:20 AM
Sticky Shepherd
Oxford/England
Joined May 2001
David, I'm hoping to make the converter available for sale in the near future, but I'm sure I can build you a one off. I have the blackwidow 50mW transmitter and receiver but I already had a camera so I'm using that. I think from memory of the website the transmitter is 15g but I don't know about the camera. To be honest if you want to carry a camera in a lil skeeter then would would probably need a smaller tx. I then think you would need to modify the camera, removing all the unessesary plastic. The cameras are basically a circuit board with a cmos/ccd detector array on top, then there is a lens in front of that to image what you want to see onto the sensor. So to make it light you would take out the sensor pcb (Very carefully) and make a very light weight assembly to hold the lens a given distance from it, probably found by experimentation, i.e. move it until it's in focus. This procedure is probably not fot the faint hearted.
For bigger models such as servo based slow/park flyers I think a straight camera would be ok, especially with the light weight battery pack.
I bought my equipment to go in a slope soarer but you have got me thinking.
Graham
Old Jul 19, 2002, 01:01 PM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Thanks Graham
My Holy Grail has been modified to include aerial videography (now living room aerobatic flyer with live video camera), so I may take you up on that offer. My back of the envelopes put the total weight of the (unmodified) TX, battery, and camera at 20-30 grams, so I agree for sub-micro videography we would need to strip down the TX and camera. Perhaps I'll try this once I work out a good bi/tri-plane version of the skeeter and do some model experiments by loading up the bi/tri plane with up to 30 grams of weight.
-David
Old Jul 20, 2002, 01:38 PM
Sticky Shepherd
Oxford/England
Joined May 2001
look what you made me do
I decided to see if anything I had said was actually true.
I stripped down my camera, here are the weights:
Lens assembly: 5g
case: 3g
circuitboard/cmos sensor: 1.3g
lens cover: 0.3g
So if you loose everything but the board and add a light weight plastic lens assembly. You loose about 8.1g in weight. I reckon you could get the camera working at under 2g.
Here's a pic of the bits
Old Jul 20, 2002, 01:39 PM
Sticky Shepherd
Oxford/England
Joined May 2001
here is the sensor board, sensor side
Old Jul 20, 2002, 01:40 PM
Sticky Shepherd
Oxford/England
Joined May 2001
and the back
Old Jul 20, 2002, 01:46 PM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Wow Graham; that's great work. I'm not sure I have the technical expertise to be able to do as you suggest, but I will try it if I get that far in my Quest.
As a related aside, it occurs to me that if someone with a lot of expertise at micro RC and an electrical engineering in general (say you, for example) were to create a minimum-weight camera and TX from stripped down components, you could probably a) sell them for some profit, and b) make a lot of micro plane enthusiasts very happy
-David
Old Jul 20, 2002, 01:49 PM
Sticky Shepherd
Oxford/England
Joined May 2001
Here is my high tech zero calculation lens anaylsis system. The square drawn on the piece of card is the same size of the sensor. The lens (from a dead camcorder) is held by bluetak and moved until an image of the backgardn can be seen on the card. You can also see a fairly nice image of my angle poise lamp. This lens aint the right one obviously as the image is pretty big compared with the sensor size. Might need two lens, the experiments will continue.
Graham
Old Jul 20, 2002, 02:02 PM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
nice work
If you can get that system down to sub-micro/LiPoly-compatible weight (say 10-20 grams for camera and TX), I'll be first in line
Do you have a way of manufacturing (in small batches) plastic housing parts?
-David
Old Jul 20, 2002, 03:10 PM
Sticky Shepherd
Oxford/England
Joined May 2001
would be nice to make a system like that, the main problem is the transmitter, the effort involved in the design would be considerable. If I could get hold of the smallest type sometimes seen mounted directly to the back of the camera it might be possible to lighten it. Probably by making a light weight case that still has a metallic layer to prevent interference. Aluminised mylar bag?
As for lightweight housing, I did buy a book on making a homemade injection moulding machine a while back but never got any further with it.
Need to think about how to do it, hmm....
Graham
KPC650 Hi-Res 12v Color CCD mini video Camera for A/V/P CactusJackSlade Aerial Photography 8 Sep 06, 2005 04:31 PM
For Sale KPC650 Hi-Res 12v Color CCD mini video Camera for A/V/P CactusJackSlade Aircraft - General - Radio Equipment (FS/W) 4 Aug 12, 2005 05:02 PM
Sold FS: NIB EYECAM 2.4GHz Color Wireless Video Camera RTF Setup kookboy Aircraft - Electric - Airplanes (FS/W) 3 Jun 11, 2005 08:13 PM
Where to get the smallest video camera? crux12 Aerial Photography 6 Feb 19, 2004 02:08 AM
$50 for 2000ft range color video camera. Patrick Plawner Aerial Photography 97 Nov 26, 2003 08:32 AM
