Old May 04, 2006, 08:03 PM
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
Where can I find a set-screw style 3mm prop adapter?
Where can I find a set-screw style 3mm prop adapter? Not 3.2mm. I've looked at all the e-stores I thought may have them. Nothing yet. Getting kind of tired of collet type adapters not coming off so switching to set-screws. Thanks.
Matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old May 04, 2006, 08:09 PM
one game away...
Willoughby, Ohio
Joined Apr 2004
Found. maxproducts.
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Go here: http://www.maxxprod.com/mpi/mpi-291.html and look at the ACC364.
Brian
wattsup_kz is offline Find More Posts by wattsup_kz
Old May 05, 2006, 05:39 AM
Wallingford, Ct
Joined Sep 2001
Set screws are a poor way to attach anything to a shaft. Collets are better as you have noticed. Set screw adapters do not run as true either. Many people use set screw adapters so I guess they are good enough.
Al M is online now Find More Posts by Al M
Discussion Where can I find a 3mm. m6 prop adpter?? morphs Power Systems 13 Aug 23, 2007 05:02 AM
Discussion Where can I find foamie plans for a trainer style plane stafphoto Foamies (Kits) 4 Mar 21, 2006 01:09 AM
Where can I find 3mm .5 module pinions? WeatherB Micro Helis 2 Mar 06, 2005 10:48 AM
where can I find a 5x4.3 or a 4.9x4.3 prop that is NOT a push-on zagi prop? I FO nut Electric Plane Talk 4 Jul 11, 2003 09:51 AM
Where can I find a Motor & Prop tutorial? mitchydkid Parkflyers 1 Apr 29, 2003 01:44 PM
