Old May 04, 2006, 06:52 PM
AeroNut45 is offline
Find More Posts by AeroNut45
AeroNut45's Avatar
Australia, VIC, Keysborough
Joined Jun 2004
Idea
Building tips and tricks ( please post yours here
I will start the ball rolling here, with one of my own tips.
To make ribs for a balsa wing can be rather frustrating and time consuming.
This method will help speed things up a bit, and will stop the need to sand your leading edge to shape.
Once you have produced your template rib, I made this one in ply for strength, you drill a sheet of balsa with a 3mm drill bit. Then push your template rib into the predrilled hole with the carbon tube at the leading edge of your rib, and cut around the template with a scalpel.
With a little bit of practice you will reproduce a precise replica of the template with no need of sanding.
The advantage with this method is , that your ribs will have perfect alignment with the leading edge.
Good luck with your project.
Knut
AeroNut45 is offline Find More Posts by AeroNut45
Old May 04, 2006, 06:59 PM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
If you need to put a curve on balsa so that it'll fit for an application, quite often the curve can be achieved by just wetting one side of the balsa only.
Inflexo is offline Find More Posts by Inflexo
Old May 04, 2006, 07:00 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Knut,
Just one question - will you mind if I put these tips/hints into a page on my site too?
Paul.
Old May 04, 2006, 07:03 PM
AeroNut45's Avatar
Joined Jun 2004
Originally Posted by pldaniels
Knut,
Paul.
Thats fine with me, but it would be nice if there would be an aknowlegment who submitted it.
cheers
Knut
Old May 04, 2006, 07:06 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
aileron torque tube connetorsin confined spaces
Whislt construting the the second WW2 for our Profile combat scale day I thought I'd try a aileron connection to the servo that was not only simple but had a secondary effect and that was of a servo saver .
SteveW
steve wenban is offline Find More Posts by steve wenban
Old May 04, 2006, 07:27 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
cheers
Knut
That's fine - it would have gone without saying (the crediting).
Paul.
Old May 04, 2006, 07:30 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
SteveW,
Your method works well on side-mounted aileron servos too...
Old May 04, 2006, 07:40 PM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
More of a money saving tip.
If you use a lot of epoxy, buy it in 1-5 litre quantities from a distributor... much cheaper! Storing it in a fridge will make it last forever if tightly sealed (epoxy is very hygroscopic and the inside of a fridge can be a humid environment)
Go to the $2 shop and grab 2 sauce type squeeze bottles. Fill 'em up and keep them in the cupboard. It's then easy to dispense and measure, and perfect for small to medium size jobs.
If you also use cabosil, which is very light and potentially hazardous if inhaled, fill a jar with with a small quantity of acetone, put on your mask and fill the jar up with cabosil. Keep stirring until it's all dissolved into a thick slurry. You can now add it to epoxy whenever you need it, without the worry of breathing it in.
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old May 04, 2006, 07:50 PM
AeroNut45's Avatar
Joined Jun 2004
While we at it, here is a refinement. I made the hinge before putting it on the pushrods. If the pushrod is not exactly the right length, this allowes you to adjust it. once you are happy with the setup you run a drop of CA on the edge, where the carbon exits the alu tube.
good luck Knut
Old May 04, 2006, 07:59 PM
Joined Dec 2003
Do you run the silicon tube right across both connection or just at the end of each rod I found that under combat loads the heat shrink tube is not up to the task by its self as it work hardens and gives up,,, but the full lenght of 1.6 mm dia with the .5 mm bore tube run fully between the 2 rods works extrememly well and its strong as well,, plus the silicon will not work harden.
SteveW
Old May 04, 2006, 08:02 PM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
How many of us have used plastic teaspoons for making air scoops?
glydr is offline Find More Posts by glydr
Old May 04, 2006, 08:10 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Okay, teaspoon for scoop is a new one for me!
Old May 04, 2006, 08:29 PM
glydr is offline
glydr's Avatar
Joined Feb 2004
Not a building tip strictly speaking...
When I put my receiver into a new plane and want to route the aerial through the fuse from the tail, I:
1. slip low diameter heat shrink tube (a long one) in until it reaches the radio bay,
2. push the aerial along the heat shrink until it won't push any more, and,
3. pull the heat shrink out the tail with the aerial within.
If you run into a former during step 1 you can twist the tube to help get past the obstacle.
Old May 04, 2006, 08:33 PM
Model Bender
Joined Jun 2004
Brilliant idea!
Another one (not mine) The clear plastic packets commonly used to hold tubes of glue can often be trimmed up and used as wing servo covers.
Old May 04, 2006, 08:45 PM
glydr is offline
glydr's Avatar
Joined Feb 2004
I like to have a packet of Bamboo skewers on hand in the workshop... last night I used lengths PVA'd to tight fit holes in a liteply motor-mount as anchors PVA'd into an EPS fuse.
Yippee! Helicopter building tips and tricks - class 101 Happymcc Micro Helis 25 Oct 29, 2008 12:40 AM
Question Am I the only one who loves crash stories? Post yours here! arclite5 Micro Helis 11 Sep 12, 2006 12:52 AM
Discussion Wing building tips, tricks, advice! toyotatruckin Flying Wings 42 Feb 18, 2006 05:23 PM
Question accomplished leccy flier wants to try ic- tips and tricks please rcminiman Beginner Training Area (Fuel) 5 Oct 10, 2005 05:05 AM
Independence Day Flight Reports-Post yours here kansascloud Parkflyers 33 Jul 07, 2005 02:38 AM
