Old Oct 12, 2006, 04:01 AM
tomasjo is offline
Find More Posts by tomasjo
Mr. Mullins
Joined Jul 2006
Excellent Tim, thank you.
Do you use 6mm depron? Also wondering wich glue to use? CA medium og hot gun?
Tomas
Originally Posted by tim_mellor
Hi Tomas, Malves and all,
try this conversion to A4 tiled of version 4. I havn't printed it but it should be OK. Just make sure you print it at 100% and don't allow adobe to shrink it to 96% like it does to fit it on the page.
Tim
tomasjo is offline Find More Posts by tomasjo
Old Oct 12, 2006, 04:05 AM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Not that I have built this one YET it depends if you are building for inside F3P or outdoor lightwind fun? Also what motor/battery combination are you thinking of using?
regards
Tim
tim_mellor is offline Find More Posts by tim_mellor
Old Oct 12, 2006, 04:29 AM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
Thanks Tim
I want to built it for outdoor flying, light breeze.
Wanted to try out a Hyperion 1200mAh pack with 50gr motor.
Do you think it will be to heavy? I also have Flight Power 800mAh 2S pack.
Do you have some tips for how to make the motor mout.
Sorry, I am new to builing depron models
Tomas
regards
Tim
Old Oct 12, 2006, 05:06 AM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
As you want outdoor best go for the 6mm for durability, it wll also simplify the bracing and spars needed.
You could still use the 2S800's you have and look at a 30-40g motor to suit. This should keep the overall weight down around 200g. If you start looking at 50g motors and 1200's you could finishup closer to 300g which won't be as nice to fly.
Also if you are flying off anything not perfect, drop the wheels and install a hard 6x6mm balsa skid on the bottom of the body.
Regards
Tim
Old Oct 12, 2006, 05:40 AM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
OK, Tim
Thank you for your advice.
Tomas
Regards
Tim
Old Oct 12, 2006, 08:07 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Just remember to grab the Foam Safe CA, and Kicker works too. It is better with the thicker stuff. I have seen the thin foam safe ca melt foam when used with kicker. Also, blenderm tape is perfect for hinges, and is lighter in weight that packing tape. Enjoy the build!
TeamTEOR is offline Find More Posts by TeamTEOR
Old Oct 12, 2006, 08:25 AM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
Thanx for the tile plans, Tim. That will sure help some ppl here.
I use UHU Creative glue for the wing spars and foam safe CA for everyting else.
When using kicker, use a lil as you can. I usualy use a q-tip to apply it. During the hardening process, CA glue generates heat. If you use too much glue and too much kicker, the heat will be more intense because of the accelerated dyring, and melt the foam.
Mine weighs ~160g and it does really good in light breeze. I've even flown it in 10mph winds. You may have to adjust the cuts in the plans for 6mm.
Malves is offline Find More Posts by Malves
Old Oct 12, 2006, 10:56 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
even better than tape is floppy disk hinges.
Chris
ChrisBowker is offline Find More Posts by ChrisBowker
Old Oct 12, 2006, 11:40 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
Floppy disk hinges?
...by which you mean pieces of a 5 1/4" disk?
Aio_1 is offline Find More Posts by Aio_1
Old Oct 12, 2006, 12:35 PM
Malves is offline
Joined Jun 2004
3 1/2" works too.
Old Oct 12, 2006, 02:42 PM
usedhippo is offline
Find More Posts by usedhippo
If u wind it it will run!
usedhippo's Avatar
Joined May 2006
floppy disks are the best
usedhippo is offline Find More Posts by usedhippo
Old Oct 12, 2006, 03:15 PM
Malves is offline
Joined Jun 2004
I also like the "barn door" type hinges. Less tape, less weight, more throws, resistance free.
Old Oct 12, 2006, 10:07 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Hi Malves,
I need to spend a little more time playing with my chopping method for plans. I would like to add alignment marks to make putting them back together again. If I sort it out as a method using freeware I will do a how to here.
For hinges I have just been using 3M Diamond Tape (glorified stickytape) it seems to handle UV really well and is pure clear.
Tim
Old Oct 12, 2006, 10:40 PM
Daniel Z is offline
Find More Posts by Daniel Z
Daniel Z's Avatar
Joined Dec 2004
floppy disks rules! and the rest of it can be used to make control horns!
Daniel Z is offline Find More Posts by Daniel Z
Old Oct 13, 2006, 12:36 PM
p.lafors@planet. is offline
Find More Posts by p.lafors@planet.
The Netherlands
Joined Oct 2006
Hi Malves,
As I was searching the internet on Depron, I saw your conversation about the Yak-54.
as I am totally new on indoor and park flyers, I would like to ask you the following:
Can you tell me what configuration (motor, prop, lipo battery, receiver, servo's etcetera) you are using on this plane.
I'm flying model airplanes for more than 25 years now, but I want to begin with indoor/park flying.
Nobody at our club has any experience with these kind of planes, so Iím "investigating" the possibilities.
Thanks so far.
Regards Paul La Fors (the Netherlands)
p.lafors@planet. is offline Find More Posts by p.lafors@planet.
Question Anybody have any Yak 54 plans? bamm 3D Flying 33 Dec 09, 2012 06:40 AM
Sold NIB Ultra RC Yak 54 (.40 sized) sukhoi26mx Aircraft - Fuel - Airplanes (FS/W) 0 Nov 05, 2005 08:34 PM
On the drawing board... Brian Courtice Slope 19 Jan 18, 2005 05:59 PM
GWS: Jets on the Drawing Board? Carter Electric Ducted Fan Jet Talk 0 Dec 16, 2002 10:07 AM
