Old Jul 24, 2006, 09:50 AM
3dflyindan is offline
Find More Posts by 3dflyindan
PB #2212
London, England
Joined Dec 2005
killi thanks for that mate i have flown 4 of them now and love them so much
Malves - email me a copy of the plans plz pal u have me address i want to make one but a tad bigger so that with my gear it wont be a brick lol
dan
3dflyindan is offline Find More Posts by 3dflyindan
Old Jul 24, 2006, 11:33 AM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
Ok, here you go v.3. 35 1/4" WS and 29" long. Modifications to this new version:
- longer fuse
- increased wing area
- increased rudder area
- slightly bigger ailerons
Enjoy!
Malves is offline Find More Posts by Malves
Old Jul 25, 2006, 10:05 PM
Malves is offline
Joined Jun 2004
Pics...
I'll try to check the weight tomorrow. It should be around 150-155g with a TP4803s, for a 3-3.1oz/sq.ft.
This plane should be perfect for aeromusicals.
Old Jul 26, 2006, 07:10 PM
Malves is offline
Joined Jun 2004
Ok, I've put 2 flights on it today and it flies lighter than the previous version. I don't recommend putting those holes on the depron stiffeners. They are not as stiff as if the holes were not there, and that causes tail twisting. Maybe, if the holes aren't that much together and smaller it could be better, but I say leave it.
EDIT: I've replaced the depron strips last nite with no holes and took it outside at lunch time today. What a difference! I'll see if I can weigh it today.
Old Jul 31, 2006, 01:47 PM
Brummeh is offline
Find More Posts by Brummeh
"How old are you?"
Brummeh's Avatar
Brum, U.K.
Joined Feb 2006
A week on and my full fuse is all readt to go, it is 145 g without battery or lg...
27g micro cyclon, 2s400 20c pack, 3 x 5g servos, 10a esc, 5ch rx
Lets hope it flys :P
Brummeh is offline Find More Posts by Brummeh
Old Jul 31, 2006, 02:43 PM
Malves is offline
Joined Jun 2004
Sweet! You may wanna add a lil CF "post" right at the crossing of those CF struts.
Old Aug 01, 2006, 01:55 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
That's very nice.
Aio_1 is offline Find More Posts by Aio_1
Old Aug 01, 2006, 04:52 AM
Mister UHU is offline
Find More Posts by Mister UHU
Mister UHU's Avatar
London UK
Joined Dec 2005
YAK-tastic !
Mister UHU is offline Find More Posts by Mister UHU
Old Oct 03, 2006, 09:21 PM
Malves is offline
Joined Jun 2004
Well, here's version 4 of the Yak. This will most likely be the last update I'll do to it. I really like flying this plane and I can't wait for the indoor season. Actualy, I am building one right now for this next Sunday, when there will be an indoor meeting in a nearby city.
If you build it right and with light weight equipment, you can get this plane to 140-145g (we're talking about a 35 1/4" wing span). Mine with 7.7g servos weighs ~155g. It won't be only light, but also very strong and with very good stifness for a foamy. It's a great plane for freestyle.
Changes from v.1 thru v.4 were:
- bigger ailerons
- CF on the TE
- increased fuse area
- longer fuselage (from 27" to 30")
- little modification to the fuselage design (v.4)
Have fun and enjoy!
Old Oct 04, 2006, 12:00 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
nice and simple my friend. Got to love a good set of plans. What are you thinking about for a power system for the new one you are building?
TeamTEOR is offline Find More Posts by TeamTEOR
Old Oct 04, 2006, 07:55 AM
Malves is offline
Joined Jun 2004
Thank you. Same setup I've been using - Park 300, 8x3.8SF, TB-9, TP4802s. I am waiting for the Park 250, so I can replace the 300 and loose ~10g. I am also thinking about replacing the S3110 with D-47.
I am still building mine, and it should be ready in 2-3 days (don't have much time to put on it). I'll have pics then.
Old Oct 04, 2006, 08:10 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Hmmmm.. Do think this will work? Could run it on a 2s700 pack with a 1047? I have one laying around doing nothing. I'll send out for a couple of 5gr servos or find a set of Picos laying around here.
2406-32 1150kv outrunner brushless direct drive motor
Size : Dia 28 mm x L 23 mm
Shaft Size : Dia 3 mm x L 9 mm
Screw Size : M3
Weight : 33 g
KV : 1150
IO : 0.8A (10V)
Efficiency : 70%
Propeller Li-po Battery Current Thrust
1047 2s 6.8 A 310 g
8 x 3.8 3s 6.4 A 363 g
8 x 6 3s 7.8 A 340 g
Old Oct 04, 2006, 10:16 AM
Malves is offline
Joined Jun 2004
Yup, that setup should work fine. That's more than enough thrust for it.
Old Oct 12, 2006, 02:07 AM
tomasjo is offline
Find More Posts by tomasjo
Mr. Mullins
Joined Jul 2006
Hi there
I really like your YAK 54 and going to build it.
Just wondering how I print it out from PDF to right scale with tile?
Tips?
Tomas
Originally Posted by Malves
Thanx, bro.
Here is the plan for the Yak-54. This should be final. I modified the wings a lil with more area and bigger ailerons. Adjusted the cut on the fuse where the stab/elev goes in. Adjusted the elevator for more rudder throw. Broke the x-section in more parts to put 2 CF spars on the wing.
I would start with the CG at around 2 3/4" from LE and go from there.
I'll be putting a new one together over the weekend so I can check the adjustments I've made to it.
Enjoy!
tomasjo is offline Find More Posts by tomasjo
Old Oct 12, 2006, 03:51 AM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Hi Tomas, Malves and all,
try this conversion to A4 tiled of version 4. I havn't printed it but it should be OK. Just make sure you print it at 100% and don't allow adobe to shrink it to 96% like it does to fit it on the page.
Tim
tim_mellor is offline Find More Posts by tim_mellor
Question Anybody have any Yak 54 plans? bamm 3D Flying 33 Dec 09, 2012 06:40 AM
Sold NIB Ultra RC Yak 54 (.40 sized) sukhoi26mx Aircraft - Fuel - Airplanes (FS/W) 0 Nov 05, 2005 08:34 PM
On the drawing board... Brian Courtice Slope 19 Jan 18, 2005 05:59 PM
GWS: Jets on the Drawing Board? Carter Electric Ducted Fan Jet Talk 0 Dec 16, 2002 10:07 AM
