Espritmodel.com Heli Air
Old Jul 21, 2007, 11:56 PM
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
Originally Posted by helitaiwan963
O yea, for the plans? I was wondering what those two long strips are for?
Eric
yeah me too, i built a prototype V4 with paper and the ice cream sticks to see how it looks, turned out pretty well, now i just need 3mm depron
brian94066 is offline Find More Posts by brian94066
Old Jul 24, 2007, 09:01 PM
Joined Jun 2004
Check some pics in my blog page 2 of the finished model. You'll figure it out what those strips are for. They go glued on the fuse at a 45º angle on each side to make it rigid.
Malves is offline Find More Posts by Malves
Old Aug 21, 2007, 01:07 AM
charge em up!
Zamfir's Avatar
Colorado
Joined Jul 2007
Very nice blog. I have only made epp planes so far and this 3d stuff is a blast! I think a depron is next and I love the yak. Good show Malves. What is your suggestion for a reciever? I picked up a 30 g Flyware 220-1300 Motor and want a plane to try it in. Do you think it will work on your version 4 YAK? Is a Blue Arrow BA-TS-3.6 Micro Servo enough umph for the control surfaces? Sorry for all the questions but this blog has my mind racing!
Zamfir is offline Find More Posts by Zamfir
Old Aug 22, 2007, 01:44 PM
Joined Jun 2004
Hi Zamfir,
Yes, the 220-1300 will work just fine with the Yak. I am not familiar with the BA-TS 3.6. For Rx I'd go with the Berg 4.
Old Aug 24, 2007, 04:40 PM
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
can you post the pdf plane in tile form.or can someone show me how to tile pdf things I really want to build your yak becuse it looks sooooo simple to buid and awsome. this will also be my first 3D plane i just want to learn how 2 hover
foam and tape is offline Find More Posts by foam and tape
Old Aug 24, 2007, 05:55 PM
Joined Jun 2004
I think someone did that in this thread already. I am sorry, but I don't have a way to do that.
Old Aug 24, 2007, 06:12 PM
beavercreek,ohio
Joined Jan 2007
oh, never mind i found them. now i need some depron have 2 wait till tomorow
Old Oct 12, 2007, 04:53 PM
BrunooO's Avatar
Brasil, São Paulo, Lins
Joined Jul 2007
I would like to know if this plane is good with 4mm depron and this motor:
https://www.unitedhobbies.com/UNITED...t=2069&image=2
Because here in my city I dont have 3mm depron...
If someone has already tried to do it say how it fly here!
BrunooO is offline Find More Posts by BrunooO
Old Oct 12, 2007, 05:42 PM
Do it for fun
Aio_1's Avatar
Kilkenny, Ireland
Joined May 2002
I've never heard of 4mm depron but if it's the same material it probably does not weigh much more than the 3mm stuff and will probably work fine. Depron is not the same density throughout the sheet. Most of the mass is near the surface. As a result 3mm depron is not a lot heavier than 2mm depron and it's likely that the same is true for 4mm.
Aio_1 is offline Find More Posts by Aio_1
Old Oct 12, 2007, 06:50 PM
BrunooO's Avatar
Joined Jul 2007
Ok,
I´ll try to make this plane with my depron(i live in brazil and here our depron is heavier than american´s), but i will try to make it with about 100~150g
When I finish the plane I post the results here
Old Oct 12, 2007, 06:59 PM
Joined Jun 2004
With this one you'll most likely be at 140-150g. It will depend on your setup. I have plans for a smaller version (800mm) here somewhere that I got at 110g (see pic below).
I am posting a new version maybe tomorrow or Sunday. It's also a 32" plane, but longer and wider fuse (30.5"), and some work on the tail section, along with a different cut for a better build.
I am actually building it right now for tomorrow nite indoor flying.
Old Oct 12, 2007, 07:44 PM
Daniel Z's Avatar
Joined Dec 2004
Brunoo, I use that motor on a 160gms shocky with 2s460 10-12min flights with 9x4.7 prop ... strong pull out
Daniel Z is offline Find More Posts by Daniel Z
Old Oct 12, 2007, 08:25 PM
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
You lucky dawg!
Sounds like Texas life isn't so bad. Wait till winter. Are you gonna miss the snow?
MICKEL is offline Find More Posts by MICKEL
Old Oct 12, 2007, 09:37 PM
Joined Jun 2004
N O O!!!!!!!!!!!!!
Old Oct 13, 2007, 06:43 AM
BrunooO's Avatar
Joined Jul 2007
Ok malves,
I will wait the new version, when u fly it tell me if the plane is better than the other version and post the plan
Daniel Z, here in brazil I have this motor or one motor that weights 9g and for 7" propeller max. it gets about 150g of thrust and i will need to make the plane with 70g!
So, i prefer to use the hextronic motor
Question Anybody have any Yak 54 plans? bamm 3D Flying 33 Dec 09, 2012 06:40 AM
Sold NIB Ultra RC Yak 54 (.40 sized) sukhoi26mx Aircraft - Fuel - Airplanes (FS/W) 0 Nov 05, 2005 08:34 PM
On the drawing board... Brian Courtice Slope 19 Jan 18, 2005 05:59 PM
GWS: Jets on the Drawing Board? Carter Electric Ducted Fan Jet Talk 0 Dec 16, 2002 10:07 AM
