Old Nov 02, 2006, 04:10 PM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Last 4 nights down this way have been 12-18 knots onshore to windy for 3D but a couple of beers in the sun sitting on a sand dune with a glider helps make up for it.
With the CD sized motor your weight sounds good, have fun.
Tim
tim_mellor is offline Find More Posts by tim_mellor
Old Nov 13, 2006, 11:18 AM
tomasjo is offline
Find More Posts by tomasjo
Mr. Mullins
Joined Jul 2006
Hi Malves
I been flying your great YAK for some time now.
I was thinking of making it 60% of the originale size, just to play with in my back yard with 3gr servos og 300mAh 3S battery. Do you have your drawing in dwg or some other format, which I can use to down scale it? I think it's possible to scale and tile the drawing from PDF, but I don't know how ;(..
Great plane bro.
Cheers.
Tomas
Originally Posted by Malves
The Yak-54. One plane that always wanted to fly, but never had the opportunity to do so. Tonight I found some schematics of the real thing and loaded it on the Photoshop. The goal is to keep it very light, so I decided to make a plan where most of the parts are already integrated. We have been used to building planes out of many parts because that's how the manufacturers have to pack and ship it - as small as possible. But since this is just a plan, then why not just cut one big piece?
Only the LE will have CF. Size is 35"WSx28". LG will be 2 CF rods with pants/wheels made out of EPP or depron. Fishing line bracing instead of CF struts for the wings should keep it lighter, too.
Version 4 is here and pics in my blog. Just scroll down.
Full fuse version is here.
tomasjo is offline Find More Posts by tomasjo
Old Nov 13, 2006, 02:56 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Take the A3 tiled one and then select scaled printing in Adobe use A4 paper and you get 68% of full sized.
Tim
Old Nov 13, 2006, 03:25 PM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
Hey Tomas,
No DWG files. Since I've designed it with Photoshop, all I have is either PDF or PSD files. But Tim's way should work just fine. Sorry, bro.
Malves is offline Find More Posts by Malves
Old Nov 13, 2006, 03:30 PM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
ok thanks lads.
Happy days
Tomas
Old Nov 13, 2006, 05:24 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
I could scale it for an extra beer
Tim
Old Nov 14, 2006, 01:00 AM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
Would you? Thank you Tim .
Here is your beer by the by
Is it possible to get the PDF without margins and in A4 (about 68% of the originale scale)?
Is it possible to build the YAK in just 3mm depron?
Happy pappy
Tim
Old Nov 14, 2006, 07:51 AM
Malves is offline
Joined Jun 2004
That what it was designed for...3mm depron.
Old Nov 14, 2006, 05:05 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Hi Thomas,
lucky it is only a small plan as the beer offered is not very big The Wee Beasty fits onto 2 sheets of A3
Tim
Old Nov 15, 2006, 02:12 AM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
Thanks Tim
Hi Thomas,
Tim
Old Nov 15, 2006, 02:13 AM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
I knew that.... not
Sorry for the stupit question.
I'll post some info on my small YAK soon.
Tomas
Old Nov 16, 2006, 09:43 AM
Boss248 is offline
Find More Posts by Boss248
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Hi Tomas, Malves and all,
try this conversion to A4 tiled of version 4. I havn't printed it but it should be OK. Just make sure you print it at 100% and don't allow adobe to shrink it to 96% like it does to fit it on the page.
Tim
Tim..which file is the 8.5x11 tiled sheets..?
Boss
Boss248 is offline Find More Posts by Boss248
Old Nov 16, 2006, 03:14 PM
Plays with Toys
tim_mellor's Avatar
Joined Jun 2005
Hi Boss,
I never did one. Most of us in the world use metric sized paper
But if you see below and follow the same instructions for the other sized ones (don't allow shrink to fit).
Tim
Old Nov 16, 2006, 04:01 PM
Boss248 is offline
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Is there a set plans for the full fuse version..? I have not done a full fuse in a while and this looks like a good one to start on.
Boss
Old Nov 16, 2006, 04:39 PM
tomasjo is offline
Mr. Mullins
Joined Jul 2006
Hi
Just wantet to post some pictures of my baby YAK. I think it's about 60% of the original size. I think it might be a bit small, but I am going to try it on saturday, if the wind is calm.
It weighs about 170gr with all the gear and battery (800mAh 2S, little heavy).
Once again, great drawings Malves. Very easy to cut and put together. Thanks.
Happy flying.
Tomas
Question Anybody have any Yak 54 plans? bamm 3D Flying 33 Dec 09, 2012 06:40 AM
Sold NIB Ultra RC Yak 54 (.40 sized) sukhoi26mx Aircraft - Fuel - Airplanes (FS/W) 0 Nov 05, 2005 08:34 PM
On the drawing board... Brian Courtice Slope 19 Jan 18, 2005 05:59 PM
GWS: Jets on the Drawing Board? Carter Electric Ducted Fan Jet Talk 0 Dec 16, 2002 10:07 AM
