Old May 04, 2006, 12:08 AM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
Ultra light Yak-54 plans on the drawing board
The Yak-54. One plane that always wanted to fly, but never had the opportunity to do so. Tonight I found some schematics of the real thing and loaded it on the Photoshop. The goal is to keep it very light, so I decided to make a plan where most of the parts are already integrated. We have been used to building planes out of many parts because that's how the manufacturers have to pack and ship it - as small as possible. But since this is just a plan, then why not just cut one big piece?
Only the LE will have CF. Size is 35"WSx28". LG will be 2 CF rods with pants/wheels made out of EPP or depron. Fishing line bracing instead of CF struts for the wings should keep it lighter, too.
Version 4 is here and pics in my blog, page 2.
Full fuse version is here.
32" (800mm) version is here
32" (800mm) final version - with no counter weights on ailerons and one CF spar is here. Sorry I haven't posted this last year when I revised the plans. Pictures from the above link are of this version.
Malves is offline Find More Posts by Malves
Old May 04, 2006, 09:25 AM
3dflyindan is offline
Find More Posts by 3dflyindan
PB #2212
London, England
Joined Dec 2005
looks kool
dan
3dflyindan is offline Find More Posts by 3dflyindan
Old May 04, 2006, 12:16 PM
Malves is offline
Joined Jun 2004
Thanx, bro. Here's the prototype plan. I'll post the plans in pdf format, after I build, test fit, and fly it.
Old May 04, 2006, 12:25 PM
PB #2212
London, England
Joined Dec 2005
looks nice
them counter balances on the airlerons are a bit small
dan
Old May 04, 2006, 01:52 PM
3d_Crazy is offline
Find More Posts by 3d_Crazy
3d_Crazy's Avatar
Fort Worth, TX
Joined Nov 2003
I think some/most manufacturers actually cut the parts so that they go with the depron grain so each part will be as stiff as possible. Because of the size of a full sheet of depron you can't always get a full part (ie wing) from the sheet without loosing strength by going against the grain. At least that is why I do it.
Tim
e-foamies.com
3d_Crazy is offline Find More Posts by 3d_Crazy
Old May 04, 2006, 02:36 PM
PB #2212
London, England
Joined Dec 2005
thats a good idea i might try that the next time i make one
dan
Old May 04, 2006, 03:56 PM
sequagl is offline
Find More Posts by sequagl
Joined Jan 2005
Your final plan is very good!
I like the idea to keep it as light as possible!
I'll whait for the Pdf files......i have a small CD motor and small lipo battery that are whating for a plane like this!
Thanks and ciao
sequagl is offline Find More Posts by sequagl
Old May 04, 2006, 04:37 PM
Alexandre Cruz is offline
Find More Posts by Alexandre Cruz
Joined Nov 2004
I would duble the LE thicknes and use two flat carbon rods (0,5mm), it would weight almost the same as a single stronger rod, but due to inertia moment it will be much stifer and will slow down the plane a lot.
Alexandre Cruz is offline Find More Posts by Alexandre Cruz
Old May 04, 2006, 05:19 PM
Malves is offline
Joined Jun 2004
Thanx for the info, Tim.
Plans should be available this coming weekend, if it flies like I am hoping to. I just got home with some depron, CF and paint. Now I gotta go to Staples to print the plans. How big should be the counterbalance? Double the size? I've just followed the lines from the real thing.
I am not sure about double LE thickness. I've seen ppl that swear by it, and others that didn't notice any difference. I thought about it, but dropped the idea. But it's nothing that can't be done with the current plans.
Nao tem muitos brasileiros aqui no forum, ne? Acho que voce eh o segundo que vejo por aqui.
Old May 04, 2006, 05:35 PM
Joined Nov 2004
Não mesmo, a maioria deles voam planadores.....
The ideia of dubling the LE makes a much stronger wing, I would try mostly because of that. You also my also not use wheels wires or carbon rods are lighter...
Old May 04, 2006, 06:41 PM
Malves is offline
Joined Jun 2004
I won't be using wheels. LG will be composed of CF and foam. At low weight, you don't need a very strong plane. The inertia is so low, that in the event of a crash, the damage is not a big deal, if any. I've been flying a copy of the Futurion that has no CF at all, and the crashes that it suffered only required minor repair. Also, with such a low wing loading, I find it harder to crash that often. Unless you get caught by surprise when flying in 8-10mph wind, like I do sometimes.
Now, I've been thinking about the dimensions of this YAK. I tried to keep it as close as possible to the real thing using the schematics I have - fuse is just 1 1/4" longer than what it was supposed to be so I could fit the bigger elevator, thou. I've noticed that other designs have a longer fuselage. Like the Ikarus shocky is 4 3/4" longer than mine, and they share the same WS. Is there any particular reason for that?
Old May 04, 2006, 09:02 PM
Joined Nov 2004
Longer planes have more inertia on the longitudinal axel and so are more precise (yet they have more side area), the stronger wing would prevent flexing during hi-G manuvers or on rolling ones.
Old May 05, 2006, 07:58 PM
Malves is offline
Joined Jun 2004
Fitting is good. Don't mind with the hacked paint job. Spray cans are the worst to work with.
I think I need to enlarge the ailerons a lil more on the plans. It didn't come out as big as I thought. Elevator is not in place because the rudder is not cut, yet. More to come soon. I need to paint the other side of the fuse and I think I am running out of yellow paint.
Old May 05, 2006, 11:09 PM
Joined Nov 2004
Very nice painting job. Biger ailerons may be needed for 3D but I think it will perform F3P well, usually I try to keep CG to fly inverted without elevator imput, this makes your elevator veeeery sensible
Nice plane Bro
Old May 06, 2006, 12:17 AM
Malves is offline
Joined Jun 2004
Thanx, bro. Yes, that's the problem with the ailerons. I do more freestyle than pattern. Oh well, let's see how it goes. I don't even know if it will fly well, yet.
Question Anybody have any Yak 54 plans? bamm 3D Flying 33 Dec 09, 2012 06:40 AM
Sold NIB Ultra RC Yak 54 (.40 sized) sukhoi26mx Aircraft - Fuel - Airplanes (FS/W) 0 Nov 05, 2005 08:34 PM
On the drawing board... Brian Courtice Slope 19 Jan 18, 2005 05:59 PM
GWS: Jets on the Drawing Board? Carter Electric Ducted Fan Jet Talk 0 Dec 16, 2002 10:07 AM
