Old May 03, 2006, 11:07 AM
techguy is offline
Find More Posts by techguy
Long Island
Joined Nov 2003
Top Flite Elder
I am almost done building a Top Flite Elder. I put a Saito 56 in it. I now have to decide on a RX. I'm between a Hitec electron 6 or a Futaba 7 channel. Both of them are dual conversion but i'm not sure which one I should get. Any suggestions would be appreciated.
techguy is offline Find More Posts by techguy
Old May 03, 2006, 12:02 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I'd use the Electron - it's lighter and less expensive. Actually I'd use a Hitec Supreme 8.
Ivan
ivanc is offline Find More Posts by ivanc
Old May 04, 2006, 08:37 AM
rnrdoc is offline
Find More Posts by rnrdoc
Flyin' High
Staten Island, NY
Joined Aug 2005
It is on my list
So much Money (The planes that is) and so little time.
The TF Elder is another kit that is on my list. How was it to build?? Any Pictures?
Gary...
rnrdoc is offline Find More Posts by rnrdoc
Old May 04, 2006, 01:31 PM
techguy is offline
Long Island
Joined Nov 2003
The Edler was my first kit and was very straightforward. I will post pictures when I get home. Where do you fly? I live on Long Island.
Old May 04, 2006, 02:44 PM
rnrdoc is offline
Flyin' High
Staten Island, NY
Joined Aug 2005
Hey Tech...
Our club flys by the COSTCO on Richmond Ave in Staten Island. Where are U in Long Island. Have family out that way.
Gary...
Old May 04, 2006, 03:48 PM
techguy is offline
Long Island
Joined Nov 2003
I live in Farmingdale. I fly in Wantagh.
Old May 05, 2006, 07:29 AM
rnrdoc is offline
Flyin' High
Staten Island, NY
Joined Aug 2005
That not really too far. Thats like 28 off the Southern State.
On a godo day that about 45 min drive. Where is the field out there?
Will have to see if we cant get a good old WW1 Dog Fight going.
Gary...
Old May 05, 2006, 11:20 AM
techguy is offline
Long Island
Joined Nov 2003
Cedar Creek Park. You would take the Southern State to the Wantagh to Merrick Rd. Nice flying field. I didn't get a chance to post pictures last night because I was trying to finish it to maiden today. I have some pictures with me at work so i'll post them now and i'll do the rest later.
I ended up doing the maiden this morning. It flies really nice.
Old May 05, 2006, 11:56 AM
Majortomski is online now
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
May I suggest you install an additional landind gear block around the bulkhead/frame at the leading edge of the wing?
I had the original 20 sized plane back in the 90's and with the gear mounted as designed it was almost impossible to land smoothly. It was too far forward and it would bounce at the slightes bump. I turned the gear around and added another mount block at the wing bulkhead. This put the gear closer to the CG and made landings much smoother.
I've looked at the pix on TF's page, and they appear to have moved the gear back some on the 40 size but adding one wood block while building is easier than afterward.
Happy flights
T
Majortomski is online now Find More Posts by Majortomski
Old May 11, 2006, 10:38 PM
techguy is offline
Long Island
Joined Nov 2003
Thanks for the tip. So far I haven't any trouble landing. I'll keep that in mind though. I finally got around to posting the rest of the pictures. I am still waiting on the scale wheels (wire spoke), the machine gun and piliot. My LHS has them on order. I'm currently in the process of putting together the flying wires for the top and bottom of the wing. I'm also debating putting chrome monocote on the nose like the picture on the box has?
Old May 12, 2006, 02:14 PM
Joined Aug 2000
I used 'aluminum' mc, looks more like beat up metal.
Old May 12, 2006, 02:34 PM
techguy is offline
Long Island
Joined Nov 2003
I was think of that but how did you finish the edges? The 'metal' only comes down about half way on the cowl.
Old May 12, 2006, 04:31 PM
Joined Aug 2000
Basically just wraped a sheet from the fire wall forward much like a Nieuport 11
top Flite Elder 40 dds7197 Fuel Plane Talk 2 Sep 23, 2005 06:55 AM
Top Flite Elder 40 dds7197 Sport Planes 1 Sep 20, 2005 04:21 AM
FS:Top Flite Elder Biplane Wings Level Aircraft - Electric - Airplanes (FS/W) 1 Mar 15, 2004 08:46 PM
top flite elder ARC vett Aircraft - Fuel - Airplanes (FS/W) 0 Jan 20, 2004 10:20 AM
Top Flite Elder 40 with OS 40 FS Surpass Twostroker Aircraft - Fuel - Airplanes (FS/W) 1 Nov 03, 2003 06:47 PM
