Aug 03, 2001, 06:19 AM
USA, NC, Clayton
Joined Feb 2001
A-10 glitching issue...need some help!!!
Hi,
My A-10 is glitching pretty badly while motor on. It went down in the weeds today due to surging right after launch. I had 2 caps on each motor, the hitec 535 rx is in front of the battery, and the aveox a-15 esc is right behind the battery. Added the third cap...and fully extended the rx antenna(had some of it wrapped on a straw) when I got home. The esc and rx are rather close to the battery, but I moved the pack out of the plane, and it still does it. Range wise, I'm getting to about 40 ft now with one antenna section up b4 it starts, but it still isnt clean enough for me to think it's gonna be ok in the air. Antenna is routed across the top of the fuse, and (now) up to the top of one fin. How is your antenna routed? Should I try a different ESC?
