Old May 01, 2006, 08:43 PM
PlaneRacer is offline
Find More Posts by PlaneRacer
Poway, CA
Joined Dec 2003
Motor for Multiplex Easy Star?
Hi
I like to replace a EasyStar stock motor with brushless motor. But, i dont know, what size motor i need. Let say stock motor is 400 size, what size
brushless will be?
Thanks for any advise
PlaneRacer is offline Find More Posts by PlaneRacer
Old May 02, 2006, 10:22 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
There isn't really a standard set of sizes for brushless motors, so it's hard to answer.
You could look for an identical sized motor to make it easy to fit, and there are several.
Inrunners are easier to mount in the foam, but you will need to strengthen it anyway if you increase the power much.
There's a lot more variety though, so it's probably better if you think about how much power you are planning to put into it (i.e. how much you are going to spend on the batteries) and if you can live with the standard prop size limit, or if you will consider raising the motor and squeezing in a bigger prop.
RobinBennett is offline Find More Posts by RobinBennett
Old May 02, 2006, 10:36 AM
tIANcI is offline
Find More Posts by tIANcI
Xtreme Nut
Kuala Lumpur, Malaysia
Joined Oct 2005
The stock motor is a 400 sized one and I would say get another Mabuchi as there is no need to use a brushless for that plane ... brushless 400 for that can would be a motor with a can of about 28mm, just over 1".
tIANcI is offline Find More Posts by tIANcI
Old May 02, 2006, 10:45 AM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
I'm using a Mega 16/15/5 in my Easy Star. The 16/15/5 runs about the same RPMs for a given voltage as a sp400 brushed motor but does so more efficiently (i.e. you get longer flying time). The 16/15/* series of motors are drop-in replacements for sp400 motors.
Mitch
Mitch G is offline Find More Posts by Mitch G
Old May 02, 2006, 10:52 AM
sargentw is offline
Find More Posts by sargentw
"SARGE"
sargentw's Avatar
Fairfax Station, (Northern) Virginia
Joined Jun 2003
Originally Posted by PlaneRacer
Hi
brushless will be?
Check here around post 38
http://www.rcgroups.com/forums/showt...8&page=3&pp=15
sargentw is offline Find More Posts by sargentw
Old May 02, 2006, 10:59 AM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
I know several people who have used outrunners in their EZ-Stars. Simply cut back the original foam to place the prop shaft in about the same location as the original can motor, then mount a light ply plate for the outrunner mounting. Make sure the thrust line matches the original.
If you go the outrunner route, you will need a higher kv outrunner probably somewhere in the 1300kv-1700kv range (depending on battery voltage) to be able to spin a 5-6" prop fast enough.
A BL speed 400 replacement motor will need to have a relatively low kv to avoid over amping. Something in the 2000kv-3000kv range should work well (again, depending on battery). If the outside diameter is different, then you'll have to come up with a way to mount it.
Popsflyer is offline Find More Posts by Popsflyer
Old May 02, 2006, 11:56 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
I recommend the RCers Warp 4, 4 turn from www.allerc.com.
I'm using a couple of the 5 turn ones in my TwinStar II, but it has 7" props, which won't clear the tail boom on the EZ*. Going down one turn in the windings will get you into the 5-6" prop range on 8 cells. They have full datasheets that will be useful.
Personally, I'd leave the EZ* brushed, and spend that money on another plane, one that is more worthy of brushless power. The EZ* would benefit from a tad more climb, and higher efficiency, but it is not the best speed flyer on account of its undercambered wing. (makes it rise as you go faster, like it or not)
Jeremy Z is offline Find More Posts by Jeremy Z
Old May 02, 2006, 02:30 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
I fly aerial photography with a Typhoon Micro 6 with a 7x4 SF prop on 3S 1200mAh Lipo's. Gets me 3 or 4 flights of 5 minutes easilly with good altitude in the 100 to 250 meter range. So, although at full-throttle this setup pulls about 10A, I-m actually using a bit less than half of that on average. This setup will haul up a 200 gram camera, RTF weight in the 800g range or so, with a good rate of ascent, but will not go vertical. Will that work for you?
Arthur P. is offline Find More Posts by Arthur P.
Old May 02, 2006, 04:19 PM
Piledriver is offline
Find More Posts by Piledriver
almost slackin
United States, MO, St Peters
Joined Dec 2005
I mounted a bp-21 on a stick mount that raises it slightly so a 7" prop will clear the boom. I can use anywhere from a 3 cell 2000 to a 3 cell 3850 battery and I carry my CVS camera up and get incredibly long flights. The power is great for hauling the camera up in a hurry, then throttle back and glide around. When not carrying the camera it is quite alot faster than my stock easystar.
Piledriver is offline Find More Posts by Piledriver
Old May 02, 2006, 07:46 PM
Poway, CA
Joined Dec 2003
Thank You All for reply's. That info will help me a lot.
Thanks again.
Old May 02, 2006, 08:03 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
I know it can be done and with good results, however, I can't see sticking outrunners/geared motors on an EZ as a pusher. I have outrunners and geared motors on Stiks, sailplanes, 3D, etc as tractors. You put a prop on the EZ that's bigger than 6" and you wind up doing all these mods that don't make sense.
My Mega 16/15/4, TP 2100 3S, 6x4e will get the EZ and equipment up high quick and then you are ready to chop the throttle and start chasing lift or taking pictures.
If the EZ flies great with the 400 speed motor it flies 4 times better with a brushless, especially if you start flying your EZ in more advanced situations; smaller fields, over the breezy ocean, AP payloads, acrobatics.
Discussion Best motor for fpv easy star Manic Flyer FPV Talk 42 Dec 16, 2008 02:45 PM
Discussion batteries and motor for my easy star Gazzz Power Systems 7 Oct 07, 2007 09:04 AM
Discussion Can't decide on BL motor for AP Easy Star N8fromVA Aerial Photography 29 Nov 01, 2006 02:45 PM
Discussion Getting a new motor for my Easy Star AP ship randall1959 Aerial Photography 11 Jun 08, 2006 11:45 AM
