Old May 01, 2006, 02:18 PM
Chatenever is offline
Find More Posts by Chatenever
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Question
Carbon Fiber vs. Fiberglass
I'm just getting started building flat wing foamy profile models. Which do you prefer for stiffeners on the body, wing, and stab ... carbon fiber or fiberglass? Rod or tube? And how do you select what diameter tube or rod you're going to use? Most of the foamy plans I've seen don't specify.
Chatenever is offline Find More Posts by Chatenever
Old May 01, 2006, 02:40 PM
rockin' roller is offline
Find More Posts by rockin' roller
United States, TX, Dallas
I prefer carbon fiber for its stiffness over fiberglass. Look at as many plans as you can to see how other people have done it for simular sized planes. I use 4mm = 5/32in. carbon fiber tubes for planes from 28 to 40 inch wingspan built out of 1/4 inch foam.
rockin' roller is offline Find More Posts by rockin' roller
Old May 01, 2006, 03:56 PM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Is that for EPP foam or something more rigid,... or does it matter?
B
Old May 01, 2006, 07:04 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Robert: If you are going to use EPP, you should visit this thread: http://www.rcgroups.com/forums/showthread.php?t=382174
Sloper Steve, Dave North et al can fill ya in on it. FG is much cheaper....
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old May 03, 2006, 01:00 PM
B
I don't think it matters much, because that size carbon fiber is very stiff, but I build from Bluecor FFF mostly, and it is fairly ridgid by itself.
Old May 03, 2006, 03:31 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
Don't know if this matters, but I found a great place (or so I thought) for cheap fiberglass rods to use on the wings of FFF profile planes. Its umberellas. They usually have 1/8 inch or so fiberglass rods in them, you have to work carefully to get the plastic pieces off them but they are free. I think a good bit heavier than CF though. Just my two cents. Ray
raythomas is offline Find More Posts by raythomas
Discussion Carbon fiber vs kevlar (aramid) vs glass? icmartin Slope 17 Oct 31, 2013 02:53 PM
Discussion Carbon Fiber vs. Aluminum? csc Sailplane Talk 28 Jul 08, 2007 11:57 AM
Discussion carbon fiber v. fiberglass T-Rex 450 canopy bobthehobo9 Mini Helis 2 Apr 08, 2007 11:26 PM
Question carbon fiber vs. aluminum sgtdirt The Builders Workshop 8 May 16, 2005 11:09 AM
Fiberglass strapping tape VS carbon fiber...... gpw Foamies (Kits) 10 Sep 09, 2002 09:10 AM
