Old May 01, 2006, 12:51 AM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
Help me figure out what went wrong
I finally finished building the Dumas DV-20 with an OS .21-M inboard. It was the first run of the engine break in. I had just come out of the first turn and opened up the throttle everything seemed OK until midway then the engine sounded like it went lean the boat then really went like it had a jet engine afterburner. The boat then appeared to go up on the prop and it did a torque roll like an airplane then flipped end over end.
I am not experienced so I cannot analyze what happened. The boat seemed to be running flat and tracked straight. I have the trim tabs as was suggested and the prop is parallel to the boat center line. The is balanced midway on the hull length.
Thanks for any help you can give me and as always all help is greatly appreciated.
Ace
PROACE is offline Find More Posts by PROACE
Old May 01, 2006, 06:18 AM
w3bby is offline
Find More Posts by w3bby
Helsingborg, Sweden
Joined Jul 2005
More info required, do you have a tuned pipe on the motor?
It sounds like a basic blow-off, speed too high for the set up.
If the engine is piped then you just experienced it "switching on".
(just a grammatical edit)
w3bby is offline Find More Posts by w3bby
Old May 01, 2006, 02:41 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
It could be 1,001 things. You could have caught a gust of wind, a wave, hit some object just under the surface and like w3bby said, it could have gotten on the pipe or leaned out enough to give it a sudden burst of speed. It's one of those things that's really kind of hard to know from where I'm sitting.
Ron Olson is offline Find More Posts by Ron Olson
Old May 01, 2006, 10:43 PM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
Water was calm and no breeze. The boat weight ready to go is 3lb 12oz and the length is 25 inchs bow to stern. Yes I have a tuned pipe with flex shaft drive and a dumas brass prop 1.625" diameter, 2.5" pitch.
Help! Thinking of going 4Cell Help me figure out what i need! DsWright Mini Helis 15 Jun 27, 2007 10:15 PM
Discussion Help me figure out what battery *please* rcman4life Mini Helis 7 Dec 30, 2006 01:09 AM
Discussion Help me figure out what battery *please* rcman4life Batteries and Chargers 1 Dec 29, 2006 11:13 PM
Crash, help me figure out what happened foofinator Beginner Training Area (Fuel) 11 Oct 01, 2005 05:30 PM
somebody help me figure out what rc heli this is!!! its way small! bassplay Micro Helis 4 Jun 18, 2004 06:22 PM
