I use a heat gun, lots of heat, which is why you need to be careful. I've built Jedelsky type wings, by gluing some foam ribs with 3M77 to help retain the shape. Here's one of them: http://www.geocities.com/pfaudette/eplane/supstik.jpg
I've also made closed wings with a 'C' shape spar, 1/8" balsa doubled up with 1/8" square sticks, to spread out the contact area on the foam. The leading & trailing edges sanded on an angle to glue them down on a wider area. |
Had the opportunity last evening to play with this pink foam. It looks perfect for ribs. It is stiff. It is very easy to cut with a sharp knife or razor blade. It carves nicely and sands well. It weighs 1 oz per square foot. Have not tried to glue it, but I would guess any adhesive for other foam would be OK.
Found an adhesive at the craft store which I plan to try; it is called "Hold the Foam!" by Beacon Chemical Co. and is claimed to be a 'glue for styrofoam'. Works well on the Lite Stik foam. It is slow drying at about 45 minutes and is strong. Mine came in a 2 oz tube. Works also with wood, paper, cardboard and fabric. |
Here in the colder part of the US we can buy this board in 1.5" x 2' x 8'. This costs about $7. Two or three pieces held together with 77 spray and you can build a fuse.
By itself it has little strength, cover it with packing tape and it's almost indestructable. My first plane was a O-C pink foamie with a 56" WS, survived 222 flights and 17 crashes. |
Hoppy has reported on a bunch of them (Aleene's Fabric Glue I remember). One thing to watch is that the Beacon adhesive will re-soften in water even after drying. Rick. |
Space Coast
Joined Oct 2000
Hint for bending foam. Before trying to bend the leading edge, put a strip of 2" masking tape over the leading edge. This will help to prevent it from breaking when you bend it. The other method is to cut the foam along the leading edge and than glue it together at a 90 deg angle. Once again, put some 2" wide tape on the outside of the leading edge before trying to bend it.
This works well with depron, maybe it will work with the material you have. The newest material I'm trying now (which is not new to many people), is to cover the foam with Tyvec, the house wrapping material. It has fibers in it and is almost impossible to tear by hand. Glues very well to foam with Elmers white glue, does NOT shrink on drying, and looks like it should accept paint very well. It will not however stretch over compound curves like brown paper and white glue. hoppy |
Blacksburg, VA 24060 USA
Joined Feb 2000
Most users of this and the blue foam use Probond glue. It makes a very good bond, but you must be careful not to use too much, or it will foam up and ooze out of cracks and joints. The foaming action is good, however, for filling up those less-than-optimum joints.
Users of the blue foam claim it's stiffer than the pink stuff, because it has a clear covering on both faces, which the pink does not. You pays yer munny... |
| Thread Tools | |
| Blue or pink foam?Help please.. | darmar | Foamies (Kits) | 10 | Nov 24, 2004 11:12 PM |
| I found a source for free pink foam fuses | Barrett | Electric Plane Talk | 1 | Dec 01, 2001 06:17 AM |
| securing servos to pink foam on Flitter-B? | rktung | Foamies (Kits) | 4 | Sep 21, 2001 01:16 PM |
| Covering "pink" foam! | ttnissan | Foamies (Kits) | 7 | Sep 10, 2001 03:55 PM |
| Glues for Pink Foam | WAR | Parkflyers | 7 | May 24, 2001 09:38 AM |
