Australia, NSW, Bungendore
Joined Jan 2005
Dornier DO-23 scratch build
I had never intended to build this aircraft but noticed the plan on RCM plans website while looking for Gordon Whitehead's 46" Hawker Demon.
A twin of some sort was always on my wish list, and the Dornier immediately looked interesting (I'm easily distracted ). It was a bit bigger than the average model I'd built, was simple-ish, and designed for two 400 can motors - ideal for those cheap bell outrunners I like so much. So the plan was ordered.It is interesting to note, that both Peter's Baboon and the Hanriot were mostly started and completed before the plans from RCM arrived The DO-23 was a so-called civilian aircraft designed in the 30s when Germany was prohibited from developing bombers. It was a more successful derivative of the DO-11 and the DO-13 result was renamed DO-23 (rather than unlucky 13). This plane was a forerunner to the famous DO-17. The model was designed by Laddie Mikulasko and spans 60" with a suggested max weight of around 4 lbs. With twin 7.2v 400s on 10 cells, this seems ambitious but as a slow flyer with no aerobatic requirements this may be OK. Two 850 kv BL outrunners and 18A escs were purchased off EBAY, with the intention of running APC 9X6 props off 3S lipo. When the motors arrived, they were 750 KV in 850 packaging. As I cannot fit larger props without moving the motors outboard a little, I am hoping there will be enough grunt. Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
Steve - great view - doesn't look like my idea of a forestry plane! I've seen those big struts underneath before but dont know what they are! Any ideas?
Also, there are handrails or antenna running along the fuse top? Great scheme except I have this roll of silver Litetex to use (I'm meaner than Peter Rake )Pat |
Joined Jan 2005
If you look at both those "forestry" pics, there is a deflector shield ahead of the airfoil things and a rear vision mirror under the nose!! curiouser and curiouser..Pat
| Thread Tools | |
| Dornier Do-335 "Pfeil" Build | jcarstan | Slope | 52 | Jan 23, 2006 04:06 PM |
| Discussion Where do you buy balsa for a scratch build | gabe6090 | Fuel Plane Talk | 9 | Jan 13, 2006 10:05 PM |
| What do you need to scratch build foamies? | samolot | Foamies (Kits) | 4 | Apr 26, 2005 05:32 PM |
| My First Scratch build, what do you think? | MailOrderGuy | Parkflyers | 2 | Feb 07, 2003 11:59 AM |
| My first Design Scratch Build Project | Heather | Electric Plane Talk | 20 | Jul 22, 2001 11:03 AM |
