Old Apr 29, 2006, 11:18 PM
POUNDER73 is offline
Find More Posts by POUNDER73
Davenport, Iowa
Joined Jan 2006
Best online source for a new Futaba 9c
I've decided to upgrade radios, and would like to know where I might find one online. I really like the features of the 9c! Any recommendations are appreciated!
POUNDER73 is offline Find More Posts by POUNDER73
Old Apr 29, 2006, 11:34 PM
checkenbach is offline
Find More Posts by checkenbach
H.A.L. 9000
checkenbach's Avatar
Benicia Ca. USA
Joined Jan 2001
http://www.servocity.com
checkenbach is offline Find More Posts by checkenbach
Old Apr 29, 2006, 11:37 PM
Davenport, Iowa
Joined Jan 2006
Whats the diff between low/high band? I've never seen that before!
Old Apr 30, 2006, 01:41 AM
H.A.L. 9000
Benicia Ca. USA
Joined Jan 2001
It's a Futaba thing AFAIK, I'm not an Electrical Engineer, so I don't know the technical end of it. I know the frequencies are split into two groups, not sure why, tighter tuning???? If you get a synth module(HIGHLY recommended!!!!), it won't matter anyway, if you plan on using any Rx other than Futaba. If you primarily fly sailplanes you might consider a Heli vesion due to no ratchet on throttle stick, and better switch positioning for landing mode. You might post on Yahoo Futaba Radios Group also, lots of knowledge there. Chris
Old Apr 30, 2006, 04:48 PM
outfitter540 is offline
Find More Posts by outfitter540
Joined Jan 2006
at servocity the synth module is only $10 more
outfitter540 is offline Find More Posts by outfitter540
Old Apr 30, 2006, 06:09 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Also Check www.allerc.com.
boomer
boomerace is offline Find More Posts by boomerace
Old May 02, 2006, 06:17 AM
guy mckenzie is offline
Find More Posts by guy mckenzie
Joined Jun 2005
Yes, it's really important to buy the best version for you for sailplanes as as well as the ratchet thing some of the switch positions are fixed. For example the 3 position switch for start off (flaps) speed (reflex) can be on the LH or RH side and are fixed there. Most sailplaners (I think) prefer it on the LHS. My 9CP puts it on the left, CAP on the RHS, so check with the supplier, he might understand the question! It's a great Tx!!
guy mckenzie is offline Find More Posts by guy mckenzie
Old May 03, 2006, 01:35 PM
VinceHaworth is offline
Find More Posts by VinceHaworth
VinceHaworth's Avatar
United Kingdom, England, Lancs
Joined Apr 2005
which is the best UK supplier for the 9C?
VinceHaworth is offline Find More Posts by VinceHaworth
Discussion Online source for new Hitec servo extension arms? Valid8r 3D Flying 4 Jun 26, 2006 11:43 AM
Best online source for Batteries SpyHawkFPV Micro Helis 0 Aug 08, 2005 10:39 PM
Best source for new Saito engines? 3DDean Engines 3 Sep 15, 2004 12:33 PM
Good online source for a Tiger Moth? mpj220 Parkflyers 5 Mar 31, 2002 11:36 PM
Best power source for Zagi? Dado Foamies (Kits) 17 Jan 04, 2002 03:00 PM
