Old Apr 28, 2006, 07:10 PM
2lakea is offline
Find More Posts by 2lakea
Its true... A MAN CAN FLY
2lakea's Avatar
Townsville, Australia
Joined Nov 2005
Lipo loss caused by spark
G'day.
I just bought a new 1600MaH lipo. It came, as many do, with that weak little plug. I pulled it off to solder on a deans plug. Unfortunately, the leads touched for a split second. Now my Swallow charger won't even recognise the battery is there. Is it lost, or can it be saved?
I have also had a problem with another battery and recognition after I soldered a deans plug on and wondered if the heat from the soldering iron might cause a problem. What do you think?
2lakea is offline Find More Posts by 2lakea
Old Apr 28, 2006, 07:16 PM
Milton is offline
Find More Posts by Milton
Auburn Ga.
Joined Feb 2004
When you had the short you burned one of the tab's off one of the batteries cells, Been there done that.
Milton
Milton is offline Find More Posts by Milton
Old Apr 28, 2006, 07:23 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Leads should be done one at a time. Never have two ,striped battery leads at the same time. When changing connector types ,cut and strip one slip on a piece of heat shrnik , solder to new connector slide heat shrink into position shrink ,now repeat.Never cut both leads at the same time either.
Do you get any voltage measurement at all?
Charles
Old Apr 28, 2006, 07:32 PM
2lakea is offline
2lakea's Avatar
Joined Nov 2005
Thanks for the advice guys. I will never make the mistake of doing both leads at once again. I guess theres no hope of replacing the burnt out tAB.
Oh well. This hobby is just like boating. Throwing money into a bottomless hole in the sky
Charles
Old Apr 28, 2006, 08:01 PM
Milton is offline
Auburn Ga.
Joined Feb 2004
No
The best two times of owning a boat is the day you buy it and the day you sell it.
Milton
Old Apr 28, 2006, 08:04 PM
Milton is offline
Auburn Ga.
Joined Feb 2004
Charles,
Being you are located in south Ga, Are you going to SEFF.
Milton
Old Apr 28, 2006, 08:30 PM
supi7 is offline
Find More Posts by supi7
supi7's Avatar
CHICAGO
Joined Feb 2004
Originally Posted by 2lakea
G'day.
Most likely the tabs are OK, but check it there is a small PCB on the battery pack. If there is then it may be a crossover between cell one add cell 2 (cell one being the one with (+) wire attached.)
During a short this crossover acts as a FUSE all you need to do is jump it with some wire and solder. (solder alone may not work)
Best Wishes,
Dan
TrueRC
supi7 is offline Find More Posts by supi7
Old Apr 29, 2006, 02:38 AM
2lakea is offline
2lakea's Avatar
Joined Nov 2005
Best Wishes,
Dan
TrueRC
Thanks Dan. Excuse my ignorance. What does PCB stand for? Do you have a photo of what you mean? Cheers mate.
Regards,
Mark
Old Apr 29, 2006, 05:16 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
printed circuit board
The break may be anywhere on that "Z bend"
Dan
In-flight radio glitching. Caused by soldering extra wire to Phx-45 rx connector? 717 Castle Creations 1 Oct 20, 2003 10:24 AM
In-flight radio glitching. Caused by soldering extra wire? 717 Radios 2 Oct 19, 2003 09:23 PM
Economic woes caused by media drumbeat to war. Gman2 Life, The Universe, and Politics 6 Aug 06, 2003 06:55 PM
ESC glitch caused by missing schotky diode??? icebear Power Systems 2 Aug 23, 2002 02:03 AM
Servo jitter caused by battery???? Need HELP!! BlueAce Power Systems 2 Jan 26, 2002 04:50 PM
