Old Apr 28, 2006, 03:37 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
My first composite build: Step by Step
Hey all
First, I'm very new to this composite stuff. I am building a f/g /Kevlar trimaran and would like to start off with something simple. So I decided to build the keel fin for it. I used the TLAR method to find the shape and size.
It's going to be a non vacum bagged, Depron cored, Kevlar/Carbon/Glass layup!
Here's where we start...
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Apr 28, 2006, 04:34 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
More progress..
Old Apr 28, 2006, 04:52 PM
will_newton is offline
Find More Posts by will_newton
wishes this caption was longe
will_newton's Avatar
wilson, nc, usa
Joined Dec 2005
hey tommy!
glad to see you getting a thread together about this! I don't sail boats, but I might if your build thread's cool enough!
Will
will_newton is offline Find More Posts by will_newton
Old Apr 28, 2006, 06:43 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
Will, It just got cooler!
My next step is to cut the fabrics to shape. To do this I'll use a paper template so I don't ned to trim off too much cured material.
Edit: I was going to use the Aramid (Kevlar), but figured I woul probably screw this up and didn't want to waste it. I've got a foot of it and 1.5 yds of S-Glass
Old Apr 28, 2006, 08:48 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
well It's all laied up and is curing right now. I didn't manage to get too many pics duriong it all (epoxy on hands etc), but I wil get some tommorow morning when it has cured. I used West System resin with 205 hardner. It is sandwitched between wax a flat desk, waxed paper, and some heavy books and battery packs on top. I'm screwed if the cured part doesn't release from the paper.... ):
Old Apr 29, 2006, 12:28 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
Awesome
It cam out perfect. I let it cure overniight under a light to heat it a bit. The waxed paper stuck to it, so I wet sanded it to remove it. That tooki like a minuite or so. I then trimmed and wet did a final wet sand with 400 grit paper. It's pretty strong, and as long as I don't smakc it full speed on a rock, it should be ok. I'll get some pics later.
Old Apr 29, 2006, 06:10 PM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
You could put a patch of light fiberglass to cover the non glassed area.
It's great to hear that your first composite project started quite well
regards,
Chets
chetosmachine is offline Find More Posts by chetosmachine
My first scrath build, How did I do? Flying Taco Parkflyers 5 Aug 29, 2009 09:11 AM
My first balsa build - Switchback! FJR Parkflyers 26 Jul 03, 2003 10:25 AM
75% Bluecore Pibros - My first F3 build. gobigdale Foamies (Kits) 14 May 16, 2003 09:11 AM
My first scratch build plane - MT1 tomx Parkflyers 14 Mar 28, 2003 04:59 PM
My First Scratch build, what do you think? MailOrderGuy Parkflyers 2 Feb 07, 2003 11:59 AM
