Old Sep 14, 2006, 07:29 PM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Floats????????
Every time I go out to fly after work the local athletic fields are busy now that school's started. But there is a nice little lake around the corner tha begs for my TM on floats!!
I've browsed thru the TM thread here and am looking for recomendations for pico TM floats. I think the GWS floats are too heavy. Anyone have plans or a source for Tm floats?
My TM is powered by a lens 17T cd, so I think it'll have the power to get off the water with appropriate floats.
Paul
praymond is offline Find More Posts by praymond
Old Sep 14, 2006, 08:14 PM
flycracker is offline
Find More Posts by flycracker
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
Me too. will soon be near nice little lake in the Carolinas
flycracker is offline Find More Posts by flycracker
Old Sep 15, 2006, 12:23 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Kitty, you have to pick up a Lama, Pegasys, or a BladeCX. I fly 2-3 times a day inside the house. My kid goes bonkers! Buzz and I have been chatting over it too. It seems his Lama V3 and mine share the same habits, they love to break the 25' Buzz-Moth limitation! HAHAHAHAHAH. Sorry Buzz, could not hold that one back.
Oh, my moth motor is going to be changed for sure. I have a new one on its way, and should be here by Saturday. Something I been looking to find for a while from a local dealer, and I was lucky enough to see that GorillaBob has picked up some for his stock.
Check this out:
EC28P-S Brushless Motor $13.50
Product Description
Length: 9 * 27 * 47mm
KV: 1540
Weight: 29g
Diameter: 28mm
Shaft Diameter: 3.175mm
TeamTEOR is offline Find More Posts by TeamTEOR
Old Sep 15, 2006, 12:37 AM
LedKitty is offline
Find More Posts by LedKitty
I even seen a house fly!
LedKitty's Avatar
Montreal!
Joined Oct 2003
That's a sweet little motor and mount Tom!
Paul and Rich, I truly can't say enough about dirt cheap floats cut from 2" pink insulation foam on the bandsaw, sanded and covered with low temp, lightweight covering. Made small mounting blocks from basswood, cross beams out of 1/8th CF tubes and you're good to go! Super light, plenty strong, they do the trick nicely
Attached is the plans I used, originally provided by Chuck!
Cheers!
K
LedKitty is offline Find More Posts by LedKitty
Old Sep 15, 2006, 12:43 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Cool, if I have time tomorrow I will have to cut myself out a set of those. Is there a real reason for those to be tapered in to the top like that? I wonder if I have some balsa laying around, maybe I can make templates and then use a hotwire to cut the rest out smooth.
Old Sep 15, 2006, 01:11 AM
The Enemy is offline
Find More Posts by The Enemy
AllAloneInSpaceAndTime
The Enemy's Avatar
Canada, ON, Guelph
Joined Apr 2003
TEOR, they're tapered to save weight I think... Not under the water anyway...
Here's a thread I found a while back on building hollow floats. http://www.rcgroups.com/forums/showt...ht=1+97+floats
Kitty,
I'm right there on the amazing little PicooZ too. Have 2 already!
Corey
The Enemy is offline Find More Posts by The Enemy
Old Sep 15, 2006, 01:28 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Yup, I'll do a mixture of the two, whichever is easier to cut out on the scroll saw. I'll fire up the band saw for the major cut of the foam, and then the handheld hotwire to do the actual cutting of the shape.
Now I know what to do with the extra Moth in the closet. I wonder if AllERC was able to start selling those strut kits again....
Old Sep 15, 2006, 02:56 AM
radralph is offline
Find More Posts by radralph
My first Build
radralph's Avatar
Vancouver WA
Joined Jul 2006
Looks like it.
http://www.allerc.com/product_info.p...af26d8a31083e8
EDIT. Just got one!
radralph is offline Find More Posts by radralph
Old Sep 15, 2006, 07:15 AM
praymond is offline
praymond's Avatar
Joined Jun 2005
Hey thanks Kitty! I have some 2" blucor I'll try it on.
Is that the wheel LG wire on the front, with the wheels removed?
And did you use the rear wing rubber band "pins" to attach the floats?
Those look great-- did you cover or paint them
thanks---Paul
Old Sep 15, 2006, 08:44 AM
althulas is offline
Find More Posts by althulas
althulas's Avatar
Banbury,Oxfordshire,UK
Joined May 2002
Kitty looking back in the manual for the dihedral, the lower wing layed flat and raised at one tip by 80mm and the top wing both tips raised by38mm.
Mark.
althulas is offline Find More Posts by althulas
Old Sep 15, 2006, 09:11 AM
LedKitty is offline
LedKitty's Avatar
Montreal!
Joined Oct 2003
Paul! Yes and yes!
The floats are indeed covered, in this case with black Econokote, but any low temp, lightweight covering should do the trick. The idea is to make them nice and slick when running on the water Tried a set of DIY floats on an old E-Starter ages ago that I hadn't covered, and the thing would just STOP on landings, and forget about ROW!
Mark! Thanks! ^_^
CHeers!
K.
Old Sep 16, 2006, 10:09 AM
Drunkskunk is offline
Find More Posts by Drunkskunk
Crash tester
Drunkskunk's Avatar
Texas
Joined Sep 2006
hey TeamTEOR , who makes that motor? it look like the same output, but 10grams less weight than the GWS I was going with. I'd really like to shed 10 grams!
Drunkskunk is offline Find More Posts by Drunkskunk
Old Sep 16, 2006, 11:07 AM
GBX is offline
GBX
Find More Posts by GBX
GBX
Illinois
Joined Jan 2005
Im Lazy so i just ordered some floats from www.foamfloats .com
GBX is offline Find More Posts by GBX
Old Sep 16, 2006, 11:33 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
It is made be ELE. I'll let you know how I like it as soon as it gets here. I am hoping it is today. GorillaBob is over in Bullhead City, AZ so is should not take that long to get here. It was nice to see a local vendor have these in stock. I have ordered from him before, and he is a real stand up guy. Here is a link: http://www.gorillabobsshack.com/cata...products_id=89
Old Sep 16, 2006, 03:04 PM
Buzz is offline
Find More Posts by Buzz
Forever WTTM Pilot #7
Buzz's Avatar
Daytona Beach, Florida, United States
Joined Aug 2002
OK, Teor... I caught that message about flying higher than 25ft.
I'm doing the same basic motor install on the white Pico Moth ... which I need to get started on. I have a lens end runner, but I don't have an ESC yet. What are you using? Also, some tips on a motor mount would be much appreciated.
I decided to find the oldest electric airplane out there, and ended up with a Wright Flyer! This thing is going to be so cool.. the only thing I have to finish is some detail painting on Orville and the frame of the plane. Oh, yeah... no wingwires yet either.
I'm also going to have to paint the props brown. If they were a different color, I could use a brown marker to make them look like wood. Any suggestions on what color Orville should be? I'll get some video of the maiden .... or the crash.
Buzz is offline Find More Posts by Buzz
Discussion GWS Tiger Moth thread - Part 28 Ozprey Parkflyers 2388 Apr 28, 2006 01:10 AM
GWS Tiger Moth story - Part 9 Martin Hunter Parkflyers 547 Jan 01, 2004 07:32 PM
GWS Tiger Moth Story - Part 9 The Enemy Parkflyers 2 Dec 18, 2003 09:21 PM
GWS Tiger Moth Story - Part 8 The Enemy Parkflyers 566 Dec 18, 2003 09:11 PM
GWS Tiger Moth Story - Part 7 The Enemy Parkflyers 521 Dec 04, 2003 11:01 PM
