That's lookin real good! All I need is a brushless ESC and I'll have everything I need for the white moth. My site has been keeping me pretty busy, but .... I do need to build it soon. I guess you never found the yellow moth? That's really too bad. That was a sweet little plane. |
Flycracker:
Nice looking moth. Something about a white moth with appropriate trim. My planned TM #3 will be built from a white kit. I have a picture of Keith's moth on the wall for inspiration, and a picture of Kitty's Little Fishy on the wall as a motivator. RD |
Latest blog entry: Big Red Cadillac
Hey TM flyers, my TM has egg shaped exit holes for the control rods from all the flights on it. It's causing the rudder to keep from centering consistantly. Whereas they were just a punched hole when new, they've now become elongated and much bigger. Any suggestions for a light weight fix for this? I'd hate to add any weight to the tail end, she flies so nice now.
thanks Paul |
boomer |
Egg Shaped Holes
Perhaps I am looking at this from the wrong direction, but I would think elongegated openings for the control rods would not be the cause of self-centering problems for a given operating surface. There would be less resistance to the movement of the control rod in an enlargened hole versus a new or tight opening. Is there a problem with the servo or the servo linkage?
It would be possible that the small diameter control rod is deflecting under load as it would not be supported properly due to the enlargened opening in the fuselage. This, I would think, would lead to less movement of the operating surface, or inconsistent deflection of the rudder/elevator. In that case, I think TeamTEOR has presented a very good workable solution. I had a severe self-centering problem with the ailerons on my Speedy 400, due to the friction of the bowden wire setup and the deflection of the control rod(s) under load. Solved the problem with separate servos for each aileron. Just my perspective. RD |
It could be the servo. |
Hey Buzz, Good Call!!
I pulled the wings and checked the rudder servo-- it's not consistant in it's centering. It's off by bout 1/16 returning to center, and hunts sometimes to find center. It's a hitec HS50, I have aa TP rs 50 that'll fit in the same space (two balsa rails going across the fuse). Probably the holes won't bother anything when I replace the servo. I used to be able to hold my radio in my left hand and swat bugs, the the TM would just put along on a die straight coarse. Now I'll be able to do that again!!! Thanks again Paul |
Going WAY off topic!
Just got back from driving my son's new $125,000 show truck and he is already redoing the flames to "ghost" flames and putting on chrome wheels for the 40" tires! Even the door handles are flames.Truck started off as a Chev Avalance that morphs into a pick-up. 3000W stereo system! It is kind of like flying a airplane and feel like you should have oxygen from the driving height! boomer |
Buzz |
| Thread Tools | |
| Discussion GWS Tiger Moth thread - Part 28 | Ozprey | Parkflyers | 2388 | Apr 28, 2006 01:10 AM |
| GWS Tiger Moth story - Part 9 | Martin Hunter | Parkflyers | 547 | Jan 01, 2004 07:32 PM |
| GWS Tiger Moth Story - Part 9 | The Enemy | Parkflyers | 2 | Dec 18, 2003 09:21 PM |
| GWS Tiger Moth Story - Part 8 | The Enemy | Parkflyers | 566 | Dec 18, 2003 09:11 PM |
| GWS Tiger Moth Story - Part 7 | The Enemy | Parkflyers | 521 | Dec 04, 2003 11:01 PM |
