Old Aug 23, 2008, 07:26 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Hey Pat, are your floats from Foamfly? I just got mine yesterday. I think I'm going to add a small skeg to each. Any other advice? Really looking forward to flying off water..
Angelo is online now Find More Posts by Angelo
Old Aug 23, 2008, 07:45 PM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
My floats are made on a band saw with pink foam--glassed the bottom and sides.
Pat Daily is offline Find More Posts by Pat Daily
Old Aug 23, 2008, 09:14 PM
Steve_A_Reno is offline
Find More Posts by Steve_A_Reno
Planes, Guitars and Cigars
Steve_A_Reno's Avatar
Joined May 2002
Sorry to hear about all the bad weather you guys had in Fla. Hope you are drying out. Just got back from a week in the Poconos. The weather was fabulous. Not a drop of rain for 7 days. Sunny and about 75 degrees everyday. Cool for August but perfect as far as I'm concerned.
Got my floats back on the TM before the trip. With the the BL motor it flew perfect. Lots of easy flying and touch and goes. No nose overs. Every morning and evening were dead calm and my moth couldn't have been happier. I must haveflown a good 30 flights.
Also had my GWS cub with me. I think the motor is about shot on her but she flew great as well.
Steve_A_Reno is offline Find More Posts by Steve_A_Reno
Old Aug 23, 2008, 09:49 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Steve_A_Reno:
Great shot of your moth on floats. Nice reflection. The very essence of Moth!!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Aug 23, 2008, 10:22 PM
wgoostrey is offline
Find More Posts by wgoostrey
North of Lake Pontchartrain
Joined Jan 2006
Hi Pat,
Thanks for all the realy cool pics and vids you've put un this and other threads.
Did enjoy the auto gyro!
Are those floats on a pdf somewhere?
Wes
wgoostrey is offline Find More Posts by wgoostrey
Old Aug 24, 2008, 09:13 AM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
Does anyone know where I can get a new set of wings? MY TM lost a dogfight with a friendly and got shot down today. Thanks.
taekwondo is offline Find More Posts by taekwondo
Old Aug 24, 2008, 09:16 AM
Pat Daily's Avatar
Joined Mar 2001
Balsa Products and Tower both carry spare parts for GWS.
Old Aug 24, 2008, 09:53 AM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
Doesn't Graves carry spare parts anymore?
Chuck
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Old Aug 24, 2008, 09:54 AM
Pat Daily's Avatar
Joined Mar 2001
Here are the details on my pink foam (or blue foam--a bit heavier) floats. No diagrams or pdfs available. These floats are perfect for the TM and Cub-- this set had been in service since 2004 and are a bit beat up and you may note I snapped one in the middle and epoxied it back together.
Here are the measurements
The Top of the float is flat
Length 17.5 inches
Width 2 inches
Height at step 1.75 inches
Step notch is 0.25 inches deep
Height at rear of float is 0.5 inch
Step is 8 inches from the front.
The nose is a gentle French curve and is 1.5 inches deep at 4 inches behind the front of the float.
The step is 0.5 inches behind the leading edge of the lower wing.
The float is 3 inches below the fuselage at the front strut and 2.75 inches below the fuselage at the back strut.
The floats are 7 inches apart --inside to inside edge and parallel.
The struts are 0.051 music wire.
I use 1/16 ply pads (1.25 by 1.25 inches) epoxied to the tops of the floats 5,5 inches and 11.5 inches from the front.
I use nylon landing gear clips screwed into the pads to hole the cross braces and struts in place.
I use a 1/4 inch by 1/16 inche basswood skeg on the bottom of the rear of the float centered from the stop to the rear of the float.
I glass the bottom and sides of the float back to the step and the top back to the rear mount. You could glass the whole float if you want.
I drafted my bride, Sandie, and her kitchen to take some pics for you. Hope they help.
Old Aug 24, 2008, 10:50 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Chuck
Yes they certainly do Chuck!
http://www.gravesrc.com/GWS_PICO_TIG...-tm-das2-y.htm
Henry, you do not even have to go inside the store and you can order it via on-line (something you know very well to do) and save on Gas $$$!
guapoman2000 is offline Find More Posts by guapoman2000
Old Aug 24, 2008, 01:23 PM
Jugjock is offline
Find More Posts by Jugjock
Jugjock's Avatar
Arvada, Colorado
Joined May 2004
Maybe I'm not using the right search terms... but is anyone aware of a post that describes how to remove the small metal gear from a brushed GWS IPS motor shaft and how to press it onto a Feigao replacement motor? I thought I'd better ask for help before immediately reaching for the hammer and chisel.
Pat, that sure is some fine looking work on your Moth!
Jugjock is offline Find More Posts by Jugjock
Old Aug 24, 2008, 02:38 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
I tried Graves online.
Carlos:
Thank you for the good idea. I tried Graves online. It said I could ship ups so I thought I'd choose that since the wings are so light. When it came time for shipping charges, they wanted me to use DHL Ground, The 6.00 extra plus the 12.50 and tax, I'm close to $20.00 For that, I'll get a whole new kit online for $24.00 at tower and I have a free shipping code or $10.00 off if I spend $50.00. Unless someone is going to Graves in the near future.
Old Aug 24, 2008, 03:45 PM
Pat Daily's Avatar
Joined Mar 2001
Jug
You need a gear puller for these small motors--I think they are available from some of the on line places. I bought one years ago. GWS may even sell one. I use a small vise to push the gear on a shaft very gently. If you use a hammer, barely tap it on and make sure the back end of the shaft is on something hard like a steel ruler.
Old Aug 24, 2008, 03:51 PM
Pat Daily's Avatar
Joined Mar 2001
I just finished installing a brushless esc and one of my new headsuprc outrunners on my old Land plane version of the Tiger Moth. I used a circle of 1/2 inch balsa with a 1/8 inch lite ply fire wall and the radial mount. Need a bit of downthrust with 2 lipos and an 8 x3.8 APC. Flew it on my cul de sac. It still needs a bit more downthrust to handle full power. I got tired of my brushed motor cutting in and out.
Old Aug 24, 2008, 04:19 PM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
BEAUTIFUL PHOTO!
Discussion GWS Tiger Moth thread - Part 28 Ozprey Parkflyers 2388 Apr 28, 2006 01:10 AM
GWS Tiger Moth story - Part 9 Martin Hunter Parkflyers 547 Jan 01, 2004 07:32 PM
GWS Tiger Moth Story - Part 9 The Enemy Parkflyers 2 Dec 18, 2003 09:21 PM
GWS Tiger Moth Story - Part 8 The Enemy Parkflyers 566 Dec 18, 2003 09:11 PM
GWS Tiger Moth Story - Part 7 The Enemy Parkflyers 521 Dec 04, 2003 11:01 PM
