Old Jul 13, 2006, 05:11 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Photo Recon!
O.K.!, Just strap on the wing, and we're ready for a movie run, to find lil' mothy lost! (Tabitha-Ann plans to continue guarding mommie's kitchen chair)!
Lancer31 is offline Find More Posts by Lancer31
Old Jul 13, 2006, 08:31 PM
Sympster is offline
Find More Posts by Sympster
Louisville, KY
Joined Jun 2006
I just ordered a TM400 and a brushless setup. Is it possible / good idea to fly the TM400 with no landing gear at first and belly land in medium grass until I get the hang of things? This will be my first aileron plane. I'm a little concerned about landing on pavement or dirt.
Also does anybody know of a good FMS model for the TM400?
Sympster
Sympster is offline Find More Posts by Sympster
Old Jul 13, 2006, 10:09 PM
conceptmachining is offline
Find More Posts by conceptmachining
Death and Taxes
conceptmachining's Avatar
Des Moines I'm in Heaven...I mean Iowa
Joined Feb 2006
Those of you that used the wood struts from allerc, did you pay attention to the directions on the sheet that is supplied with them? If so, where did you put the top wing? It says to measure from the bottom front of the wing 1 9/16 and start the slot there. Okay, I did that, and then it didn't say what to do with the top wing, so I was stupid and put them in the original position, causing the wing to be off from one another. Should have just put them where the original dimples were, and I would have probably been fine. Those of you that have used them, where did you put them ?
Jimmy
conceptmachining is offline Find More Posts by conceptmachining
Old Jul 13, 2006, 10:32 PM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
I don't remember any directions came with mine, I put in the dimples where the original struts went.
praymond is offline Find More Posts by praymond
Old Jul 13, 2006, 11:23 PM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
I'm with praymond. However I used them as lamination to the original plastic parts.
TeamTEOR is offline Find More Posts by TeamTEOR
Old Jul 14, 2006, 01:59 AM
Stuart Linfoot is offline
Find More Posts by Stuart Linfoot
build, fly, crash, repeat ...
Stuart Linfoot's Avatar
United States, OR, Beavercreek
Joined Jan 2004
I put them where the original dimples were, they worked fine for me.
I got my moth finished up tonight, all I have left to do is ad a few more decals, then take it to the pin striper.
After the "accident" it needed a complete rebuild, the fuselage has been repaired (not real good looking, but it will do), it's got new wings and tail, a kitty cowl (you’re cowl worked out great, thanks kitty!!) I salvaged the allerc struts after the "accident" from the old wings, and for the flying wires I used spider wire fishing line this time.
I'm going to call it a 30-foot plane; it will look good from 30 feet through blurry glasses with bad eyes.
Stuart Linfoot is offline Find More Posts by Stuart Linfoot
Old Jul 14, 2006, 03:45 AM
wig is offline
wig
Find More Posts by wig
wig
Joined May 2006
Guys,
I have been flying my TM400 with a Himax 2025-4200
with a gear of 5.33:1, a APC 10X7E with a 3S 2100 for
1 1/2 years and read something that said that I may have
the wrong propeller. I think they recommended a APC 10x7.
Any help with ratios and props and other combinations would
be greatly appreciated!
Wig
wig is offline Find More Posts by wig
Old Jul 14, 2006, 07:52 AM
Death and Taxes
Joined Feb 2006
Yeah, I should have never paid attention to the directions that came with the struts. by the way, what is the 5th single piece used for that comes in the set? Does it brace the wing or something??
Old Jul 14, 2006, 10:47 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Struts
With regards to the TM struts, I did what Basketcase did with his TM ie; I glued some CF rods to the provided struts. I've done this with 4 different Pico TM's over the years and some of them have been way overpowered with AXI 2208 34s and 3s lipos packs and I haven't had a wing failure with these
I've used both epoxy and contact cement to attach the CF rods to the plastic struts with equal success.
Here's a couple of shots of one of my somewhat modified TM's with the CF struts.
Kern
KLH is offline Find More Posts by KLH
Old Jul 14, 2006, 10:56 AM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Kitty is going to love the Barbie in there.
Old Jul 14, 2006, 11:20 AM
Travler is offline
Find More Posts by Travler
Wingman
Travler's Avatar
United States, AL, Randolph
Joined Mar 2004
CAUTION!! off subject.
Buzz,
You should read the MDS ( material data safty sheet) for Ivory flakes. You are supposed to wear a face shield,apron,rubber gloves and wash up after. It contains a small amount of caustic soda, thats what makes it feel so soft.
Larry
Travler is offline Find More Posts by Travler
Old Jul 14, 2006, 11:31 AM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
It's a dihedral brace that goes across the center rib on the bottom of the bottom wing to reinforce the joint.
boomer
boomerace is offline Find More Posts by boomerace
Old Jul 14, 2006, 11:50 AM
pburress is offline
Find More Posts by pburress
Kansas is windy.
pburress's Avatar
Wichita, KS
Joined Jun 2003
Sympster
Sympster, I would say go ahead and start with the landing gear. If you belly land in grass with no LG you run the risk of catching the bottom wing and causing damage. Don't be intimidated by landings; practice, practice, practice! Few things are nicer to watch than a smooth scale looking touch-and-go!
Landing is a big subject so I'll just say this: the first and main thing to shoot for is a nice approach. Make a long approach, reduce throttle gradually to about 5% or 10%, and be ready to apply throttle to abort the landing and come around for another try.
As far as FMS models, there is a tiger moth so start with that. But practice on different models. The fact is, it's a lot easier in FMS no matter what model you choose.
pburress is offline Find More Posts by pburress
Old Jul 14, 2006, 12:28 PM
Sympster is offline
Louisville, KY
Joined Jun 2006
OK, I will try it with the landing gear and I'll also get a second bottle of glue.
I found alot of Pico Tiger Moth FMS models (all without ailerons) do you know of a TM400 model and where can I download it?
Sympster
Old Jul 14, 2006, 03:12 PM
Death and Taxes
Joined Feb 2006
Just got done with my maiden. It flew pretty good...even in the wind. But I tell you those little gusts will darn near it flip it over in a hurry. I have some questions. When flying full throttle, at the correct CG, is it common for the plane to want to pull up? I have a 25turn motor with a 10x6 prop and it was wanting to do loops at full throttle. It may have something to do with my wings being altered due to poor positioning of the wings (in my case). Also, I will be building another one soon. I want to get different servos. Which ones other than Waypoints would you recommend? I can do with more weight as I needed a little clay on the back to get CG right anyway.
jimmy
Discussion GWS Tiger Moth thread - Part 28 Ozprey Parkflyers 2388 Apr 28, 2006 01:10 AM
GWS Tiger Moth story - Part 9 Martin Hunter Parkflyers 547 Jan 01, 2004 07:32 PM
GWS Tiger Moth Story - Part 9 The Enemy Parkflyers 2 Dec 18, 2003 09:21 PM
GWS Tiger Moth Story - Part 8 The Enemy Parkflyers 566 Dec 18, 2003 09:11 PM
GWS Tiger Moth Story - Part 7 The Enemy Parkflyers 521 Dec 04, 2003 11:01 PM
