High Flying Moth
Well, folks, we finally got the chance to fly the Moth and check out the altimeter device. Wind was calm to trace wind conditions, close to 8:00 PM, so up she went. Once I got up into clean air, the breeze was very light but constant, perfect for floating the Moth at high altitudes. Brought her in early, just 12-1/2 minutes of flying time. Could not get the altimeter to read back out on the strip, but then it was getting towards dusk. On the bench, under a more focused light, still had a problem with getting the device to read back. Apparently, the shadow of my finger was not as clearly defined, or of sufficient contrast to trip the sensor for read back function. So, I tried a little device I discovered while at the doctors office. I "installed" that, on the appropriate finger, and did the 4 pass wave as so instructed. Bingo, the altimeter read back the height, AGL, via flashes. I had estimated mentally how high the Moth had flown, knowing I had been notably higher in past flights. Did NOT want to spec her out at this point, just see if the altimeter worked. It did, and here is the result:
Flash, Flash, Flash, Flash, Flash, Flash.......Flash, Flash.......Flash, Flash Yep, 622 feet. Now I am more than sure I have approached 800-900 feet in some past flights. The wings were still clearly visable at 600 feet. When I experienced the "under fly" via a full scale plane, the Moth was a mere yellow spec, no discernable outline. Simply (requiring a riveted attention) a mere yellow dot moving slowly. Can't wait for a full spec-out flight!! ![]() RD |
Latest blog entry: Big Red Cadillac
Next comes the pitot tube, followed by the on-board port-a-potty!
![]() RD |
OK, so can anyone tell me a quick link to Pico Moth mods that need to be done? I just picked up my first ever moth....Want to build it right the first time. Planning on stock power for now, but 2 cell 800 lipo's for juice as I have 4 already from my heli. Will be using 2 picos, a Hitec 05S RX, and GWS GS-100E for esc. Please any tips, advice, links to advice, bring it......Any and all. Thanks alot, Chris
Hi Chris, congrats and welcome to the Tigermoth Squadron.
![]() All the parts you list will work perfectly. Here's my little bit of advice, in the form of a thread I started on the building of my second Moth, used all the mods that worked well on the first and added a couple more. Even though that was a couple of years ago it's still flying. But does look a slightly worn after these couple of years since I built it. ![]() http://www.rcgroups.com/forums/showt...threadid=59561 Wayne |
Why do you need a few guys and gals? Are you running low?
Latest blog entry: Selling out
Ho - Hum - and High
Great evening, once again, for Moth flying. Basically dead calm until you get some altitude (spelled 25 feet and then some...
) afterwhich the breeze is very light and steady. Thought I would "push the elevator" a little bit more and see what I could get for a decent view way up high. 26-1/2 minute flight, TP 1320 2S1P ProLite showed 7.61 resting voltage after the Moth was down and unplugged. The altimeter, after much coaxing, flashed it's reading. 813 feet. And the wings were still clearly discernable at that height, as was the yellow color when the sun hit the plane just right. I may have to relocate the sensor, as recommended by Dave of Winged Shadow Systems, to get a better triggering of the readback flashes. For the moment, however, this device adds a whole new dimension to flying my Moth! ![]() Buzz: You MUST get one for your pending Moth. Don't leave ground without it! ![]() RD |
Why is the location of the sensor so critical? 813ft? You'll be able to go over 1000 easy. My altitude record is 1228ft. That was with a Wingo with a BIG altimeter in it. That was the day I got thrown out of the airport! Two cop cars blocked me in and said to get it down FAST! I was confusing the guy in the tower. Seems the guy in the tower was trying to radio my Wingo to clear airspace over an active runway! LMAO!!!
| Thread Tools | |
| Discussion GWS Tiger Moth thread - Part 28 | Ozprey | Parkflyers | 2388 | Apr 28, 2006 01:10 AM |
| GWS Tiger Moth story - Part 9 | Martin Hunter | Parkflyers | 547 | Jan 01, 2004 07:32 PM |
| GWS Tiger Moth Story - Part 9 | The Enemy | Parkflyers | 2 | Dec 18, 2003 09:21 PM |
| GWS Tiger Moth Story - Part 8 | The Enemy | Parkflyers | 566 | Dec 18, 2003 09:11 PM |
| GWS Tiger Moth Story - Part 7 | The Enemy | Parkflyers | 521 | Dec 04, 2003 11:01 PM |
