Old Jul 10, 2002, 05:41 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Best Motor/prop/battery for high altitude
Hi, I am new to electric planes and have not had much success as of so far. I have a couple of planes that are roughly 26 oz and have a wing area of about 275 sq inch. I have tried a Graupner speed 400 race motor with an 8 cell pack with both 5 X 5 and 4.5 X 4 props and they barely fly. Anyone have suggestions on what would make these planes scream? What is a super hot combination? Should I go brushless? Should I gear it? Should I go to a 10 cell pack? Should I quite asking so many questions?
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Jul 11, 2002, 03:43 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Khen,
Have a search for "MotoCalc" and/or "Electricalc". These are two programs where you get to put in all the numbers about a plane (wing area, weight, motor, cells, etc.) and then they let you "try" different props and use mathematics to predict what it will fly like. Both are remarkably accurate. In the case of MotoCalc you can download a trial version that works for 30 days to see if you like it before parting with your cash.
Later...
The relevant web sites are:
Motocalc
and
Electricalc
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Jul 11, 2002, 09:18 AM
Utah USA
Joined Jun 2002
OK I downloaded motocalc, wow what a great tool!
Theres alot of factors involed in choosing the right combination for these electrics isn't there -- not quite as easy as gas planes(but not as loud and sloppy either).
Thanks for your help
Site Sponsor
Old Jul 11, 2002, 10:38 AM
RPatrick is offline
Find More Posts by RPatrick
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Hi Khen, and welcome to Ezone!
When thinking about your motor setup, the one of the first decisions is to determine whether your plane will fly best with either gearing or direct drive. Sleek low drag planes like direct drive with small props, while planes with thicker profiles need larger props for more thrust and are geared (most of the time, depending on the motor). Once you know this you'll be able to better utilize the prediction programs.
A brushless motor with 10 cells !!!
RPatrick
RPatrick is offline Find More Posts by RPatrick
Old Jul 11, 2002, 04:59 PM
calvin8837 is offline
Find More Posts by calvin8837
Joined May 2002
This works on my 26oz plane
On a 26 oz AUW plane I have, which is a flattened aileron T52 wing and a scratchbuilt fuse, I have had great success with the following power combo.
S400 6V
APC 9.5 x 6.5N Prop (intended for .40 gas pylon racers)
2.9:1 Gearbox
8cell 600AE or RS 1600Nimh
Duration is 6 minutes with AE and 10+ minutes (I always land waaaayyy before the cutoff occurs with this pack) with the RS Nimh. This combo is cheap and gives good thrust and top end.
The funny thing is that in experimenting with these setups the crucial factor after you get in the ballpark with motocalc is trying many differrent props. I collect them almost everytime I go to the hobby store. It seems that every AUW, motor, Battery, Gearbox combo has its own prop sweetspot, and it really just takes flying alot of them to know which one that is. I hope this info helps.
calvin8837 is offline Find More Posts by calvin8837
Old Jul 12, 2002, 12:32 AM
Utah USA
Joined Jun 2002
Thanks! all your help is appreciated. I am slowly starting to figure this stuff out.
Site Sponsor
Question What motor / prop / battery for converting 54" foam glider? magic612 Electric Plane Talk 15 Feb 01, 2006 01:46 PM
Question Best motor/prop/battery combo for Magpie as AP plane? denial Aerial Photography 10 Feb 16, 2005 11:30 AM
Prop pitch for high altitude? edfardos Electric Plane Talk 4 Oct 12, 2004 01:23 AM
Question re: motor / prop / battery for Apache Tempest Sport Planes 7 Aug 08, 2002 01:03 AM
Hottest Motor/Prop/Battery for Push-E Cat? ScottChase Foamies (Kits) 0 Feb 06, 2002 10:46 PM
