Old Apr 26, 2006, 09:16 PM
mitchlandry is offline
Find More Posts by mitchlandry
United States, TX, Tomball
Joined Jan 2006
Build Log
My first towboat
Hey every one.
Here is my first attempt ever at building a towboat, actually building any boat.
This is the Joey Carol from towboatjoe's. I'm building in 1/48, so model is 21" long. Eventually, 2 barges will accompany this vessel.
Please don't be shy on suggestions, remember this is my first boat, and you only learn by experience.
mitchlandry is offline Find More Posts by mitchlandry
Old Apr 26, 2006, 09:18 PM
Joined Jan 2006
Here are the stern rudders , flanking rudders, wheels and propshaft support-strut layed out to be cut
Old Apr 28, 2006, 02:39 AM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
Looks good so far.
Treetop is offline Find More Posts by Treetop
Old Apr 28, 2006, 07:45 AM
wingnut163 is offline
Find More Posts by wingnut163
wingnut163's Avatar
Newburgh New York
Joined May 2005
wingnut163 is offline Find More Posts by wingnut163
Old Apr 28, 2006, 08:56 AM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Mitch,
Looks like you're doing as well (if not better) as any new builder usually does. You've gotten the design from someplace that does know what they (he's) are doing, so guess that's to be expected.
The only 'hints' I can offer are;
Buy sandpaper by the ton, it's cheaper.
Don't glue more than one hand to your forehead at a time. Really hard to get to your car keys with both hands tied up.
Do the thinking part ~before~ doing the gluing!
- 'Doc
PS - Wonder what would happen if you made the main and flanking rudders into 'Becker' rudders? Forget it, probably twist the boat in half...
LtDoc is offline Find More Posts by LtDoc
Old Apr 28, 2006, 09:55 AM
Tug Guy is offline
Find More Posts by Tug Guy
Joined Jan 2006
It looks like a first rate job to me. You are doing great, keep up the good work. And by all means please keep those pics coming. What are you using to power the boat?
Tug Guy is offline Find More Posts by Tug Guy
Old Apr 28, 2006, 09:28 PM
Joined Jan 2006
I haven't decided on power yet. I'm thinking 2 540 size motors. Not sure if i am going to direct drive (low rpm motors) or gear reduce (higher rpm motors)
I have an extra 7.2 NiCd laying around, i thought 2 of those would be great for the power source
I will most likely set the boat up with 2 ESC's so i can control each motor independently.
Question, I was thinking of fiberglassing the hull for extra strength and durability. Do you think resin only will be enough, or should i put mat down as well.
Old Apr 28, 2006, 11:38 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
If you only use resin in time it will crack due to the expansion and contraction of the wood. Use cloth not mat, cloth is much easier to work with and doesn't soak up as much resin. For strength use 2 layers of cloth.
green-boat is offline Find More Posts by green-boat
Old Apr 29, 2006, 09:18 AM
towboatjoe is offline
Find More Posts by towboatjoe
River Rat
towboatjoe's Avatar
Flatwoods, KY
Joined Feb 2006
Mmitch, on the Joey Carol I built I used a layer 3/4 ounce mat. For fibergalssing go with Epoxy Finishing Resin. It's a 50/50 mix, doesn't have a strong smell, amd is not affected by humidity changes as bad as Polyester Resin. If you're not experienced with Polyester it can get very messy, plus it has to be done outside, unless you got a good ventilatiion system, and it's hard to estimate how many drops of catalist to add to each ounce of resin because of it being so sensitive to the humidity. Rember Epoxy Finishing Resin, not the same stuff as Epoxy Adhesive.
towboatjoe is offline Find More Posts by towboatjoe
Old May 04, 2006, 11:44 PM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
Mitch, what did you use to cut the props and rudders from the brass sheet in such a way that they appear to be flat, and didn't try to curl as they were cut? Thanks.
jeepers1940 is offline Find More Posts by jeepers1940
Old May 05, 2006, 12:05 AM
Joined Jan 2006
Actually, i had more problem with the brass trying to curl when trying to grind the edges smooth.
Anyhow, the 1st rudder i tried, i used a dremel, what a pain. The brass sheet i'm using is a little thick at 1/16".
After that i use a scroll saw, still troubling, was dulling the blade after 2 sides of rudder. Managed to finish rudders with the scroll saw anyway.
The props, i finally thought about it, i have a shopsmith w/ bandsaw attachment. Turned the RPMs down to lowest (i think about 700 RPM), using a fairly fine tooth blade, the band saw went through the brass like a hot knife in butter. I was totally in awe that is was this easy. I wish i would have thought about the band saw first.
As far as curling with a grinder, i would take the matching sets. Wether it be the 2 steering rudders, 4 flankers or props. I would clamp them together with a c-clamp and grind them smooth on all sides. I guess with the heat that generated and the pressure i was applying the bottom piece in the clamped set it would always bite the grinding wheel (using bench grinder) and curl downward. I was able to elimate most of the bent pieces that i did have by placeing on concrete floor and tapping with rubber mallet. the only grinding i have left to do is the props. the rudders are pretty much done. Not sure i might put a polish on them.
Old May 05, 2006, 02:07 AM
Treetop is offline
Treetop's Avatar
Joined Feb 2004
The props, i finally thought about it, i have a shopsmith w/ bandsaw attachment. Turned the RPMs down to lowest (i think about 700 RPM), using a fairly fine tooth blade, the band saw went through the brass like a hot knife in butter. - mitch
That is sure the way to go, unfortunately most bandsaws dont allow turning down the speed. On some you could switch out the pulleys I guess.
Old May 12, 2006, 11:58 AM
Joined Jan 2006
Sloooow progress
About finished with stuffing boxes and props
Made small stuffing boxes for rudders, but i'm not sure if i even need them.
The top of the rudder tube will be at about water line.
Still need to pitch my homemade props.
Old May 13, 2006, 07:45 AM
wingnut163's Avatar
Newburgh New York
Joined May 2005
Please Guys Do Not Grind Grass On The Bench Grinder Unless You Have The Right Wheel For Nonfress Metal. The Wheel Will Load Up And Can Blow Up In Your Face.
I Am A Machinest Ad I Have Seen It Happen. You Would Not Want To See It.
They Make Wheels For Brass And Such, Please Use Them.
attempt at mounting a cam on twinstar Beige Foamies (Kits) 2 Mar 05, 2002 09:25 AM
Attempt at video and some night flight video(soarstar) joemi Electric Plane Talk 0 Nov 10, 2001 01:29 AM
3rd attempt at home built LuckyArmpit Beginner Training Area (Aircraft-Electric) 10 Nov 09, 2001 09:01 PM
First attempt at Zagi video (streaming).. 5teve Electric Plane Talk 3 Jul 22, 2001 08:10 PM
