My best guess is that the lamination/skin had started to 'part' fractionally from the foam on your flaperon. The speed of the launch with the wind assisting will have them subsequently peeled away the rest. The tearing up on the the mainwing would have been due to the "effective" massive down flaperon on the wing effect, pushing the flaperon surface violently up and causing the tear effects.
What I /do/ find interesting is that it looks like it happened on both front-corners of the flaperon, as apposed to just one. I believe by the looks of it that the skin didn't go into the notched section of the hinge, this is a weak point for skin/foam bonding. To prevent this there should be either a thin layer of tape or other such skin going down into the hinge notch and over the exposed skin/foam bond. Paul. |
Latest blog entry: What a change of life. No more R/C.
On further examination I'm going to speculate that the delamination started at the root, pulled off quite a bit of skin then the drag effect pulled it back along the length of the wing inwards again to the tip.
I'd say that the bond between the foam and skin had been degraded somehow, either due to an unfortunate/bad cure/bagging, or due to exposure/wear. How long have you had the wing? |
Falls Church, VA
Joined May 2004
Actully, I think I'm going to abstain here, because the plane was in a fairly major crash before I bought it. A mid-air at a contest, and if I recall it nosed it pretty big time. In fact, I think it was one of those where the two planes tangled, and the pilot of this plane ended up following the wrong plane out of the tangle while this one went off on it's own, deadstick! Man, I dread having that happen to me. At any rate, there was wing damage along with fuse crumpling, etc,etc - the things you would expect for a nose-in. That being said, I don't want people to skim this thread and get an undue impression that I'm questioning the quality of the original build.Additionally, I was at that contest, and I'm friends with the person who owned it for more than a year before he sold it to me. He's an aggresive, competitive pilot with super throws, and he's never had any problems with it. And I think he would have told me if he had since he was selling it to me and told me about anything he thought might be wrong with it. I'm confident this wasn't an original quality problem. Now whether that crash had some lasting effects, that's a good question. -Charles |
Germantown, Maryland
Joined Apr 2004
I would say that prior damage could have been a factor in the crash. If the flaperon skin was loose and air got under the loose skin during a high velocity launch then this could lead to the entire skin peeling off the flaperon. The plane would be expected to do some crazy, uncontrolled maneuvers during the time that the skin/flaperon parts were in the process of separating from the wing. The partially delaminated skin on the wing bottom that is visible in the pictures is typically what you see from the heavy impact of a crash and I suspect that that delam happened as a result of your recent crash.
The moral of the story is that you should look for loose skin (on any model) and fix it before doing any high speed launches. That would prevent the type of crash you experienced. Fortunately it looks like your model is fixable as explained earlier in this thread. In keeping with everyone's wish to avoid having people skim this thread and get undue impresions; I'd like to point out that the wing in the pictures is clearly not a TabooGT. All production TabooGTs have the logo on the right wing and the tip shape is different. In keeping with the thread title, "DLG detectives", a quick reading of the second to last paragraph of post 18 in this thread should give a big clue as to where this DLG came from. |
Falls Church, VA
Joined May 2004
At any rate, I plan on attempting the repair this week sometime, so I'll let you guys know how it goes. I need a plane to fly at the BASS contest this upcoming weekend, I've already sent in my $30. ![]() -Charles |
| Thread Tools | |
| Discussion There is something wrong with this picture. | rcjetpilot | Life, The Universe, and Politics | 39 | Aug 28, 2006 09:24 PM |
| Is there something wrong with this Rx pack | Frankd1 | Batteries and Chargers | 2 | Jun 29, 2004 11:05 PM |
| Question Is there something wrong with my Astro deluxe? | EP heli freak! | Batteries and Chargers | 9 | Nov 28, 2003 03:21 PM |
| Is there something wrong with My Kokams 402 charger? | Fredrik W | Batteries and Chargers | 5 | Feb 19, 2003 01:03 AM |
| Is there something wrong with my RX? | Steve Fehr | Electric Plane Talk | 6 | Sep 27, 2001 09:41 PM |
