Old Jul 09, 2002, 11:30 PM
erunway is offline
Find More Posts by erunway
Kuala Lumpur, Malaysia
Joined May 2002
My TM mtor mount broke! What to do???
I fly my TM into the tree and while retriving it from the branch of the tree,
it fell straight into the ground! The cowl and the motor mount broke!
Can anyone help? Is there anyother way then to drill the piece of spruce out?
Thanks...
Erunway
erunway is offline Find More Posts by erunway
Old Jul 10, 2002, 12:07 AM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Many of us have broken the motor stick in our Tiger Moths.
You can cut out the broken stick and glue in a new one with expanding polyurethane glue as shown in this thread.
Or, you can make a removable stick that can easily be replaced if it breaks, as shown here.
Or, you can make a more elaborate adjustable motor mount, like this one.
Good luck -- you'll be flying again soon!
galloping gimp is offline Find More Posts by galloping gimp
Old Jul 10, 2002, 09:23 AM
FX1SUB is offline
Find More Posts by FX1SUB
Green Member
FX1SUB's Avatar
NJ
Joined Mar 2002
epoxy it back on!
The easiest thing to do is to Epoxy it back on. Mine had a pretty jagged brake about 1/2 and inch from the fuselage... so I put some 5 minute epoxy on both ends of the stick and held them in place (for 5 miutes) and it's as good as new. Hope this helps.
Joe
FX1SUB is offline Find More Posts by FX1SUB
Old Jul 10, 2002, 08:34 PM
erunway is offline
Joined May 2002
Thanks for the info guys.....
Between that, I also broke the cowl and made a new one out of
coke botttle...
Erunway
Old Jul 10, 2002, 08:42 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Erunway
Gust of wind blew mine of table and broke the mount stick also.
It was a jagged break and went right back together good as new with Med CA ( foam friendly )
Stronger than new. Elemers ProBond (water cleanup) would probably be even stronger.
But takes overnight to dry.
New cowls are available as well as other parts I hear.
Dave
DaveW is offline Find More Posts by DaveW
Old Jul 12, 2002, 12:36 AM
erunway is offline
Joined May 2002
Hi DaveW,
For the cowl, it would take a few weeks before I can get it ...
I bought my TM from Aust. In Malaysia, there's none...
That's the reason why I have to make my own out of coke bottle.
The material of it are much stronger and it only weigh a lil more...
Erunway
Old Jul 12, 2002, 05:56 AM
ronnath is offline
Find More Posts by ronnath
ronnath's Avatar
Iowa
Joined Oct 2001
DaveW:
what's Med CA?
ronnath is offline Find More Posts by ronnath
Discussion My Ikarus Yak 54 Video- What do you think? VictoryRoll-91 3D Flying 5 Apr 22, 2007 06:57 AM
Discussion My Berg has batter on it.... what to do? KillerAir Castle Creations 5 Sep 20, 2006 06:39 AM
arugghhh !!1 my throttle is on the wrong side what do i do ... rumplestilskin Radios 6 Jan 02, 2005 07:40 PM
i wanna to change my sky vector for a helichopper what do u think about ?? captain riso Beginner Training Area (Aircraft-Electric) 3 Oct 23, 2004 12:55 PM
Elevons flap when my wing goes very fast? What to do? I FO nut Foamies (Kits) 20 Nov 22, 2003 02:41 AM
