Old Jul 09, 2002, 02:58 PM
eromero is offline
Find More Posts by eromero
Joined Jun 2002
LiPoly Battery charger schematic
Does anyone has a schematic to build a simple battery charger for the Lithium Polymer cells?....They require 4.2 volts at 140ma
This should not be difficult...
eromero is offline Find More Posts by eromero
Old Jul 09, 2002, 03:02 PM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Good timing. I just read the info at the following web site, and it should give you a real good overview of what you need, though he stresses that his experience is with Lithium "Ion".
http://www.flyelectric.ukgateway.net/lithium.htm
I actually bought a supply from WildRC, but HL seems to sell the same supply. Both are in the mid $20 range, and handle 1 or 2 cells.
Good luck,
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Jul 09, 2002, 04:06 PM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
If you have access to RC MicroFlight there was an article on Li cells and a charger schematic. It was around the beginning of the year. I emailed the author for some advice on altering the design for different size and number of cells but got no reply.
Dave W.
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jul 09, 2002, 05:25 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi,
this is a circuit like I use. The first LM317 works as a constant current source. The second one works as a voltage regulator. Charging termination has to be done by hand when the current has gone back to 0.05-0.1C (see cell manufacturers specs). So don't go away while charging. This is the drawback for the circuit being so cheap and easy.
The resistor values:
R1=1.25V/Icharge (~3.3Ohm/1W for 830's Qualcomm, ~8.2Ohm/0.5W for 140's)
R2=1kOhm
R3=1.5kOhm
R4=2.5kOhm spindle trimmer
Use a good (exact) voltmeter to adjust the output voltage to 4.2V without load. Don't charge more than one cell at a time with this simple design, as there is no security against charging the cells unbalanced.
You may burn down your house if overcharging Li-Ion cells, so if you don't know exactly what you are doing, don't do it. I am not responsible for any harm or damage happening with this circuit. People who know what they are doing will know which pins of the LM317 to use where.
Remember, charging termination has to be done by hand when the current meter in line with the cell shows a value below 0.05-1C (dependent on cell manufacturers steps). So don't go away when charging.
People who want automatic termination should buy a ready-made charger.
jberg is offline Find More Posts by jberg
Old Jul 09, 2002, 06:16 PM
NightSwan is offline
Find More Posts by NightSwan
Hmm, kerosene... :)
NightSwan's Avatar
Weert(LB) - the Netherlands
Joined May 2002
the charger at http://www.shdesigns.org/lionchg.html can also easily be
modified for 4.2V (single cell) and less amps.
To lower amperage, increase the value of R1.
R1 = 0.65V/max_current (approximately)
Adjust the values for the potentiometer and resistors in series with it to
lower the output-voltage.
The charger works great on my qualcomm 2-cell packs.
For a charge-graph see my post in the modelling-science section :
http://www.rcgroups.com/forums/showt...threadid=50838
Total cost of the charger should be under 5 bucks.
NightSwan is offline Find More Posts by NightSwan
Old Jul 10, 2002, 01:34 PM
eromero is offline
Joined Jun 2002
Battery charger schematics
Hey..thanks for the help.....i also found some schematics while i was looking for some lectronic components....if you take a look ant the datasheets of this operational amplifiers you'll find some charger designs in the application notes...just download the datasheets for the following OpAmps. LM350 & LM317...you can find them in the National Web page..www.national.com
This designs are very simple...and they do work....i found also that there are specific IC to charge Lithium Ion batteries..and they cost only 2 or 3 dollars....you can find them in National too...
Old Jul 29, 2002, 11:54 PM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
I built a charger from the schematic NightSwan suggested, seems to work fine. I use it for my Kokam 140 Li-polys
Trizza is offline Find More Posts by Trizza
Off Site Ebay Common Sense RC Lipoly Battery Charger mumblety-peg Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 19, 2006 10:33 AM
FS 3S 1100 Lipoly battery and charger mlehman Aircraft - Electric - Airplanes (FS/W) 3 Dec 10, 2004 07:44 PM
1-3 cell, 300-1500mA LiPoly/LiIon charger schematic NightSwan Batteries and Chargers 15 Oct 26, 2003 12:44 PM
Li+ battery charger with DC-DC converter schematic Takao Shimizu Batteries and Chargers 0 Feb 16, 2003 08:33 AM
High Capacity Li+ Battery Charger Schematic Takao Shimizu Batteries and Chargers 4 Nov 09, 2002 07:04 PM
