Old Jul 09, 2002, 01:17 PM
Graeme is offline
Find More Posts by Graeme
Joined Jun 2002
1/6 scale SIG CUB...will it fly?
Hi,
I have been building a 1/6 scale SIG CUB. This is my first attempt at a plane. All I have left to do is complete the radio equipment installation, engine & associated and cover the plane.
My problem is this...while the wing looks good and straight the fuselage has some bends and twists in it. This cause the elevators to be at a slightly different angle than the wing, and the cabin area is like a parrallegram when viewed from the front down the fuselage axis. The angles I am talking about are 1 or 2 degrees to about 5 degrees. I have very little dihedral on the wings - I am making it a 4 channel CUB.
Will this cause a big problem? Anyone have experience with this kit?
Graeme
Graeme is offline Find More Posts by Graeme
Old Jul 11, 2002, 03:34 AM
flyfalcons is offline
Find More Posts by flyfalcons
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
It should fly okay; you may want to have an experienced modeler look it over before you fly it though. Cubs fly funny enough as it is so you probably won't notice the slight mis-rigging.
flyfalcons is offline Find More Posts by flyfalcons
Old Jul 11, 2002, 11:44 AM
Graeme is offline
Joined Jun 2002
I'll have a guy a a local shop have a look at it before I cover it.
Cubs fly funny? How so?
Graeme
Old Jul 11, 2002, 03:48 PM
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
Model Cubs fly funny by design. I am flying a Great Planes cub with a 76" wing so it is about the same size as yours. It is very unstable in yaw, requiring constant minor corrections to hold a heading perfectly. I don't know if your plane has "barn door" ailerons but mine does and even with some differential the planes has tremendous adverse yaw, so my turns are made with a 50-50 mix of rudder/aileron. I'm not running a computer radio on my cub but if I were I'd put about a 50% mix of aileron-rudder. Don't get me wrong, I enjoy the cub as much as my hopped-up Extra, but to master the plane you must constantly use all four channels. Have fun.
Question Any tips on biulding a 1/6 scale piper cub kit? bouncy-boy Scale Kit/Scratch Built 3 Apr 11, 2007 02:51 PM
Found 1/5 SCALE Sig Cub kit wfortney99 Aircraft - Fuel - Airplanes (FS/W) 4 Jun 18, 2006 08:58 PM
For Sale 1/4 Scale Sig Cub UNFINISHED Zagabond Aircraft - Fuel - Airplanes (FS/W) 1 May 17, 2006 09:49 PM
Aerotowing with 1/4 Scale Sig Cub M. Clarkson Scale Sailplanes 14 Nov 15, 2005 04:54 PM
Question 1/4 Scale Sig Cub Drew's M-1 Fuel Plane Talk 1 Dec 12, 2003 08:20 AM
