Old Apr 22, 2006, 09:48 AM
drbyrnes is offline
Find More Posts by drbyrnes
Joined Mar 2006
Help!
Wing struts for Sr.Telemaster ARF
I just bought a Sr.Telemaster ARF from Hobby Lobby. Everyone recommends using the wing struts. Any suggestions out there on a good way to connect them to the airplane? I'm thinking of using heavy duty clevis attachments to a brass horn. Hobby Lobby will sell the hardware, along with a lot of other stuff I don't need, for over $40!! Their customer service and tech departments were not accomodating as far as me buying just the hardware. I'll never buy from them again. Thanks!
drbyrnes is offline Find More Posts by drbyrnes
Old May 08, 2006, 01:19 PM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
I bought some airfoil shaped tubular aluminum for the struts, in exchange for the heavy supplied wood ones.
For attachment, I used the large Du-Bro pinned hinges. Slip one half of a hinge into the ends of the aluminum struts, then flatten the strut down over the hinge. Drill two or three small holes through the strut ends and hinges. Use short screws with nuts to cinch everything together.
Simply screw the other half of the hinge to the flat strut mounting points on the wings and fuselage. I left the hinges on the wing end of the struts permanently pinned together, so the struts stay attached to the wing.
I removed the pins from the fuselage ends and substituted large "T" pins for the hinge pins. These are attached to the landing gear struts with a short piece of elastic cord so the pins won't get lost.
To install the struts, simply line up the "eyes" of the hinges and slide the pins into the place to lock the struts in position.
I also converted my wing to one-piece, using a false center plywood rib and wing bolt hold-downs.
There is more information about this on a thread on the electric sport planes forum. Here is the thread, in case you haven't seen it. http://www.rcgroups.com/forums/showt...t=410957&pp=25
By the way, this is a great plane, I'm sure you will enjoy it.
AmpAce
AmpAce is offline Find More Posts by AmpAce
Sold Sr Telemaster Arf cainebean Aircraft - Electric - Airplanes (FS/W) 1 Jan 05, 2006 07:58 PM
Question Wing struts for pico Stick FD Bob Nichols Parkflyers 7 May 02, 2004 03:37 PM
Mini Telemaster ARF for sale! Check it out! CAFplanekid Aircraft - Electric - Airplanes (FS/W) 4 Apr 18, 2004 09:35 PM
Wing Struts for the GWS Tiger Moth UWBob Foamies (Kits) 0 Oct 15, 2002 03:03 PM
SOurce for TM wing Struts Carnifax Parkflyers 0 Jul 24, 2002 01:06 AM
