Old Jul 30, 2001, 09:30 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
A-10 Kyosho Motor Conversion Battery Recommendation.
I am building the K&A A-10 that sparked all the stink about KP44's.
SO...
I went with the Kyosho motors and seperate Fans. They are supposed to be wired in Parallel...
What batteries should I try?
CP1300's? or 800AR's
Thanks for your help
Kirby
kepople is offline Find More Posts by kepople
Old Jul 31, 2001, 01:21 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
They're close to the same weight, I'd go with the CP1300's.
GregG is offline Find More Posts by GregG
Old Jul 31, 2001, 10:04 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Definitely go with the new CP1300s. Diversity Model Aircraft has them, there's a new ad in the Sept S&E Modeler magazine. www.flydma.com
Weight quoted is 35 grams, dimensions 23 x 27mm. They are short and squat, so the'd be much easier to fit into the fuselage than the tall and skinny 800ARs, which weigh 36 grams each.
Of course, 600AEs weigh 22 grams a piece, so you'd have a lighter all up weight. I don't know if anyone has flown the micro A-10 with larger cells, may have to do some searching on that. There's also 1000mah NiMH batteries that are the same size and just a bit heavier than 600AEs. DMA carries them as does www.batteriesamerica.com. You'd need to add an extra cell to make up for the lower voltage but you'd still have a lighter pack than the 1300s.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jul 31, 2001, 10:48 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
10x500AR/600AE is the recommended pack. 1300s would seem to add a lot of weight and 11+ cells often goes beyond ESC's cell count.
jrb is offline Find More Posts by jrb
Old Jul 31, 2001, 09:51 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
My Dare A-10 with Johnson 180 motors in parallel does well on 10X600AE and that is what I plan to use on my next pair of KP-44 fans and the Kyo DMC motors. I do not beleive the 10X800ARs will fit very well in the K&A A-10, and the wing loading will go up noticably.
Keep it light!
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Jul 31, 2001, 11:22 PM
kepople is offline
kepople's Avatar
Joined Jun 2001
Thanks for the input. I ordered to CP1300's today. hope they fit...
Wanted Looking for power 10 or motor for .20 conversion wakeboarder2342 Aircraft - Electric - Power Systems (FS/W) 2 Mar 04, 2007 12:02 AM
Discussion Need motor/esc/battery help for a conversion--in--> johnnybronco Electric Warbirds 0 Oct 19, 2006 06:21 PM
Discussion battery recommendation on speed 400 motor kogibankole Electric Plane Talk 8 Apr 06, 2006 12:00 AM
540 mabuchi motor, battery recommendation djgorman23 Power Systems 1 Jan 25, 2005 07:28 AM
Stinger 10/gas motor/suitable for electric conversion bpu6999 Aircraft - Fuel - Airplanes (FS/W) 3 May 30, 2002 09:43 PM
