This thread is privately moderated by Malc C, who may elect to delete unwanted replies.
Old Nov 02, 2007, 06:19 PM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
What version of the interface have you built ?
What do you mean "i cant do this work" - do you mean you've built one and it doesn't work, or do you you mean you can't program the chip ?
Does the DX7 output in PPM mode and not PCM - check the settings of the transmitter
Malc C is offline Find More Posts by Malc C
Old Nov 02, 2007, 08:34 PM
JoMebold is offline
Find More Posts by JoMebold
Joined Mar 2007
Malc I have built the interface of Alessio: RC Joystick NG≤ 3.3.3 and it work great with a Futaba radio. But when I connect the interface to Spektrum DX7 it doesnt work.
I cant find where in the Spektrum I can change the signal output to PPM.
Dou you know if this is posible? This interface is Spektrum compatible?
Josť Luis
JoMebold is offline Find More Posts by JoMebold
Old Nov 03, 2007, 03:56 AM
Malc C is offline
UK
Joined Oct 2003
Personally I don't know if the Spektrum has a PPM or PCM output from its trainer port, orr how to change it if it has this option.
If the interface works with your Futaba then there is nothing wrong with the interface as it will be decoding the PPM signals just fine, which would suggest that there is some compatibility issue with this model of transmitter. It also might be worth dropping Alessio a mail to see if he can help
Old Nov 04, 2007, 10:29 AM
JoMebold is offline
Joined Mar 2007
I tested my Spektrum with PPJoy + SmartPropoPlus (SPP) and work.
This is what I see:
In the SPP I put in Modulation:
Type: PPM (Generic)
Now for the Futaba in Shift Polarity I put Positive and it work.
For the Spektrum I put Negative and it work.
This is the only diference: Positive/Negative.
This is simple for our interface.
Supose in Futaba
pin 1 is GND
pin 2 is Signal
For the Spekturm
pin 1 is Signal
pin 2 is GND
All in the PPM imput.
And all works perfectly.
Thanks for all and I hope that I wrote will be helpful for someone else.
Josť Luis
Old Nov 04, 2007, 05:01 PM
Malc C is offline
UK
Joined Oct 2003
I just wish to add that anyone experiencing issues should download one of the windows based oscilloscope applications such as http://sillanumsoft.altervista.org/download.htm
Hook up a lead from the sound cards line or mike input using screened cable, and connect the screen to whichever pin you suspect as being GND ( if its a round DIN type connector then this can be the circular outer shield - if its the square fitaba type then pin 2 should be GND) - then probe each of the pins to see if you get a trace
(more pin out info at http://www.mftech.de/buchsen_en.htm )
The trace should look something like
When you have found this trace, then make the interface connection lead to the same configuration (ie GND to GND and signal to input) and see what you get.
Old Nov 25, 2007, 07:37 PM
yanglu77 is offline
Find More Posts by yanglu77
Joined Oct 2007
what can I Revision the joystick name?
yanglu77 is offline Find More Posts by yanglu77
Old Nov 26, 2007, 03:21 PM
Malc C is offline
UK
Joined Oct 2003
1) - What version of the joystick are you building ?
2) - Check the hardware as it seems that the device has not been recognised
Old Nov 28, 2007, 08:55 PM
yanglu77 is offline
Joined Oct 2007
thank you
I think my hardware is ill
Old Jan 05, 2008, 05:19 PM
JDill is offline
Find More Posts by JDill
JDill's Avatar
United States, MI, Traverse City
Joined Nov 2004
Is there a parts list that goes with the RC-USB8ch schematic? I did make up a list from looking at it but had some confusion. Most of the components are straight forward but I didn't understand 2 designations, 220R (R2) and 1K5 (R3).
Jeff
JDill is offline Find More Posts by JDill
Old Jan 05, 2008, 06:21 PM
Malc C is offline
UK
Joined Oct 2003
Hi Jeff,
The R designation is for Ohm, so in this case the 220R is a 220 Ohm resistor. The 1K5 means a 1500 Ohm (or 1.5K).
Hope that helps
Old Feb 13, 2008, 02:04 AM
fred73 is offline
Find More Posts by fred73
Joined Jun 2005
RC USB not working
Hi
I've built the RC Joystick NG2 and its is being recognised by the windows xp and game controller. i also have the led light on , on the circuit, but its not receiivng any input from my radio.
I ahve tried swap the radio output wires but still not working. I have both an old futuba 4channel and a DX7 spectrum.
Is there anything i can check. i will try also build the Malc C one to make sure i got it working i guess.
I have an old rc adapter but 4 channel only and it works fine with both radio, and im looking to fully benefit of the dx7 channel
Your help will be greatly appreciated
All spare parts on the circuit as exactly as specified
fred73 is offline Find More Posts by fred73
Old Feb 13, 2008, 11:43 AM
Malc C is offline
UK
Joined Oct 2003
The only suggestion would be to varify that you are getting a PPM signal into the interface. Simple way is to download one of the free soundcard based windows scope programs and probe the pins on the trainer port of the Futaba. It should be pin 2 on the DIN plug (if its the old round type). Other than that, check the board for track breaks, or shorts, and make sure all transistors are correctly mounted as some packages from some manufactures use different layouts (eg ECB EBC)
Old Feb 15, 2008, 10:46 PM
fred73 is offline
Joined Jun 2005
Hi Malc C
Hi
I've build your version of the usb adapter and with my futaba 4 channel its working fine but not with my dx7 spectrum.
The led goes on and it works for 3 seconds and then nothing. I double check the mono jack, cable etc all seems fine, plug my futaba and its does work with it.
As u previously adviced i did download and use the windows oscilloscope and there is definately a ppm signal
Is there any issue with dx7 do i need to add a resistor etc for it to work
Fred
Old Feb 16, 2008, 02:48 AM
Malc C is offline
UK
Joined Oct 2003
Hi Fred,
Glad to hear that you have the interface working, at least with the Futaba. This confirms that the programming of the PIC worked well, and that your building of the board was sound.
Regarding the issue with the DX7, the only things I can think of is that either its sending pulse coded signals rather than pulse proportional, or the timing of the sync signal is out of range for the interface. Just to go over the development, I use a JR 3810 which has 8 channels which, along with Marks Futaba TX was used for testing. But since then (its now been almost two years since we took Allessio's code and modified it) there has been an explosion of RTF models and new transmitters, and thus we can't guarantee compatibility with some of the new technology.
You say you've scoped the output, try comparing the two outputs to see if they look the same or if the dx is repeating the signals quicker than the futaba. My recollection is that the interface is looking for a refresh every 20ms, if the dx is refreshing a ms or two sooner or later then this could be the issue. Maybe Mark could chime in here as he was the main drive behind the re-coding.
Old Feb 16, 2008, 11:21 AM
benavide is offline
Find More Posts by benavide
Joined Feb 2008
Hello
I have realized the assembly of the interface with the chip 16c745, have recorded the file RCjoy-USB-Futaba.hex, the crystal of 6Mhz and it does not work, the PC does not detect anything on having connected the interface, any help?
Tanks
P.S. I do not speak English write with a translator
benavide is offline Find More Posts by benavide
Question JW24RC - Model RC to USB joystick converter chip skratchbilder Radios 0 Dec 16, 2004 07:43 PM
Quattro USB adapter: RC, Analog Joystick -> USB PiNa Simulators 2 Sep 22, 2004 01:09 PM
Radio Shack USB joystick adapter. HankF Simulators 0 Jul 23, 2003 01:46 PM
