This thread is privately moderated by Malc C, who may elect to delete unwanted replies.
Old Dec 31, 2009, 11:06 AM
Telemachus is offline
Find More Posts by Telemachus
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
If it works, then a cheap USB to serial adapter should do it for you.
http://cgi.ebay.com/USB-SERIAL-DB9-R...ht_2915wt_1056
http://cgi.ebay.com/USB-to-Serial-DB...#ht_2932wt_928
Telemachus is offline Find More Posts by Telemachus
Old Dec 31, 2009, 03:04 PM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
Originally Posted by Norman Adlam View Post
Thanks for the info.
Looks like I've got to get a new PIC programmer. My last one was a serial port one, and since upgrading the PC I now need a USB one! *sigh*.
It's Christmas - treat yourself
Malc C is offline Find More Posts by Malc C
Old Dec 31, 2009, 03:28 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Cool. Where, and how much?
Old Dec 31, 2009, 04:31 PM
Malc C is offline
UK
Joined Oct 2003
$139 - http://www.mikroe.com/en/tools/easypic6/
I've got the previous model
$129, - main differences are SM components on the V6, COG display and keypad buttons, whereas V5 has 7-seg LED, and no dedicated key pad buttons, but has two AD pots
the touch screen is extra as are the 2 x 16 LCD.... but they aren't that expensive
There are also loads of plug on boards from $5 up so you can do basically anything you want...
Mikro also do compilers and a free (up to 2K code size) BASIC, which is fairly easy to work with - worth spending some time browsing the site
Old Dec 31, 2009, 04:42 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Way cool.
I think my bread board was $17 and the programmer was $10... have served me well for about 4 years, but that would be a treat.
Old Jan 05, 2010, 08:55 AM
Norman Adlam is offline
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Hmmm... looks like the problem is more related to laptops USB ports. The interface doesn't get recognised on my Sony (Windows 7) or my friends Dell (XP).
Any more ideas from people regarding getting it running OK on laptops, or why it seems so finicky?
Update: Well it seems to be related to whether you have programmed 4-axis or 8-axis joystick. Maybe it's the USB speed that's the problem? Anyway, having re-programmed as a 4-axis joystick Windows 7 now recognises the interface! .
You are supposed to be able to calibrate USB Joysticks in Windows 7 - but I can't find an actual "Game Controller" tab in Device Manager (Windows 7 Home Premium). There is a HID-Game Controller one (now) - which doesn't allow any calibration, but it does still seem to work.
Just got to see if it remains reliable!
Norman Adlam is offline Find More Posts by Norman Adlam
Last edited by Norman Adlam; Jan 05, 2010 at 11:41 AM. Reason: Added update status.
Old Jan 05, 2010, 11:41 AM
Malc C is offline
UK
Joined Oct 2003
Norman, have you plugged it back in to your XP desktop machine to confirm that it's working OK. If so then I guess it's either down to windows power management software, or that on the two machines the current draw is taking the 5V supply down and the pic can't function.
Googled USB ports not functioning and came up with lots of hits:
Most seem to be in relation to hub management under XP though
http://support.microsoft.com/kb/817900
Old Jan 05, 2010, 11:44 AM
Official Old Git!
Hampshire, UK
Joined Sep 2000
Malc,
Yup - it had still been OK in XP - and I had also found the USB Power Management 'stuff' on the Net and tried that on the Lappy - but it made no difference.
Many thanks for looking for me, though! Much appreciated!
Old Jan 05, 2010, 11:53 AM
Malc C is offline
UK
Joined Oct 2003
No worries,
The strange thing is I can't see that the interface would draw that much current that it causes the thing not to work. Do you have a meter so you can check the voltages that the PIC's receiving, on both the XP machine and your laptop. You might also want to check the current draw at the same time
Old Jan 05, 2010, 12:16 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
This has strictly got to be a Windows 7 thing, perhaps there is not a proper driver installed for Hi-Speed (USB 2.0) drivers. The main difference between the 4 axis and 8 axis version is that the 8 axis is only made for hi-speed USB.
Since you know the USB port itself is capable of doing hi speeds, it must be a driver issue within Windows.
Did you try it on a Windows 7 desktop?
Old Jan 05, 2010, 12:22 PM
Malc C is offline
UK
Joined Oct 2003
Don't think so...
Old Jan 05, 2010, 12:23 PM
Official Old Git!
Hampshire, UK
Joined Sep 2000
No worries,
Don't think it had anything to do with current draw etc - as reprogramming it as a 4-axis joystick got it recognised and working OK. If I get more trouble with it I may well measure such things.
BTW - it worked fine on my friends Compaq Laptop running Vista. More indication that it's software, I think.
Old Jan 05, 2010, 12:36 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
Awww... I read that wrong. I thought that you were saying that both you and your friend's laptop have Windows 7 and it wasn't working on them.
Did you use the PCB to build it, or did you direct solder your own connections? Perhaps there is a short somewhere?
You were saying that it doesn't show up AT ALL in windows, or does it say "devise unrecognized"?
Old Jan 05, 2010, 01:02 PM
Official Old Git!
Hampshire, UK
Joined Sep 2000
All nicely laid out, proper manufacture PCB etc - and has worked fine for ages (on my XP desktop).
Yeah - it didn't show up at ALL - never got as far as "device unrecognised".
Old Jan 05, 2010, 01:41 PM
Heli Humbled Daily
Riverside, CA
Joined Jul 2006
do u need 8 axis?
Question JW24RC - Model RC to USB joystick converter chip skratchbilder Radios 0 Dec 16, 2004 07:43 PM
Quattro USB adapter: RC, Analog Joystick -> USB PiNa Simulators 2 Sep 22, 2004 01:09 PM
Radio Shack USB joystick adapter. HankF Simulators 0 Jul 23, 2003 01:46 PM
