Horizon Hobby's E-Flite Brand Blade CX Micro Helicopter Review
Albert Wahrhaftig, beginning heli pilot, is amazed to find that finally, he has a heli in his hands, he can REALLY truly fly. Experienced heli pilot and hobby shop owner, also test pilot extraordinaire, Red provides great indoor flight video as well.
Length15.75"
Height:7.17"
Weight:8.0 oz.
Main Rotor Diameter:13.60"
Motors:(2) 180 installed
Battery:7.4 v 800mAh Li-Po included
Transmitter:FM 4 channel included
On-Board Electronics:4-in-1 Receiver/Mixer/ESC/Gyro installed
Servo:(2) EFLRS75 High-Speed,High-Torque installed
Manufacturer:E-Flite
Available From:Horizon Hobby
Within a reasonable driving distance from my house, there are four well-equipped hobby shops. When I started this review some time ago, each of them had ordered E-flite’s Blade CX helicopters and not one of them had one still in stock. Sold out in no time! Doesn’t that tell you something? Fortunately, the initial rush to be a Blade CX owner has abated -- or at least Horizon is keeping up with stock quantities! -- and there will likely be one waiting for you at your LHS.
As far as I am concerned, the Blade CX Coaxial Helicopter is a tiny miracle. I have 70 year old reflexes, only average skills when it comes to piloting fixed wing RC aircraft, an unwillingness to put up with the expense and complexity of the RC helicopters that have been on the market for the last several years, and, being a Mac user, no possibility of practicing with a flight simulator. Some time ago, when the helicopter bug bit me, I asked the famous Red, proprietor of Red’s Hangar One Hobbies in Rohnert Park, CA, (we have a Sherlock Holmes-Dr.Watson relationship) when there was going to be a helicopter suitable for my modest capacities. His answer was “next week.”
When I arrived the following week, there was an elegant, bright yellow copter sitting on top of its cardboard case on a display counter. Red walked over, transmitter in hand, connected the battery and proceeded to fly the little Blade up and down the aisles of his crowded shop. Then he placed the Blade in a hover, stepped back, placed the transmitter on the floor, and walked away, leaving the copter to hover unassisted. Finally, after a few pirouettes, he landed the little craft on top of its cardboard box. You think I exaggerate? Take a look at the attached video in which Red recreates his wordless sales talk. No wonder dealers can’t keep these in stock!
Not only is this beast exactly what I had been longing for, the price and quality are amazing. For less than $200, you get a "take it out of the box, charge the battery, and fly" helicopter. Nothing to build. No endless adjusting and balancing. Nothing to buy except for 8 AA batteries for the transmitter. And it is rugged.
Requires:
  • 8 AA batteries for the transmitter
  • Nothing else.
  • No really.
  • Nothing.
Contents
The Blade CX cuddled in Styrofoam trays inside an attractive cardboard box. The well designed box with a plastic handle serves as a carrying case for the copter, transmitter, and accessories, including, if you acquire them, space for spare parts. Even King Kong posing as a postman couldn’t damage the contents.
Contents:
  • A completely assembled, ready to hover right out of the box helicopter,
  • a four channel FM transmitter,
  • a 2-cell lipo flight battery,
  • a cell balancing lipo charger,
  • a packet with a screwdriver (the only tool you will need),
  • hook and loop tape for the battery,
  • some bits of double sided mounting tape,
  • and a few plastic ties.
There is also a 36 page instruction manual which every manufacturer should strive to emulate. It is the most clearly written, complete, and error free manual I have ever seen. Congratulations to the copywriter! Finally, there is a DVD (which won’t play on a Mac – one of my very few complaints) which shows what to expect of the CX.
Assembly? There isn’t any. Of course you've already read the entire manual before beginning "assembly". In case you haven't, while your battery is charging, you should look at page 11 of the instructions and make sure your Blade balances as it should. Then if you are unfamiliar with helicopters, you can start at page 21 and read how the controls work and how to trim the copter. Then, with a charged battery installed, go to page 12 and test the controls as explained there. OK. Now you are good to go.
Optionals
An optional training gear (EFLH1205) is available. I was willing to get one, but Red suggested I could get along without it, so I took his advice.
There is an optional AC transformer for the battery charger(ELFC4000). This will save you from running out to connect to your car or from having to lug a compact 12 volt battery around. I think it is a worthwhile investment.
I recommend having a few spare parts on hand:
  • lower main blade set (EFLH1220),
upper main blade set (EFLH1221)
an inner shaft with hub and main gear set (EFLH1212)
These parts will take care of the most likely victims of training accidents.
FLYING THE BLADE CX
Is the a helicopter for beginners?
The Blade CX is designed to be extra user friendly and extra stable. Want to lift off and fly around your living room? This is the machine for you (but learn in a larger space, first).
Is your Blade CX doing something weird? Let go of the sticks and it will fly itself back to stability. That’s what a beginner wants, what a beginner needs, and what a beginner gets.
The trade off, of course, is that loops, inverted flight, and other aerobatics must await your next helicopter.
From the eyes of the hobby shop owner: Red indicates, "To a seasoned helicopter pilot, the Blade CX will feel quite abnormal because it is so positively stable. Instead of continually catching it as it veers away from stability, as is the case with conventional helicopters, you need to push it where you want it to go with deliberate control inputs and it then goes right along willingly. It is by far the easiest copter I have ever flown and is the first I would recommend without reservation to a complete beginner."
From the photos and video, you can see what an experienced pilot can do with the CX, so ... how did yours truly, old fumble fingers, do?
Well, for a guy like me there is a learning curve involved. The fact that from the beginning I was trying to learn to fly indoors in a cramped space with a low ceiling didn’t help matters. It took two flights a day for over a week before I had hovering and basic movements down pat. During that time I did chip and replace a couple of blades, but that’s all. On the whole the CX survived my “learning events” unblemished. I bet this stage will take most new owners considerably less time than it took me, and now I am at the point where the CX is my little friend.
Early in the morning when the air is still calm, I take out my heli and fly it as I stroll up my long driveway to go fetch the morning paper, tuck the paper under my belt, and fly the copter back down the drive, through my garage, and park it on my workbench. And what a joy it has been to be able to fly something indoors on stormy days. Once you get the hang of it, this little beast can be flown with great precision.
Advice for first time helicopter flyers
First of all, E-flite recommends that you make your first flights indoors in space at least 20 by 20 feet and with a high ceiling. I didn’t have a space like that available, and the lack of one slowed my learning curve drastically. In your house in a typcial room, the rotor wash from those contrarotating blades will bounce off the walls and off furniture and buffet your helicopter all over the place.
The Blade CX is very sensitive to even the slightest breeze. That’s why you don’t want to fly outdoors at first. Even indoors, drafts from open windows, a heating duct, or even your dog scratching fleas will destabilize the copter. In the beginning, stick to still air.
Just as soon as possible, get your helicopter up to the level of your belt. Below this altitude, the helicopter is bounced around by the wash from its rotors; above it, things smooth out.
Try not to over control. This copter pretty much wants to stay in a stable hovering position. Once it is trimmed, if you want it to do something else, you have to make it do what you want.
If the helicopter is doing something you don’t want – moving to the left, for example, so you have to keep holding the right hand stick to the right – set it down and “click” in some left trim, then take her up again. Trim only one control at a time. Repeat until your helicopter holds a hover.
Many people find that if they fly for about a minute, set down, unplug and replug the battery, and then take off, the helicopter is in much better trim. This apparently resets the electronics in the little black box to compensate for the helicopter’s warmed up condition.
At this point, most of you will be flying just fine, but some of you, like me, will find the going a little slow. What to do? Do what Olympic atheletes do. Visualize!! No kidding. I know about this stuff and it works. Sit in a comfortable chair with your transmitter in your hands. Close your eyes. Move the left stick (throttle) forward. “See” the helicopter rise in the screen of your imagination. Pull the stick back. “Watch” the helicopter settle. Repeat a few times. Now let the helicopter rise and try another control. Watch the helicopter move. Try the controls one by one, all in your mind’s eye, and then try using them in combination, as for instance, left stick forward to rise plus right stick forward to move forward, plus left stick to the right to point the nose to the right, and so forth. It works at the Olympics, and it’s going to work for you.
Finally, to seek advice, help, or other information about flying, hopping up, repairs, and other modifications, or just to see what other CX flyers are up to, log on to the to the Multi Rotor Helis discussion thread at RCGroups.Com. There are literally hundreds of messages about this one helicopter.
Flight Video
Editor's note: If you do not have the most recent quicktime software, the video may not play for you. It's worth downloading, HERE, to enjoy this fun video! Sorry, I could not get my conversion software to convert it over to .wmv for the windows users.
No question about it. The Blade CX is the answer to a helicopter beginner’s prayers. Ready to fly out of the box, agile, reliable, and rugged with complete instructions and everything but the AA cells included at an astoundingly low price, it couldn’t be more perfect. In short, the Blade CX flies well and is an ideal beginner’s first helicopter. For experienced pilots, it is a reliable and compact go-anywhere machine to fly around your motel room on business trips and the like.
Old Apr 21, 2006, 01:49 PM
Red is offline
Red
Find More Posts by Red
Red
Red's Avatar
Santa Rosa, CA
Joined Apr 2002
Nice article Al. Yikes...looks like crowded flying in there
Red
Red is offline Find More Posts by Red
Old May 30, 2006, 02:15 AM
xswamix is offline
Find More Posts by xswamix
Joined May 2006
Blade Cx Training Wheel Effect To Heli Pilots
The Blade CX is super fun to fly and has a fast learning curve. Unfortunately, I found that the quick learning curve was a crutch when transitioning to the Blade CP. The Blade CX experience actually hindered the learning curve for the Blade CP much like training wheels on a bike taught you to lean the wrong way but got you up and riding fast. The basically complete lack of anti-torque rotor training with the Blade CX becomes a rude awakening when transitioning to the Blade CP.
xswamix is offline Find More Posts by xswamix
Article Horizon Hobby's E-Flite Brand Brio 10 Pattern Electric ARF Review rc2xs Sport Planes 28 Jun 10, 2009 10:26 PM
Article Horizon Hobby's E-Flite Brand Cessna 182 ARF Review RichN Electric Plane Talk 32 Jul 14, 2008 10:13 PM
Article Horizon Hobby's E-flite Brand Ultimate FX 3D ARF dawnron1 Foamies (Kits) 36 Sep 08, 2007 01:28 PM
Article Horizon Hobby's E-Flite Brand P-47 Parkflyer ARF Review mordib Electric Plane Talk 11 Apr 01, 2006 05:33 AM
Article Horizon Hobby's E-flite Brand Blade CP RTF Micro Heli -- Stock & Upgraded Performan Hoverup Micro Helis 4 Aug 20, 2005 11:44 PM
