Old May 16, 2001, 06:37 PM
austin9000 is offline
Find More Posts by austin9000
memphis, tn
Joined May 2001
Radio Shack 1600 NIMH's in a Zagi
Hello,
Are the radio shack 1600 nimh's a good choice in a zagi x 400? They seem good to me. Aren't nimh's better than nicads for this sort of thing?
Also, where can I find out how to build my own pack?
Austin Carpenter
austin9000 is offline Find More Posts by austin9000
Old May 16, 2001, 06:45 PM
memphis, tn
Joined May 2001
Also,
What do you guys think about this cell: http://www.aspencer1.com/showitem.asp?ItemID=10053
It is a good bit cheaper.
I read a post about people building radio shack 1600 packs for like $25, but they are 4 for $16, which doesn't add up, that is if it has the same number of cells.
Austin Carpenter
Old May 16, 2001, 07:28 PM
dwatkins is offline
Find More Posts by dwatkins
Angola, IN USA
Joined Mar 2000
RS 1600 packs are pre-packaged in 8 cells which you "remodel" They are $25. They will give less zip than 8 cell 500 AR pack just barely, but will last over 10" in stock Zagi. My Astro 020 Zagi will tear up the sky for 5" full throttle with the 1600's.
Somewhere here is a link to andy's pictures of converting the stock pack for Zagi use. Search and ye shall find.
DPW
[This message has been edited by dwatkins (edited 05-16-2001).]
dwatkins is offline Find More Posts by dwatkins
Old May 17, 2001, 10:02 AM
ChrisD is offline
Find More Posts by ChrisD
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Here's the link from my extensive library
http://eflyguy.freeservers.com/RS1420.html
It's not hard. Buy shrink wrap from www. radicalrc.com. $2 shipping. 2 1/8" is for AA square packs.
BTW - I use the RS pack in my Zagi. It has a good punch, and outlasts nicads. Not as quick as Nicads, but longer 1/2 throttle flight times. I'm no speed demon (yet), so it's ok.
ChrisD is offline Find More Posts by ChrisD
Old May 17, 2001, 03:55 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
We have some Hitec Flash 5SX in stock with HS-81 servos. I could bring it with me this weekend to Memphis where I will be attending a wedding, and save you on shipping charges. I would even swap out some HS-81MG servos if you wanted.
I think you will be very happy with a Flash 5SX, no matter where you buy it from. Highly recommended.
And by the way, those Nexcell cells will not work in an RC application. The internal resistance is too high, and they will not have enough voltage. The only 2 suitable are the Radio Shack and the Sanyo 1600 NIMH cells, with Sanyo being the better cells.
We have 8 cell Sanyo packs in stock for $24 right now on Special.
Shawn
eflightpower.com
sf_247 is offline Find More Posts by sf_247
FS: (2) Radio Shack 1600 NIMH 8 cell packs ChrisD Aircraft - Electric - Airplanes (FS/W) 2 Sep 25, 2002 05:57 PM
Hitec 55's in a Zagi? Clipless Foamies (Kits) 8 Feb 06, 2002 05:25 PM
resizing the radio shack 1600 packs Gerald Beginner Training Area (Aircraft-Electric) 5 Aug 06, 2001 12:58 AM
Adding 9th or 10th cell to Radio Shack 1600 NiMh? Balin Power Systems 1 Apr 23, 2001 03:04 AM
will a spar save servo's in a zagi?? wigham1 Foamies (Kits) 3 Apr 22, 2001 03:49 PM
