Old Apr 19, 2006, 08:18 PM
dhauch is offline
Find More Posts by dhauch
Watervliet, Mich.
Joined Sep 2003
f3b Trinity x-tail bellcrank ?
anyone have a pic of the connector you used to hook up the bellcrank ?
thought i remembered seeing some guys flying these planes in this forum.
thx,
dave hauch
dhauch is offline Find More Posts by dhauch
Old Apr 19, 2006, 08:54 PM
seeker is offline
Find More Posts by seeker
United States, NV, Henderson
Joined Aug 2004
Here is how I did it. I made a 90 degree bend in the metal part of the push rod to allow it to go around the front mounting bolt. I then bent a ninety with about a quarter inch span from the first bend. Now the rod should be pointing straight toward the back of the fuse. One more ninety back towards the bell crank with a 1/4" span and I was done. The trick is to get what looks like a square question mark. When you mount the tail you slip the push rod into the bell crank. Then install the forward bolt So it is on the side of the push rod that will lock it in place on the bell crank. I will try to get a picture up. I tried to do a Z bend around the bolt without success.
You may want to ask tim ( timming ) how he did it. As he seems to have the Trinity F3B dialed in very well.
Although the internal linkage is a very clean way to go, Tim as well as myself have gone to external linkage for better throw and less slop. Consider this while your in the build stage of the game. I ordered carbon covers from sporter ( standard and sm jelly beans) I went external on the ailerons and used a long arm on the flaps with a jelly bean cover.
seeker is offline Find More Posts by seeker
Old Apr 19, 2006, 09:10 PM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
thanks, yeah a pic would be great, even a simple drawing.
yeah, I'm bottom driving flaps for sure, might stay inside with the ailerons, and using Sporters covers.
dave hauch
Old Apr 19, 2006, 10:01 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I did a great job internally driving both surfaces, but you need to add some larger control horns for a posative, strong link. Here is a pic of my aileron install
djklein21 is offline Find More Posts by djklein21
Old Apr 19, 2006, 10:51 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
I just used a straight 90 degree bend in the wire and left it that way. Once the tail is bolted on-- if you have the bend just the right length- it can't come off no matter what anyway. Then the rudder push rod goes down the opposite side where I put a ball socket-- cut the rod out of the rudder the right length-- as the tail is bolted on--slide the rudder wire into the ball socket. Simple, and effective. FWIW
Klienster-- what the heck do ailerons have to do with the tail surfaces??
Timmig
OH!!
timmig is offline Find More Posts by timmig
Old Apr 20, 2006, 12:44 AM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
thanks guys for all your help, really appreciate it.
dave
Old Apr 20, 2006, 01:39 AM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
This
Old Apr 21, 2006, 08:29 PM
seeker is offline
Joined Aug 2004
For rudder, I just used a metric ball link that is usually soldered to a V tailrod. It fit perfectly with no slop. It just slides on the rudder rod and can't come off the bottom.
Jon
Old Apr 21, 2006, 08:51 PM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
here's how i did mine, works great.
dh
Old Apr 22, 2006, 12:42 AM
timmig is offline
timmig's Avatar
Southern California
Joined Sep 2003
That will work-- why the U shape? I just went straight in with a 90 degree bend-- a little bit of "up" kink for alignment and it was done. Flying it in the VRQ next week.
Tim
Old Apr 22, 2006, 09:33 AM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
well, starting at the carbon rod, the first z-bend is to get it around the front
fin bolt and to center it up.
next bend up is to get get it up to the bellcranck, makes hooking i up a little easier, plus keeps it from rubbing on the boom with max throws.
the last bend goes thru the bellcrank hole.
dh
Old Apr 22, 2006, 11:08 PM
timmig is offline
timmig's Avatar
Southern California
Joined Sep 2003
The pushrod runs down one side of the fuse past the fin bolt. That alone takes you around it. But looks like your's will work-- just a lot more bending then necessary. Doesn't matter-- as long as it WORKS!! I'll be flying mine at the ISR in Davenport at the end of the month!
Timmig
Old Apr 22, 2006, 11:58 PM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
Discussion Eagle F3B X-tail amzimmy Sailplane Talk 7 Aug 23, 2007 07:25 AM
For Sale Trinity F3B X-Tail Fuselage - New PDX Slope Pilot Aircraft - Sailplanes (FS/W) 8 Apr 28, 2007 12:19 PM
Sold Baudis Trinity F3B X-Tail PDX Slope Pilot Aircraft - Sailplanes (FS/W) 2 Apr 03, 2007 11:06 PM
Discussion Trinity F3B X-Tail Throws/Settings PDX Slope Pilot Slope 6 Oct 03, 2006 11:26 PM
For Sale F3B Trinity v-tail fuse mrfski Aircraft - Sailplanes (FS/W) 8 Mar 25, 2006 11:57 AM
