This thread is privately moderated by Inconel_601, who may elect to delete unwanted replies.
Old Apr 19, 2006, 07:47 AM
Inconel_601 is offline
Find More Posts by Inconel_601
Trader Rating: 8
Joined Feb 2005
Trader Rating: 8
Sold
Must Go !!! Skyburner DF Jet w/OS .91, Dynamax Fan & tuned pipe
Partially scratch built ducted fan Skyburner Jet. Perfect ducted fan trainer for grass runways. Elevator & rudder shape slightly modified with anhedral in the stab to resemble BVM Bandit type tail feathers. Elevators have hinge slots cut out. Also modified for dual elevator servos in the rear fuselage. Fin/rudder need final shaping & hinging. Foam wing cores sheeted and ailerons cut out and edge sheeted. Wing tip blocks included. Ailerons ready for hinging. Set up for fixed gear. Gear blocks can easily be cut out and replaced with plates for retracts. Nose gear not installed. Requires some balsa sheeting for the turtle deck and fuselage bottom. Some foam is also needed for shaping the nose, intakes and tail cone. No full size plans, but the all important C.G. range is clearly marked on the inside of the fuselage.
Included in the package is a slightly used OS.91 VR-DF engine (excellent compression) with a tuned pipe and Dynamax ducted fan unit. Tuned pipe has pressure tap installed and spring retainer. Excellent shape and completely assembled. Comes only with remote needle. Recommend a JMP or BVM in-flight mixture control in its place.
New must go clearance price:
Price: $499 + shipping & insurance. Money Order only.
Inconel_601 is offline Find More Posts by Inconel_601
Sold Used Trim Ramtec OS 91 Ducted Fan Unit RC Jet Airplane junieb Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 06, 2007 10:30 PM
Sold New Trim Ramtec OS 91 Ducted Fan Unit RC Jet Airplanes junieb Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 30, 2007 08:43 AM
Sold Dynamax Ducted Fan w/OS ,91 VRDF & Tuned Pipe Inconel_601 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 26, 2006 10:35 PM
For Sale OS 91 Ducted Fan w/Dynamax fan and tuned pipe DiabloKid Aircraft - Fuel - Airplanes (FS/W) 1 Oct 30, 2005 11:57 PM
Question Has anyone coverted the:Kyosho F-16 Fighting Falcon DF ARF w/OS .15 CV-DF 38.2" to E Lv2Fly Electric Ducted Fan Jet Talk 3 Jun 26, 2004 02:48 PM
