This thread is privately moderated by nakman8, who may elect to delete unwanted replies.
Old Apr 16, 2006, 03:12 PM
nakman8 is offline
Find More Posts by nakman8
Trader Rating: 19
"OLD CHEAPSKATE" FOR SURE
nakman8's Avatar
Joined Dec 2004
Trader Rating: 19
Wanted
Brushed power system for 100" glider
Looking to "electrify" my old 100" Olympic glider.
Plenty of room inside. Did trial CG test and it look feasable. Have generic 600 size brushed motor that I can use or will consider others. Hoping to go DD but will consider gear driven setup. Need 20-25 amp ESC also. Not sure what prop I need. Suggestions?
LMK what ya might have to get me started.
nakman8 is offline Find More Posts by nakman8
Old Apr 16, 2006, 03:21 PM
smurf is offline
Find More Posts by smurf
Trader Rating: 122
smurf's Avatar
Texas
Joined Jan 2005
Trader Rating: 122
I have a kyosho NIB endoplasma and a GD 600 gearbox I'll let go for say $40. I don't know what the gear ratio is right now( am at work) but can let you know.
smurf is offline Find More Posts by smurf
Old Apr 16, 2006, 05:45 PM
kf4mot is offline
Find More Posts by kf4mot
Trader Rating: 10
kf4mot's Avatar
Panama City, Florida
Joined Jul 2003
Trader Rating: 10
I have one of these.
http://www2.towerhobbies.com/cgi-bin...?&I=LXZ904&P=7
It's not nib but it's never been used.
kf4mot is offline Find More Posts by kf4mot
Old Apr 16, 2006, 06:13 PM
1g1yy is offline
Find More Posts by 1g1yy
Trader Rating: 13
Nashville, TN
Joined May 2002
Trader Rating: 13
I have a direct drive speed 600 powering a 78" sailplane and it is barely adequate. I would say that, even geared, a speed 600 would not be good on a 100" sailplane.
1g1yy is offline Find More Posts by 1g1yy
Old Apr 16, 2006, 09:08 PM
smurf is offline
Trader Rating: 122
smurf's Avatar
Texas
Joined Jan 2005
Trader Rating: 122
Put that speed 600 on one of these and I think you will be surprised.
http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML
Old Apr 17, 2006, 09:30 AM
Wings Level is offline
Find More Posts by Wings Level
Trader Rating: 37
Wings Level's Avatar
USA, NC, Garner
Joined Jun 2003
Trader Rating: 37
hi,
I have a Mega S4 and a S6. These are big, brushed motors. They have 5mm shafts, and will easily haul a 100" sailplane up on direct drive using a 12" folding prop.
Either one shipped to you for $50.
I can make a reccomendatio0n about your battery/prop/motor selection if you give me a little more info about your plane.
PM me if you are interested.
Wings Level is offline Find More Posts by Wings Level
Old Apr 17, 2006, 11:00 AM
1g1yy is offline
Trader Rating: 13
Nashville, TN
Joined May 2002
Trader Rating: 13
Well that would certainly make a difference -- but there is not enough room on the nose of my sailplane, nor on the nose of the 100" sailplane I also have.
Old Apr 17, 2006, 12:25 PM
smurf is offline
Trader Rating: 122
smurf's Avatar
Texas
Joined Jan 2005
Trader Rating: 122
nakman8 says he has plenty of room according to the first post above.
If you don't have the room, I would recomend a planetary gearbox.
Old Apr 17, 2006, 12:28 PM
nakman8 is offline
Trader Rating: 19
nakman8's Avatar
Joined Dec 2004
Trader Rating: 19
more info on Olympic
Originally Posted by Wings Level
hi,
100" Olympic.Classic highstart glider from about 25 years ago. Don't remember who offered the kit. AUW would be around 50ozs. Super efficient airfoil. Plenty of room for batteries right under wing. Hope this helps.
Dennis
Old Apr 17, 2006, 02:03 PM
nakman8 is offline
Trader Rating: 19
nakman8's Avatar
Joined Dec 2004
Trader Rating: 19
gear box??
Speaking of GBs. Do you have to keep the prop shaft on the centeline of the fuselage,or can it be above the centerline. In other words,can I mount the motor on a planetary system inside the fuselage and the GB above the motor? Just a thought that came to mind with all the different GB configurations being offered.
Old Apr 17, 2006, 04:55 PM
smurf is offline
Trader Rating: 122
smurf's Avatar
Texas
Joined Jan 2005
Trader Rating: 122
A planetary system will be straight in line with the motor, no offset.
Old Apr 17, 2006, 05:11 PM
nakman8 is offline
Trader Rating: 19
nakman8's Avatar
Joined Dec 2004
Trader Rating: 19
I understand that. I have one in another glider.
With the GB you are offering do I need to modify the fuselege to keep the prop shaft on the centerline of the fuselege and not above it. Does it matter?
Haven't mounted a offset GB before.
Old Apr 17, 2006, 05:50 PM
smurf is offline
Trader Rating: 122
smurf's Avatar
Texas
Joined Jan 2005
Trader Rating: 122
I think it should be close to center but I'm not quite sure.
I just measure from centerline of prop shaft to the bottom of the motor is 1 1/4"
pm sent about pictures
Discussion Brushed power options for Easy Glider Electric merlinmurph Electric Sailplanes 29 Aug 22, 2006 02:40 PM
Basics of picking a power system for an e-glider? JoeR Electric Sailplanes 4 Feb 21, 2004 08:16 AM
brushed power system for a 40sized profile lagcisco Sport Planes 7 Oct 01, 2003 04:31 AM
WTB or Trade - 'Up n Go' Power System for High Sierra glider. Googleplex Aircraft - Electric - Airplanes (FS/W) 0 Apr 21, 2002 08:57 PM
