Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Kits)
Old Apr 16, 2006, 09:35 AM   #1
Foam Flyer
rc4metoo's Avatar
RippinFoamies.com Perfexion "Outdoor" Build
Hello fellow foam flyers!
Due to popular pressure, I have finished the design and started construction on an outdoor version of my popular Perfexion 3D foamie bipe. I call it the Perfexion OD (out-door).
Plans are now available on www.RippinFoamies.com.
Specs: Wings 33", Fuse 35", weight 14 ounces (est.)
Motor: Himax 2812
Battery: TP 1320 3-cell Pro-Lite
Enjoy!
John Cramer
  • Name: cuttin_foam_perfexion.jpg
Description: I print plans out full-size at Kinkos.  I am now putting stencils and plans on one sheet to save printing costs.  I then use the acetone transfer method to create posterboard templates to cut the foam. I print plans out full-size at Kinkos. I am now putting stencils and plans on one sheet to save printing costs. I then use the acetone transfer method to create posterboard templates to cut the foam. 26.0 KB · Views: 253
  • Name: perfexion_od_glue_fuse_front.jpg
Description: Fuse sides are stacked and hot glued at each end to form an envelope. Fuse sides are stacked and hot glued at each end to form an envelope. 39.6 KB · Views: 259
  • Name: perfexion_glue_wings.jpg
Description: Wing halves are glued at center with hot glue. Wing halves are glued at center with hot glue. 38.5 KB · Views: 244
  • Name: perfexion_glue_fuse_ends.jpg
Description: Tail end is hot glued. Tail end is hot glued. 32.8 KB · Views: 222
  • Name: Perfexion_and_Designer.jpg
Description: Perfexion OD and proud designer.  She flies great!  Like a glow ship without the mess.  Precise and 3D like a champ! Perfexion OD and proud designer. She flies great! Like a glow ship without the mess. Precise and 3D like a champ! 53.5 KB · Views: 288
Last edited by rc4metoo; Apr 28, 2006 at 11:57 AM. Reason: plans are now available
rc4metoo is offline Find More Posts by rc4metoo   Reply With Quote
Old Apr 16, 2006, 07:34 PM   #2
Foam Flyer
rc4metoo's Avatar
And a little more of the Perfexion OD 33"
Got a little more done.
JC
Chief designer and 3D test pilot
  • Name: perfexion_od_painting_1.jpg
Description: Foamy parts ready for painting the base (light) color using stecils cut from plans.  I really like painting Depron since it is snow white - it will take any color very well. Foamy parts ready for painting the base (light) color using stecils cut from plans. I really like painting Depron since it is snow white - it will take any color very well. 23.1 KB · Views: 247
  • Name: perfexion_painting_2.jpg
Description: Base color of yellow is complete.  This is Krylon Fusion paint and it dries by the time you can put the can down and take the stencils off. Base color of yellow is complete. This is Krylon Fusion paint and it dries by the time you can put the can down and take the stencils off. 25.8 KB · Views: 264
  • Name: perfexion_od_painting_3.jpg
Description: Stencil in place for second color (darker).  Mist on the Krylon from 1-2 feet away and don't use too much.  Stencil in place for second color (darker). Mist on the Krylon from 1-2 feet away and don't use too much. 21.9 KB · Views: 279
  • Name: perfexion_od_painting_4.jpg
Description: A batch of painted foamy parts.  The white Depron show bright colors very well. A batch of painted foamy parts. The white Depron show bright colors very well. 40.4 KB · Views: 312
Old Apr 19, 2006, 11:23 AM   #3
Foam Flyer
rc4metoo's Avatar
She's ready to rock!!!!!!!!!!!
I have completed the build. I'm bummed that I accidentally deleted the interior shots and the motor mount build . Oh, well, the plans will show that detail.
Enjoy!
I'll post a flight report as soon as it stops blowing here in Michigan.
JC
  • Name: perfexion_od_routing_wing.jpg
Description: Routing the spars channels on the bottom of both wing panels.  Routing the spars channels on the bottom of both wing panels. 47.8 KB · Views: 260
  • Name: perfexion_od_painting_5.jpg
Description: Apply tape and set with warm iron on "1".  I used small pieces of 3M Blenderm in high stress areas on the elevator and rudder. Apply tape and set with warm iron on "1". I used small pieces of 3M Blenderm in high stress areas on the elevator and rudder. 40.1 KB · Views: 268
  • Name: perfexion_od_rudder_servo.jpg
Description: Elevator servo detail.  I run extension wire inside the fuse to the RX. Elevator servo detail. I run extension wire inside the fuse to the RX. 33.1 KB · Views: 280
  • Name: perfexion_od_aileron_servo.jpg
Description: Aileron serve detail.  Short linkages.  Also, note how servos (2) are equidistant from the thrust line for knife-edge balance. Aileron serve detail. Short linkages. Also, note how servos (2) are equidistant from the thrust line for knife-edge balance. 23.5 KB · Views: 242
  • Name: Perfexion_OD_wheels.jpg
Description: Wheel pant cage.  This worked very well on my indoor models so I thought that I would try it out on this one. Wheel pant cage. This worked very well on my indoor models so I thought that I would try it out on this one. 44.8 KB · Views: 230
Old Apr 19, 2006, 11:30 AM   #4
Foam Flyer
rc4metoo's Avatar
Finished!!!!!!!!
Got here done. Need to test fly and clean up plans before release.
JC
  • Name: perfexion_od_aileron_links.jpg
Description: Aileron connectors.  Made from large zip ties and Dubro mini parts.  Connection between ailerons is 1mm CF rod. Aileron connectors. Made from large zip ties and Dubro mini parts. Connection between ailerons is 1mm CF rod. 29.3 KB · Views: 287
  • Name: perfexion_od_X-bracing.jpg
Description: Stringing the 1mm CF rod X-bracing.  This is one sturdy birdy. Stringing the 1mm CF rod X-bracing. This is one sturdy birdy. 44.7 KB · Views: 262
  • Name: Perfexion_OD_33_done_1.jpg
Description: She's done and ready to rumble.  Power is Himax 2812-850 on three cells.  Prop is APC 12x6 SF. She's done and ready to rumble. Power is Himax 2812-850 on three cells. Prop is APC 12x6 SF. 38.1 KB · Views: 286
  • Name: Perfexion_OD_33_done_3.jpg
Description: Top view.  This design is not just a scaled up indoor Perfexion.  I changed the wing design and elevator and fuse proportions. Top view. This design is not just a scaled up indoor Perfexion. I changed the wing design and elevator and fuse proportions. 51.8 KB · Views: 265
Description: Wow!  She is bigger than I thought!  Looking good and ready to rumble!  Amazing what you can do with a couple of pieces of foam! Wow! She is bigger than I thought! Looking good and ready to rumble! Amazing what you can do with a couple of pieces of foam! 53.5 KB · Views: 294
Old Apr 20, 2006, 05:30 AM   #5
UH-60 Blackhawk TI
hawk4932's Avatar
Yes, that thing is huge. Looks very good though.
Hawk
hawk4932 is offline Find More Posts by hawk4932   Reply With Quote
Old Apr 20, 2006, 09:33 AM   #6
Foam Flyer
rc4metoo's Avatar
Full fuse makes it look bigger...
Hawk
Yeah, she looks big. Here are the specs:
Wings: 33"
Length: 35.5"
RTF weight: 15 ounces (est.)
I just purchased a couple of new 3-cell 1320s lipos that will do 17 amps continuous so I should have plenty of power available.
JC
www.rippinfoamies.com
Old Apr 20, 2006, 09:56 AM   #7
Foam Flyer
rc4metoo's Avatar
Found the missing construction photos!
Seems I had downloaded these before reformatting my camera card.
JC
  • Name: perfexion_od_motor_mount_1.jpg
Description: Stick mount for Himaxx is made from 3/8" hardwood and popsicle sticks.  Cut recessed notches in hardwood stick. Stick mount for Himaxx is made from 3/8" hardwood and popsicle sticks. Cut recessed notches in hardwood stick. 34.2 KB · Views: 228
  • Name: perfexion_motor_mount_2.jpg
Description: Use medium CA to attach popsicle sticks. Use medium CA to attach popsicle sticks. 43.5 KB · Views: 242
  • Name: perfexion_motor_mount_3.jpg
Description: Align and hot glue to horizontal foam motor mount. Align and hot glue to horizontal foam motor mount. 46.6 KB · Views: 214
  • Name: perfexion_motor_mount_bottom.jpg
Description: Slide in and hot glue to nose. Slide in and hot glue to nose. 41.2 KB · Views: 248
Old Apr 20, 2006, 10:02 AM   #8
Foam Flyer
rc4metoo's Avatar
Buttoning up construction..
JC
  • Name: perfexion_od_wingspars.jpg
Description: I glue in my CF rod wing spars with foam-safe CA. I glue in my CF rod wing spars with foam-safe CA. 31.0 KB · Views: 222
  • Name: perfexion_od_fuse_const.jpg
Description: Insert uppper fuse piece and glue in.  Leave bottom open for installation of electronics. Insert uppper fuse piece and glue in. Leave bottom open for installation of electronics. 53.3 KB · Views: 235
  • Name: perfexion_od_fuse_bottom_open.jpg
Description: Hot glue in all the electronics.  I need servo extension for the elevator and rudder. Hot glue in all the electronics. I need servo extension for the elevator and rudder. 32.5 KB · Views: 251
  • Name: perfexion_od_fuse_testing.jpg
Description: Make sure everthing works before fitting in bottom of fuse. Make sure everthing works before fitting in bottom of fuse. 61.6 KB · Views: 252
  • Name: perfexion_od_fuse_completed.jpg
Description: Fuse all buttoned up.  RX is blue square in photo.  It can be pulled out to access servo connections. Fuse all buttoned up. RX is blue square in photo. It can be pulled out to access servo connections. 50.6 KB · Views: 242
Old Apr 20, 2006, 10:05 AM   #9
Foam Flyer
rc4metoo's Avatar
One more beauty shot...
Looking gooooood!
JC
  • Name: Perfexion_OD_33_done_2.jpg
Description: Window design is similar to British V-bombers. Window design is similar to British V-bombers. 48.0 KB · Views: 205
  • Name: Perfexion_OD_33_done_4.jpg
Description: Wheel pants really dress her up!  Mean looking stance. Wheel pants really dress her up! Mean looking stance. 40.6 KB · Views: 252
Old Apr 21, 2006, 06:11 AM   #10
UH-60 Blackhawk TI
hawk4932's Avatar
Looking forward to your maiden to see how she performs. Will you be able to get any video of it??? Thanks, Hawk
Old Apr 21, 2006, 11:42 AM   #11
Foam Flyer
rc4metoo's Avatar
Hopefully flying tonight. Weather is great outside now. Did weight and balance and she looks fine. AUW RTF is 16 ounces. Short video possible tonight if all goes well.
JC
Old Apr 22, 2006, 12:48 PM   #12
Foam Flyer
rc4metoo's Avatar
She flies!!! See Video!
Got rained out last night, but managed one flight this morning before the winds blew up. Flight testing cut short by motor vibration. I think it is just a combination of shimming the stick-mount to reduce play, and balancing the prop. Vibration precluded much WOT testing.
CG is about "on" for beginner/intermediate 3D, but I'll move it a little forward for my personal "advanced" preference (if I say so myself ).
How does she fly? Great! This thing flies like a glow ship. It tracks very straight, rolls very fast and crisp, and has virtually no roll coupling. Very similar to the indoor model in this respect. The winds started blowing when we shot some video and it penetrated quite well - better than my numerous other foamies.
I'm looking forward to more testing before I clean-up the plans and release.
Video: http://www.RippinFoamies.com/Public/...rfexion_OD.mov
Best regards,
JC
Old Apr 24, 2006, 09:32 PM   #13
Foam Flyer
rc4metoo's Avatar
Five more flights and wow! what a foamie!
Just a quick update for those interested. She is flying great. Flies very precise, will take some wind, rolls great, ....flies a like a much bigger 3D glow ship. She will do a knife-edge wall, and no problem with large knife-edge loops on knife-edge loops.
Stick motor mount broke (on the motor). I converted Himax to back bulkhead mount. This is actually simpler method and probably for the best as most motor are not stick mount.
Got CG correct with new motor mount. No changes to fuse needed. I'll be cleaning up plans for release soon.
I'm lovin' it!
JC
Old Apr 25, 2006, 03:21 AM   #14
UH-60 Blackhawk TI
hawk4932's Avatar
Unfortunatly I have not been able to view the video. It maybe my crappy dialup connection.
Could the fuse be built using 3mm depron to cut down on the weight and how much would you think that this would save? I have an extra ESSKAY 400XT which will fly models up to 18 ozs but I need to get the weight down to around 10-11 ozs for 3D type flight with this motor.Thanks
Hawk
Old Apr 25, 2006, 09:18 AM   #15
Foam Flyer
rc4metoo's Avatar
Motors...
Hawk
Hello Hawk,
I just downloaded the move and it played OK, but I have DSL. The movie is about 4 meg.
I looked up the specs of the Esskay 400XT and it is too small for the Perfexion Outdoor model. I am recommending 150-200 watt motors for the Perfexion Outdoor. The Himax HC2812-850 that I am currently using is a 150 watt motor.
I would not recommend building the Perfexion Outdoor out of 3mm depron. It could be done but a model of this size at 10-11 ounces would not be suitable for outdoor flying - it would simply be blown away in the wind.
I sometimes find myself trying to find airframe designs that fit the motors that I have on hand. It is better to find a design that you like and then acquire the correct components.
Best regards,
JC
Build Log Planeinsanemodels.com - THORN LIGHT - Build and fly! THUREN Slope 24 Oct 24, 2007 02:11 PM
3dfoamy.com Turbo Raven build bobsean 3D Flying 22 Oct 29, 2004 04:01 PM
FunPlanes.com EPP 540T Build GW 3D Flying 51 Jan 09, 2004 07:05 PM
11
