Old Apr 15, 2006, 08:59 PM
nopistons96 is offline
Find More Posts by nopistons96
who needs pistons?
nopistons96's Avatar
mankato,mn
F-18 Super C of G?
Hey guys, i'm getting close to getting this bird in the air but before i do, i need some help from you guys. if anyone can help me double check the cg i would greatly appeciate it. i figured it to be where i have the red line in the pict. the wingspan is 24". (i dont know if that is needed). i used some of the free calculators that are online to check it for myself but i would feel better if i had a second opinion. i'm not quite sure how to calculate in the lex's. thanks in advance.
mike
it's a scratch build from depron. minifan. 16/15/2. 3s. auw=26-28oz. (no paint/decals yet)
nopistons96 is offline Find More Posts by nopistons96
Old Apr 16, 2006, 03:35 AM
birdseed is offline
Find More Posts by birdseed
birdseed's Avatar
sussex England
Joined Jun 2002
I cant answer, but when someone who knows does, theyll need the root and tip length, and wing diameter.
birdseed is offline Find More Posts by birdseed
Old Apr 16, 2006, 04:14 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
The model looks good.
I can't do the CG at the moment but it looks too far forward to me.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Apr 16, 2006, 04:47 PM
who needs pistons?
mankato,mn
Hello Kevin.
Thanks. i know it's a pain, but any help would be a great help. i hope to graduate to something like your SH someday. that bird is absolutely gorgeous. it was part of the inspiration for this build. i just have start out a bit smaller.
thanks again guys.
mike
Old Apr 16, 2006, 09:51 PM
Lboogie is offline
Find More Posts by Lboogie
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Give me the WS total, The length and width of the LEX, the cord of the wing at the intersection of the LEX and the wing and the tip. If you could illistrate a photo to show me where you took your measurements. I'll see what I can do.
Leonard
Lboogie is offline Find More Posts by Lboogie
Old Apr 17, 2006, 06:45 AM
winmodels is offline
Find More Posts by winmodels
Wareham, Dorset, UK
Joined Dec 2003
Originally Posted by Kevin Cox
The model looks good.I can't do the CG at the moment but it looks too far forward to me.
Hi
agreed. As the picture shows the AC alone already is behind the red line.
The influence of the LERX's is probably less destabilising than the stabilising effect of the elevators, at least at small AoA. I would start with the CG in the position of the AC. What sort of air foil did you use?
Have fun with fans
Klaus
winmodels is offline Find More Posts by winmodels
Old Apr 17, 2006, 08:39 AM
who needs pistons?
mankato,mn
thanks
Hello Klaus,
thank you for your help. your drawing helped me out a bunch. i wasn't sure if i was supposed to include the area of the wing that is also part of the fuse in the calculations. i will start with you suggestion of using the AC as the CG.
sorry for the dum question, but what does AC stand for? just when i guy thinks that he's starting to figure some of this stuff out, he get's served a slice of humble pie.
i included an image of what the airfoil is. the orange lines represent the layered depron and the black is the shape that i sanded it to. thanks again.
mike
Old Apr 17, 2006, 09:07 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Why not just knock up a simple profile fuselage 'chuck' glider to work out an approx CG?... Not very scientific I know, but quite reliable.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 17, 2006, 11:23 AM
Wareham, Dorset, UK
Joined Dec 2003
AC stands for Aerodynamic Centre, which for a wing only is usually around 25% back from the leading edge of the mean arodynamic chord. "Usually" because it can be more forward on cambered air foil sections: 22%. The AC of the whole plane is further back from the wing AC on planes with normal elevator arrangement and size. This results in an AC of ~30% back from the leading edge of the MAC. On canards the plane's AC is further forward. There is a lot more to it than one can put into a few sentences; best solution is to read a few books and get yourself "educated".
Have fun with fans
Klaus
Old Apr 18, 2006, 03:12 AM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
Hi
When I used 'line method' that winmodels suggested to my 1:12 F18C pusher it was about 4cm rear. LEX had huge effect. And E/F's have even bigger LEX.
I've used the same CG in all my Hornet's since I found it. They all are C-versions though. Had no reason to move it.
My balancing point is in a line from hingeline of root of LEF (leading edge flap)to another side. Sorry I can't say it any aesier
Jyri
jjantti is offline Find More Posts by jjantti
Old Apr 18, 2006, 04:57 AM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
mike
Looks pretty nose heavy to me. Depending on which planform you use, it's either 4.5% (wing + lex) or 0% (wing alone).
I did a quick CG calc and posted the results below. The dark blue is the wing + lex and the light blue is the wing alone. The vertical lines (chordwise) are the mean aerodynamic chord (MAC) and the horizontal lines (spanwise) are the CG balanced at 25% MAC. This should be good enough to get you airborne.
As you can see the difference isn't that much. I would definitely use the dark blue because the lex does make a difference in how the model flys. If you use the wing alone, your balance will be about 3% nose heavy, which is the difference you're seeing between the wing + lex and wing alone.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Apr 18, 2006, 06:21 AM
jjantti is offline
jjantti's Avatar
Finland
Joined Sep 2004
Seems like I had something fishy in my calculations back then.
The test flight I wrote was -98 or something.
I must have had something wrong.
But I do remember result.
Half loop from taxing even with full down elevator. Pulled back throttle when inverted about 30m of height.
Stall and perfectly vertical flat bottom drop to asphalt. Flies like a glove
Moved CG 4cm to next attempt. Tzadaa! it flies!
DanSavage, I just couldn't get it.
How did you took LEX into calculations?
dividing to two separate pieces, two MAC's, weighted mean to combine them?
Might be usefull to know.
Picture says it better what I was trying to say.
My "trusty" seems to be about 15% (wing only).
/Jyri
Old Apr 18, 2006, 08:14 AM
who needs pistons?
mankato,mn
Hello jjantti, Hello Dan,
Man, i love this place. thanks for helpin a guy out. it's appreciated. Luckily i haven't built the battery tray yet. but it is the next step. You two and Klaus helped out a ton and hopefully the next time you see this bird is in a video eating up the skies. if all goes well that should be this weekend. wish me luck.
thanks again.
mike
Old Apr 18, 2006, 06:28 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
First, I import the top-view photo into my CAD program and traced the planform. Next, I used the Center of Gravity command in DesignCAD 3D MAX. (seriously)
In other CAD programs, it's called a centroid, or geometric center of mass (GCoM). In the case of a wing planform, the centroid corresponds to the MAC.
So, by drawing a line through the centroid that intersects the leading and trailing edges, we obtain the MAC. From here, it's a simple matter of finding the balance point along that line.
The tricky part is defining what should and shouldn't be included in the MAC. While this isn't perfect, it will usually get you close enough so that you can test-fly the model without crashing and destroying it on the maiden voyage.
The reason why you had to balance your F-18 at 15% MAC is because your calculations didn't take into account the lex. Had you done this, I'd bet you'd find that your CG was really close to 25% MAC.
FWIW, I'll import the drawing you posted and re-calc the CG including the lex so you can see the difference it makes.
Dan
Old Apr 19, 2006, 04:04 AM
jjantti is offline
jjantti's Avatar
Finland
Joined Sep 2004
Thanks Dan.
Now I got it. Keyword was centroid.
Didn't even dream that software mainly for drawing houses could do that...
For others that use autocad:
Draw outlines (wing and lex and stuff)in new layer. Convert them into region.
Calculate massproperties and there you have it: centroid. In cordinates only, but it's easy to draw MAC with them.
BTW, my 'trusty' was about 16,3% MAC including LEX. I'll have to test moving it backwards and see what happens...
/Jyri
F-18 Super Hornet ParkJet RCParkflyer Pusher Prop Jet Models 19 Jun 02, 2007 11:34 PM
Sold F-18 Super Hornet papamac Aircraft - Electric - Airplanes (FS/W) 8 Feb 09, 2006 04:39 AM
For Sale F.S. SUPER TIGER G 45 made in ITALY dumbthumbs Aircraft - Fuel - Airplanes (FS/W) 1 May 26, 2005 10:40 AM
EAM F-18 Super Hornet- I'm scared!!! ttnissan Electric Ducted Fan Jet Talk 5 Jun 16, 2003 04:00 PM
EJF - press releases, ejets.tv, F-18 ARF, F-18 Super Hornet for 90 mm EDF Robert Wagoner Electric Ducted Fan Jet Talk 4 Jun 24, 2002 12:11 PM
